Best puncture-resistant 45C road tyre instead of WTB Riddlers?
Quoted: 144 Post(s)
Liked 119 Times
I recently bought a bike with WTB Riddler 45C tyres because I'm sick of constantly being rattled apart by the goat tracks I have to use on my commutes. I do very little actual gravel riding, though that may change down the line.
My tyres of choice have always been puncture-resistant: Marathon Plus, Gatorskins etc. Have flirted with the idea of Tannus Armor inserts, but never pulled the trigger. Yes, I know the Marathons are particularly slow, but I prioritise puncture-resistance.
I have actually quite enjoyed riding on the Riddlers, even on pavement. Would a slicker tyre be that much quicker? If I keep the Riddlers then I'd definitely consider the Tannus inserts. Bad idea?
I've made up my mind about tubeless, and it is not an option. Really.
So, a 45C puncture-resistant tyre for pavement? Tannus Armor inserts? Thoughts?
Likes For Toadmeister:
Quoted: 144 Post(s)
Liked 119 Times
Although I can answer that question I'm not going to, because I don't want this thread to be that kind of discussion.
There are other threads for discussing that stuff.
Likes For fredlord:
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
If puncture resistance is your priority, tubeless is the way to go. I personally love the Specialized Pathfinder pro. I'm using the 38 mm version, but they have a 42 mm version.
Likes For KJ43:
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
If the riddlers work, then just keep em.
If they don't, then go with the heaviedt thickest marathon tire..
...and then of those don't work, look into a tire inflation system which can self seal when small punctures occur
Quoted: 144 Post(s)
Liked 119 Times
Well, that's the issue; they ride fine, but I keep hearing that they're not particularly puncture resistant. That's why I'm thinking about using the Tannus inserts with them. I'll research to see if that will be much heavier and/or slower than switching out to 45C Marathon Pluses.
Quoted: 6963 Post(s)
Liked 10,961 Times
If the Riddlers do end up being too puncture prone for you, you should just take mstateglfr ’s advice.
Quoted: 6193 Post(s)
Liked 4,808 Times
Don't worry about punctures if you aren't having punctures. I think only a few are cursed enough to live in an area where they happen.
Likes For Iride01:
Quoted: 101 Post(s)
Liked 41 Times
So, I have run the 45mm Riddlers and am currently running the 45mm Maxxis Ramblers. In my limited experience, the Ramblers ride similar but have been a marginally more robust against punctures…that being said, I have run both tubeless, so it’s hard to gauge whether or not I’ve got many punctures on the Ramblers, because really small ones could be happening and sealing up without noticing. Personally, I’ll probably go back to the 40mm Ramblers when these get replaced…clearance is a little tight on my current bike with the 45s.
My theory is that there are essentially two strategies you can try for puncture protection:
Both options work. #1 is probably easier to set up and more versatile (eg, no need for special rims, or if you like to swap out tires) but the ride is almost certainly going to be better on option #2.
- A bulletproof tire with a built-in puncture protection layer (Marathons) or some add-on layer like the Tannus armor (Mr Tuffy, etc).
- A relatively supple tire running tubeless with ample sealant.
Quoted: 144 Post(s)
Liked 119 Times
This page is the reason why I going tubeless with the Riddlers is almost certainly not going to be an option for me. I'm increasingly thinking about just ditchng them and going with the Marathon Pluses.
Reviews start at bottom of page.
Reviews of WTB Riddlers
Liked 10,961 Times
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
I don't have experience with the Riddlers, but I had the Rambler (tubeless) when I first got my bike for about 6 months with zero issues and I rode them hard on a variety of surfaces including semi-technical single track. I did have to bump the pressure up here and there before my rides (2 - 3 psi), but that is par for the course with tubeless tires and completely worth the ride quality and ability to seal itself.
Quoted: 668 Post(s)
Liked 529 Times
the webites for both Continental and Swalbe let you sort their tires by puncture rating.
But having said that as far as tubed tires go you won't find much of anything more highly rated than the marathon pluses. I rode the cowboy trail in Nebraska on a set of marathon plus MTB tires because I was concerned about poor trail conditions. Between all the puncture belts and half inch deep lugs on the tires I can honestly say they are goathead proof. I didn't realize how many the tires were picking up until I transitioned to smooth pavement and wondered what all the tapping noises were. Pulled a half dozen from each tire.
Having said that the first thing I did when I got back was remove those nearly new tires and get rid of them. The tire alone weighed over a kilo each. These are 26 inch wheels. God awful miserable things, rode horribly, stupid slow accelerating. Simply not worth it.
Next time I ride that trail it will be on gravelking SK tires set up tubeless. The ride is night and day different and my guess they will prove as puncture reistant.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
If you want something lighter than the Marathon Plus, maybe the Panaracer Gravelking SS Plus+ 700x43. It's half the weight of the Marathon Plus, so no way is as tough as a Marathon, but it does have a bead to bead protection layer (that's what the "Plus+" means).
I've used the wire-beaded Riddlers (700x45) and the Gravelking SS Plus+ (700x43) and the Gravelkings feel faster/smoother.
Likes For tyrion:
Quoted: 144 Post(s)
Liked 119 Times
I've done some non-tubeless research and maths for 700 x 45C:
- 2 Riddlers + 2 Tannus Armors = 1660g
- 2 Marathon Pluses = 2020g
Liked 10,961 Times
Likes For Koyote:
Expired Member
Quoted: 3665 Post(s)
Liked 5,416 Times
The GravelKing SS+ in 700X43 is 530g. Add tubes and you'll still be lighter than those two options.
https://www.panaracerusa.com/collect...vel-tires#info The SK+ is 540g if you like more tread.
Likes For shelbyfv:
Liked 10,961 Times
Likes For Koyote:
Quoted: 144 Post(s)
Liked 119 Times
And they're right!
Likes For fredlord:
Liked 10,961 Times
They suspect that I am a lazy, non-resourceful, ham-fisted, impractical buffoon with more money than sense who nevertheless sports a powerful set of glutes and quadriceps more than capable of propelling him through the cracked and pot-holed terrain of his urban nightmare, no matter the weight of his tyres.
And they're right!
And they're right!
