Sacrificial Bike for Trainer?
Quoted: 120 Post(s)
Liked 53 Times
Does a market exist for these?
I got a Tacx Neo 2t for Fathers Day and am looking to set it up but would perfer not to have to shlep on of my bikes from the basement storage to the third floor to where I will have the trainer set up.
Is there a place to find crash damaged frames that would suffice for trainer duty? Am I stupid for thinking along these lines??
Randomhead
Liked 3,664 Times
I'm not sure what a crash damaged frame would do for you. If it breaks, you'll still wind up on the ground, it's just in your basement instead of on the road.
OTOH, the bike on my trainer has a frame that I bought for $30 and built up out of spares.
Might be tough to find such a thing right now though. I think having a dedicated trainer bike is a great idea.
Bikes: yes, i have one
Quoted: 1124 Post(s)
Liked 1,171 Times
i think the OP would just get a virtual booboo at virtual speed.
try craig's list for something cheap. there is usually plenty. or you can get one of those Euro bikes i've read about on amazon.
Likes For spelger:
Quoted: 120 Post(s)
Liked 53 Times
What happens to frames like that when they are condemned by the bike shop or manufacturer?
Randomhead
Liked 3,664 Times
If it's crash damaged, my lbs offers to send the frame to metal recycling
Warranty, it gets cut up.
Quoted: 18320 Post(s)
Liked 4,489 Times
I don't think I'd use a very expensive road bike on a fixed wheel trainer... unless someone else paid for the bike.
Possibly on a roller trainer.
It wouldn't hurt to put up a Craigslist ad... "Wanted Damaged/Abused road bike or frame".
I'd be less concerned with a frontend damaged frame on a trainer than on the road.
Randomhead
Liked 3,664 Times
people tend to overvalue crashed bikes. To me, if I can't ride a bike on the road, it's worth zero. My next trainer bike is going to use a frame I found in the trash, but I'm going to fix it first.
I think it's worth looking, but recognize that your trainer bike should work well
Quoted: 120 Post(s)
Liked 53 Times
Bumping this thread up.
I haven't really come across anything yet that I would like to purchase/build strictly for the trainer, so I am now thinking about using my Lemond Zurich. However, this bike works well and has sentimental value and I don't want it to get trashed.
I'm curious whether anyone has tips to avoid damage to an older steel bike in this situation. I imagine sweat is the primary issue. Anything else? What about the front wheel/tire? Do they suffer from sitting in one position? I have a spare of both that I guess I should probably just throw on there.
Quoted: 310 Post(s)
Liked 664 Times
Parts such as stem bolts and headsets can suffer from rust, as your sweat can drip into these areas. Keeping a towel over the front end while training helps.
I don't think the front wheel suffers at all from being kept in the one spot all the time. I do rotate mine from time to time for no other reason than it puts my mind at ease.
Likes For tempocyclist:
mosquito rancher
I'm using a carbon 90s-era Trek (which I bought specifically for the purpose; upgraded the drivetrain with Microshift parts to bring it into the 21st century) on my stationary, and it definitely looks the worse for it. I do keep a sweat guard over the top tube and stem, but the finish on the cranks is rough, the bottle-cage "braze ons" are corroded, and sweat nearly seized the seatpost (my wife and I both use it, so it gets raised/lowered frequently). I wound up putting a bit of aluminum anti-seize paste on it.
Adam Rice
Adam Rice
Likes For adamrice:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4268 Post(s)
Liked 2,939 Times
My oldest road bike is now a dedicated trainer bike. If you don't have similar, buy an old used bike that fits. As long as the frame geometry is right and the drive train is good (or can be easily replaced), you're set.
Sweat is a huge issue for destroying bikes. If it's an old bike about which you care little, it's no big deal. But definitely throw a thick towel over the bars. And buy something like this
Likes For MinnMan:
Quoted: 120 Post(s)
Liked 53 Times
Thanks guys. I guess that confirms my original suspicion. I’ll keep looking on CL.
I did stop by my local bike co-op and they had a bike about two sizes too small that I could probably get the geometry right with some creativity. Is that a bad idea?
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 543 Post(s)
Liked 469 Times
Regarding choosing a bike that's not the right fit, I would not recommend that. You end up spending a lot of time on that bike in the winter months and if it doesn't fit right, you will feel that after many hours of the same motion.
mosquito rancher
Geometry on a stationary is less sensitive in some ways because you don't need to worry about how a long stem + short top tube will have different handling than a short stem + long top tube. Standover clearance is less of an issue. I think if you can get your hip-knee-ankle relationship right, you're probably good.
Adam Rice
Adam Rice
Randomhead
Liked 3,664 Times
Does it have room for spacers on the steerer? I suppose you could get an outlandishly long stem and a steerer extension. I started out with downtube shifters, which works fine with erg training like trainerroad, but if you are going to JRA on zwift, you'll want the kind of shifting you are used to, whatever that might be.
Quoted: 120 Post(s)
Liked 53 Times
That's what I did. My dedicated trainer bike is on the small side for me, and the way I've got it set up is different from my road position in lots of little ways. I rationalize this away by the fact that my erg sessions are rarely more than 90 minutes, so I can live with the imperfect fit for that duration. If I were routinely putting in multi-hour erg sessions, I'd want a better fit.
But things do start looking pretty hinky with the steering exten-der/sion...
Quoted: 806 Post(s)
Liked 1,612 Times
Likes For Bald Paul:
Quoted: 1455 Post(s)
Liked 1,477 Times
Personally I have no concerns about riding a fancy bike (or carbon wheels) on an indoor trainer.
Sweat can definitely cause damage, but this is easily solved with covering the headset and top tube with towels or one of those sweat net things, and giving the bike a wipe down once in a while.
Otherwise I don't think there's anything about an indoor trainer that causes any unique stress or potential damage to a bike or wheels. Maybe rotate the front wheel every few rides if you're really concerned about spoke fatigue, but even this seems like a non-issue to me.
Likes For msu2001la:
Quoted: 543 Post(s)
Liked 469 Times
I don't remember it being that way when I put it on initially 1.5 years ago.
Liked 1,477 Times
Any idea as to whether a wheel on trainer, pushing into the rear tire with the roller could impact the wheel? I had to adjust my bike and remove it from the trainer and put it back on but before I tightened the roller to the tire, I gave the wheel a good spin and it was significantly un true.
On my wheel-on Kickr Snap, I air my 28mm tire up to 90psi (which is higher than I would ride outdoors, but still well below the listed max pressure for that tire), and then I tighten the knob on the trainer until the tire just makes contact with the roller - From there I give it two full turns. This seems to be just enough roller pressure to prevent tire slip on hard efforts. The tire does squish a bit where it contacts the roller, but no more so than what I would see when riding outdoors.
Liked 1,477 Times
And for what it's worth, I've put around 2000 miles on a set of low-spoke count carbon wheels on my wheel-on indoor trainer over the last year or so and haven't had any issues. These are cheap generic Chinese carbon wheels (Superteam). They're still perfectly true. I occasionally ride these outside and on rollers as well.
Quoted: 543 Post(s)
Liked 469 Times
thanks msu2001la, good to know. I don't see how it could have affected the wheel but just found it weird that it got out of shape when it hasn't seen pavement in ages or had any weight resting on it.
Quoted: 237 Post(s)
Liked 177 Times
Caveat: I'm not as cost sensitive as some; I ride a lot.
That said, I have 4-5 bikes and just decided to put the Specialized Roubaix on the KICKR CORE and leave it there a couple of years back and that's worked out well. I bought it used, it's a 3x9 and while I enjoy riding it outside, it was only ever ridden when I was on super-nasty surfaced routes.
I'd choose a budget and get a dedicated frame. FWIW, I also found that after logging a few thousand miles indoor, riding technique is not entirely identical, and it was ultimately helpful to not be thinking in terms of "this bike / that bike" but "indoor set up / outdoor set up." I'm already failing to keep this short, but some of what I am discussing boils down to how I do a LOT less free-wheeling indoors and for some reason just don't get up out of the saddle as much as outdoors. Also I'm old and have various issues, so posture is always a concern.
In getting a 'sacrificial' bike the one huge warning I'd give is that if you're overly cheap, you might really wind up disliking the indoor experience and/or even wind up with a nagging injury because you don't put as much care into the set up.
Quoted: 2952 Post(s)
Liked 3,106 Times
