Cue sheet holder
Quoted: 5 Post(s)
Cue sheet holder
I'm riding a club series this year that doesn't mark the routes. What do you folks use for a cue sheet holder? Thanks for the time.
Bikes: 2003 Litespeed Vortex, 2017 All-City Mr. Pink, ~1997 Trek Multitrack 700
Quoted: 139 Post(s)
Liked 94 Times
The vast majority of cue sheets are in a font that is too small for me to read easily. I've found I much prefer to follow the "pink" line on my eTrek 20 instead. But I do want to know where the next control is as well as what the name of the business is. I recently got a top tube phone/snack holder that works perfect to hold a custom cue sheet I create with the relevant information about controls. I do carry the full cue sheet in my pocket just in case technology fails me.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I use the 'map case' on the top of my handlebar bag. The window is about 9.5" wide, 6.5" high, and pretty waterproof. I format my cue sheet into two columns. I try to put a controle at the end of each page, so the controle becomes a natural place to change the cue sheet page. This weekend's 300k works out to three pages this way.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 2604 Post(s)
Liked 1,933 Times
Since I bought my Ortlieb bar bag (almost 10 years ago now!), I've been using the cue sheet holder that snaps to the top of the bag.
Before that, I sometimes used a large zip-lock bag and secure it to shifter cables with a couple of binder clips.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Cyclo Active Bicycle Bar Map Cover - available on Amazon.
I create my own cue sheets to fit in this holder, using csv files downloaded from RideWithGPS. I import into a spreadsheet, massage some, then import into a word processor. Once you figure out how, it only takes a few minutes. The figuring out how can take a while, though. I have columns for a one word direction of turn, street name, and mileage all in 14 pt. type, like this:
Click on the PDF link to download, then click on the download to display in Adobe Reader.
Results matter
Results matter
Quoted: 4399 Post(s)
Liked 1,556 Times
The cue sheets I'm used to were arranged in 2-3" wide columns. So I would fold the paper to that narrow width and use a strip of clear packing tape to "laminate" them and connect the top and bottom around the handlbar top in a loose cuff. As I went down the sheet I'd just rotate it. Simple, light, cheap, waterproof and it can't fall off or get in the way.
Randomhead
Liked 3,696 Times
I used to laminate them with packing tape too. I would tape the whole cue sheet together page by page and then use packing tape to hold it together. It worked pretty well, and I had a cue sheet holder bent out of stainless tubing and used clips to hold the cue sheet on.
I have adopted a handlebar bag, so I use the map pocket on that now. It's simpler.
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 103 Post(s)
Liked 27 Times
I have used a Clue Clip Map and Cue Sheet holder for a number of years now. I just print off the cue sheet, stick in a zip log bag and then clip it to my handlebars.
Uber Goober
One of these:
https://www.amazon.com/Cyclo-Active-.../dp/B000AP0ACI
No, they're not waterproof. And if you have the wrong arrangement of speedometer and stuff on your stem, it may not fit well.
Randomhead
Liked 3,696 Times
the thing that bothers me about cue sheets behind the bars is that I like to stand up without hitting my knees on anything.
multimodal commuter
Liked 574 Times
I agree, anything behind the handlebar isn't good. Also, I dislike a cue sheet that flops around with the wind.
What I wish for, with a cue sheet, is one where my eye falls immediately on the right spot. I spend far too much time figuring out where on the cue sheet I am. I need to devise some kind of moveable marker that highlights the relevant cue.
I like the idea of a long paper scroll, where you turn a knob to move it along. But gee, I carry way too much crap already.
Randomhead
Liked 3,696 Times
I have used a binder clip as a pointer. I have gotten better at just remembering where to look on the sheet though.
I used to think about making the ultimate cue sheet holder. But usually I make them at the last minute and they are not that great. One of them started out as the platform for a randonneuring bag rack, but then I started adding weight to it and finally it broke.
Jedi Master
Cyclo Active Bicycle Bar Map Cover is good if it fits around the other stuff on your bars.
I've also used two of these little clips on a ziplock bag with some success
Before I used GPS, I preferred my cue sheet to be in a map holder in front of the bar. Something like the Zefal Doomap or Cyclo Active Bar Map. I would mount it backwards to the handlebar, then support the front end of the bag with some kind of brace or aerobars. You could likely use a front light or phone holder as the primary structure for such a brace.
Several of the randonneurs in my club had home made cue sheet supports that approximated stem-mounted clipboards. You can buy a modern version here: Q: PRO COMPLETE ABS ? BarYak
Jedi Master
That reminds me. I made one out of a coat-hanger, a piece of cardboard, a binder clip, some tape and a ziplock bag. It worked ok, but I didn't like the way it looked.
i wish
32
08-02-12 02:49 PM
