Adding granny gear
Adding granny gear
Is there some clever gadget out there that allows adding a granny gear to a 2 sprocket crank, or am I looking at replacing the crank with a triple? Thanks!
I'm slow, go around
I'm slow, go around
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
What you need is a tripleizer. Replaces inner chainring with one that is drilled to accept a granny.
Available in many common BCD’s.
Yes, likely requires a triple FD and a 5mm wider bottom bracket.
Likes For rccardr:
Brilliant! I knew there was a gadget to make this work! Thanks
I'm slow, go around
I'm slow, go around
Quoted: 2494 Post(s)
Liked 738 Times
If your bike is a presently a double, then it was designed for that purpose only. The front derailleur cage of a double is shaped quite differently from that of a triple, the 'middle ring' won't have ramps or pins, but it will all likely at least work. These innovations did not always exist. Cheap thumbie type friction shifters won't have too much difficulty adapting to a triple, but fancier stuff might. If only because there won't be any labeling for the new gear. OCD is a *itch. So, as you say, you will find out.
Quoted: 6193 Post(s)
Liked 4,808 Times
Seems like buying a 3x crank would be cheaper than a tripleizer. Chain line will probably be more correct too assuming the bikes not out of whack already in that department.
Well besides the shifters being rather pricey bar enders (), I actually prefer old school tech for this touring bike. I just can't get up the hills all loaded like I used to!
aka: Dr. Cannondale
Liked 3,404 Times
Bar ends will shift a triple just fine.
A tripleizer is less expensive than a triple crankset these days.
Either way you’ll need a wider bottom bracket and a FD capable of shifting a triple.
Some additional information on your present crankset would help
Quoted: 4201 Post(s)
Liked 3,857 Times
The issue with a middle ring made to mount a granny to is when that ring is worn out the replacement costs more (if it is still made years later). A proper triple crank will end up costing less over the years IMO and have far easier to find replacements.
As to what type of crankset a ft der is made for- thousands of riders have done fine with their "double specific" ft ders from when that spec wasn't a reference. I think what is driving the assumption of specific double or triple ft ders is 1- the marketing of "better/faster" **** that we have gobbled up for decades, and 2- the lack of most current riders not learning how to make their bikes shift best. But this boarders on other rants Andy
AndrewRStewart
AndrewRStewart
Liked 4,808 Times
A new Shimano 3x crankset can be had for 32 - 38 bucks.
https://www.universalcycles.com/shop...s.php?id=46763
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 912 Times
I didn't need a new front derailleur with my Red Clover triplizer - my old Suntour Cyclone FD works well. Nor did I need a new bottom bracket - I had enough clearance with my old Phil Wood. Others will say that your chain will rub, but mine didn't. If you like your present crankset, a triplizer might be a good solution.
Well, after going down the rabbit hole of possible options I'm back to square one. The tripleizers are unobtainium, at least in 110 bcd. I went to order a Sora triple fc-r3030-3 in 165mm and they're all sold out. I need some help with options.
I currently have an older Sora 2X 165mm, 110bcd, currently with a 34 on the inside. I don't want to replace the Hollowtech bottom bracket (fairly new BB-RS500 BC1.37x24 road) with a square taper. I'd be happy with a 2x mountain bike crankset that let's me put a 30 or smaller cog on the inside. I'd rather not spend a ton of money but... So, what MB crankset would fit? Are Hollowtech BB's all the same inside diameter? Thanks!
Aaron
Aaron
I'm slow, go around
I'm slow, go around
Liked 4,808 Times
Your big issue with just swapping the small ring for a smaller ring is that you'll probably be well out of your rear DR specs with any significantly smaller ring.
You'll have to sacrifice your top end by also going to a smaller big ring. But smaller on the top isn't really as bad as it may seem. How often are you truly putting out max power in the big ring and small rear? Might mean someone beats you to the bottom of the hill, but over the entire ride it probably won't make your times much different.
Knowing what kind of riding you do, your experience and fitness along with what your desires are might let someone help you figure out where to compromise.
I have an 11-36 10-speed cassette, and small ring up front is a 34. By my calculations, dropping the front ring to a 26 is a 6" gear inch drop. A 24 would be even better.
I'm slow, go around
I'm slow, go around
