Helping finding a new wheel
Hi,
I have a broken spoke that I think has caused the wheel to warp a bit. I need a new front wheel.
Here are all the details I can find:
There is a sticker on the rim that says "Matrix 750"
The tire says "700 x 35C"
Trek - 17.5"
WTU265C4056D is the serial number
Any thoughts on where I can find this? I can replace tubes and tires but I'm not sure where to look for this wheel.
Thanks.
Trek - 17.5"
Thanks.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Using any spoke from the same side of the flange that passes the same way through the flange (inward or outward) as an example how, thread the replacement spoke from the flange through its neighbors to the rim. Lightly lubricate the spoke threads and insert the nipple and tighten a few turns. Do the same with the example spoke that you had removed.
Place the wheel back in your fork. Invert the bike or suspend it from a bike stand or shade tree. Using the pitch of the similar spokes (the ones going in the same direction from the hub as the ones that you re-installed), begin to tighten the replacement nipples until the "ping" sound from plucking or striking the old versus new is pretty close. Like tuning a guitar.
Now, spin the rim and note where it passes through the brake pads. How far off is the side-to-side wobble? How about radially? Now all you must do is "true" the rim using spoke tightness in the affected areas. Watch a few YouTube videos on rim truing. It's really not difficult at all. You'll be looking to get less than 0.5mm variation in any dimension as the rim passes.
Tools needed: spoke wrench that fits your size spoke nipples, tire levers to remove tire, pump to re-inflate tube, light oil for the spoke threads.
Time to repair: aside from going and getting the spoke, and videos on truing, the total time might be about 30 minutes.
Good luck.
Thanks!
That sounds very detailed and complicated. Isn't it easier to just get a new wheel? I don't think I can do all that. And the rim is bent so that seems like id need work to do. I was thinking I can order a wheel, add a tube, put the tire on and put it on and off I go. This bike just gets me to the grocery store. I'm not a serious biker.
LP
LP
Likes For lespool:
Quoted: 1819 Post(s)
Liked 1,693 Times
Thanks!
LP
LP
Likes For alcjphil:
Quoted: 6193 Post(s)
Liked 4,809 Times
I wouldn't expect one spoke breaking to have caused the wheel to warp enough to be an issue. It is possible though. So likely the entire wheel needs to have all it's spokes checked for proper tension.
Most bike shops that have a wheel person do that for minimal cost. And if they have the proper spoke in stock it won't be too much additional for them to replace it.
Though it is possible that whatever broke your spoke also bent or damaged the wheel rim to the point it shouldn't be fixed. So eyes on the rim will be better than us hoping for a best case outcome.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Then take the whole wheel to a bike shop and let them replace the spoke. If the rim is too warped to salvage, they'll let you know. But replacing a single spoke and truing/tensioning the wheel is likely to be more cost effective than replacing the entire wheel.
Quoted: 1364 Post(s)
Liked 1,677 Times
It has happened to me on both my 26" and 700c bikes. On the other hand I have finished rides and found a spoke hanging or missing without any wheel warping.
So is it not easy to just use the information I provided and find a new wheel online? I have heard they are difficult to pinpoint the right size. I am simply going with ease. To me, I can put a new wheel on easier than doing spoke repair myself and from what I remember when this happened in the past, it isn't that cheap to get repair in the BALTIMORE MD area.
Quoted: 2975 Post(s)
Liked 1,181 Times
Buying a new wheel is more expensive than having someone at a local bike shop replace a broken spoke and straightening the wheel for you.
Why is this so difficult to understand?
It's easy to understand. Google told me wheels are about under $100. But then again I'm asking for more specifics on what wheel would fit. I've had spokes replaced multiple times in the past and the cost and the enormous wait for repair is brutal. It's not a $10 fix at a bike shop.
If you still want that option, look for a 700c quick release front wheel that's compatible with rim brakes.
I'd vote for getting the wheel repaired as matching wheels are preferred. The only time I had it done, a spoke repair cost me $30. I learned to do it myself after that.
Liked 1,181 Times
Are you really that obtuse?
Zip tie Karen
Liked 1,542 Times
Thanks!
LP
LP
Alternatively, let a bike shop repair your wheel. Replacing a wheel is a bad choice unless and until you have verified that it cannot be fixed simply. In terms of cost analysis, and using "pulled out of thin air" numbers:
- home repair = Tools $20, Materials = $3
- shop repair = $45
- buy wheel = $125
You don't have to have an MBA to identify both the most economical and the most instructive route.
Zip tie Karen
Liked 1,542 Times
Another thought...where do you live, and is there a bicycle cooperative in your area? They could supply the tools and supervise your self-repair. Best of both worlds, and the cost would be even less.
Quoted: 883 Post(s)
Liked 823 Times
Amazon has 700c wheels for as low as $50, and although not of great quality, probably adequate and as inexpensive as having a shop repair your wheel. It's a front wheel so in all probability 100mm (about 4") width. Check the distance between the dropouts before ordering.
Liked 4,809 Times
I don't know why I'd need confirmation of that.
Quoted: 6963 Post(s)
Liked 10,963 Times
Yep. And if the wheel does need to be replaced, they will be able to get you a new one.
Liked 4,809 Times
You need to consider the axle type, the drop out or fork end spacing it's made for, Shimano and other refer to that as O.L.D. (over locknut dimension). What the internal and sometime external rim width is that might matter. What type brakes you have, rim or disc, if disc which type of mount. If rear wheel then what type of cassette, freewheel or if your bike is IGH.
So if you want a wheel then you have to get real specific about what you currently have and might wish for in the future.
A bike shop can help you with that stuff too. They've found decent wheels for inexpensive prices on my son's bike that he tore up.
Liked 1,677 Times
Perhaps it was a case of "Hits [ENTER] b4 thinking", or just "60+ yo (sigh) Love to argue."
Likes For BobbyG:
