Loud noises on first inflation new CF wheels
The several noise sounded nothing like I expect with tire bead seating, and at low pressure (<60 psi). The wheels run true and no evidence of problem. After this I feared but I have NOT heard amplified wheel sounds riding-. as is suggested with some CF wheels. I can find not mention of wheels doing this. Windspace hyper 38mm rim brake.
Quoted: 7650 Post(s)
Liked 3,472 Times
I generally only inflate my tires, not my wheels.
Likes For Maelochs:
Quoted: 763 Post(s)
Liked 1,731 Times
possible spoke seating? If they were not tension and stressed properly, they could be releasing that stress. I had that on new wheels in the past, generally, alloy, but not sure if it would happen to carbon.
Likes For jaxgtr:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I wouldn’t worry about any weird noises the first time you inflate a tire on the wheel, the first 50 feet of riding, or the first time you hammer out some high wattage to climb a steep hill... with whatever rim material. Any sounds that continue or reappear might be of concern.
My CF wheels will make a big pop sometimes more than once when they finally seat at 10 lbs more than riding pressure. That's normal for my Boyd 60's and 5000s.
Quoted: 1456 Post(s)
Liked 1,477 Times
Tubeless or tubed?
I ask because there was a poster on here a few months back that destroyed a cheap set of generic carbon wheels after trying to seat a tubeless tire on them. The wheels were not in fact tubeless ready.
Quoted: 6191 Post(s)
Liked 4,807 Times
I get loud noises when I inflate my new tires on alloy wheels. I wouldn't be surprised if CF rims were a different sound and maybe even louder.
I almost always inflate and deflate my tube and tires three times when one is new just to make sure things untwist or get into their proper position.
Edit: for the sticklers...
I inflate my new tires three times and deflate them twice. <grin>
Quoted: 6958 Post(s)
Liked 10,959 Times
Winspace Hyper owner here (50mm, disc); I'm familiar with the noise you speak of, and experience it every tube/tire change.
IMO, sounds like pretty standard CF rim bead seating. I'm 10,000km and several tire changes deep with no issues. I wouldn't worry about it!
Edit: unrelated, but when you get a chance, yank the freehub off and grease the pawls. This should alleviate the ticking issue faced by virtually all Hyper owners at the 4,000km mark.
The sounds are terrifying, and completely normal.
www.mp-aviation.com
www.mp-aviation.com
