Is this a safe way to add water bottle mounts?
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,391 Times
My two TiCycles ti frames have three sets each of bottle mount rivnuts. 2008 and 2011. Haven't had a single issue and the bottom, under the DT cage goes on and off for hot and long rides. The Dremel hasn't seen either bike. (I have heard framebuilders say that drilling WB holes is one of the more challenging fits because error is so obvious. I'm guessing most make jigs early on just for this.)
If I had to do this to a frame, I'd add a bit of epoxy to help reinforce the mechanical clamping of the rivnut and its serrations. Cheap insurance.
-Kurt
Quoted: 4805 Post(s)
Liked 3,927 Times
It's really simple. You are supposed to be drinking at the bar or riding your bike, but not both at the same time. (Says he who hasn't had a HB mount cage in a very long time. Not since my pump came off the DT.)
Likes For 79pmooney:
Liked 3,927 Times
I meant in regards to anyone doing it RJ style - home-brewed. However, I have heard of some cases of loose, factory-installed rivnuts, and - come to think of it - my Birdy BD-1 was one of them. It had a rivnut for a chain keeper that had been ripped off, causing the rivnut to spin around in the frame.
-Kurt
-Kurt
Liked 4,391 Times
You know. with care, I bet virtually all loose rivnuts could be epoxied and used a long time. Getting the area clean would be a challenge. I'd start a screw after epoxying and also set a thin layer of the mixed epoxy aside so I could seen when it is almost set up hard, then back the screw out at that time. (Prepping the screw threads with wax or soap would be smart.) I would go with JB Weld or Marine Tex. Maybe pretty up the job with a little liquid boat building epoxy and an artist's brush after. (Used to build boats. For some kids it's the sand box. For me it's the gooey stuff.)
I dare say the diameter probably matters less than the completeness of the crush between the tubes. That's probably why some of them fail too; the rivet may only crush against the lower crown/curvature of the tube.
-Kurt
There are certainly plenty of bikes I wouldn't drill, but I did add rivnuts to my Grand Sport several years ago, and no problems. I had a chunk of tubing from a trashed frame, so I practiced on that first to get a feel for the crimping.
As far as alignment goes, a simple jig can be made by drilling guide holes in the corner of a piece of angle iron, and clamping that to the bike.
Liked 3,927 Times
I have and use both the Zephal and Minoura WB mounts with clean SS straps and no fastener on the backside. Both do have black plastic mounts that raise the cage considerably. Pluses - they work well. Put electrical tape on the straps, trim with a sharp box knife and they leave no marks at all. And for seattubes on close racing bikes, nothing sticks back to touch the rear tire.
https://www.modernbike.com/minoura-b...m-black-silver
The Zephal one I have isn't shown on their website so it may be discontinued. There are several other solutions there.
Quoted: 964 Post(s)
Liked 1,628 Times
My solution was to drill holes and forcefully thread in two long M5 bolts. I then silver soldered them in place and cut them down to use nuts in securing my water bottle cage... Talk about a HACK... Ha
None of my Franken Bikes are "Wall Hangers"... But they are ridden and PROVEN...
As Quoted by one of our tribe: "Steel Is Real", I would not do this on anything but a steel bike.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
before I knew such a thing as "rivnuts" existed, I decided an old French frame just HAD to include waterbottle mounts, and also chanced upon a basket-case trashed Mtn. Bke frame discarded on the street.
So...with more confidence than sense I cut out the MTB factory mounts, shaped the remaining frame tubing into "diamonds", then drilled the frame tubes in French frame and brazed them on.
It turned out so nicely I was sure I was a natural for brazing and soon discovered the truth: NOT a natural, just had some unnatural good luck, like beginners do.
So, kids, don't try this approach at home!
I would also be a little leery of rivnuts, have had mixed results with them. So maybe do a practice run on a trashed MTB frame, or a piece of one.
Friendship is Magic
Bikes: old ones
Quoted: 26410 Post(s)
Liked 10,376 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
These? They look butt ugly to me. Not something I'd care to install on a nice vintage bike. Surely vintage bottle cage clamps are available in decent supply, yes?
Likes For 52telecaster:
Quoted: 1639 Post(s)
Liked 829 Times
I think one leg of the clamp legs is actually hinged at the mount body....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3885 Post(s)
Liked 6,479 Times
There's an easy solution for most of that; you have to file/sand the edges. You can paint the underside with clear nail polish. I also use tape when mounting them, not under the clamp, but to hold them in place while securing the clamp bolts. My '72 Torpado with the VO Retro cage:
Likes For SurferRosa:
Quoted: 413 Post(s)
Liked 109 Times
I’ve done many, many frames with rivnuts. Would do them with epoxy.
Loose rivnuts? Smear epoxy in there and re-crimp them
Likes For miamijim:
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Beautiful PX-10, by the way.
Quoted: 3505 Post(s)
Liked 2,924 Times
Likes For tacreamer:
Liked 4,391 Times
I yearn for a day when someone manages to bring to market a version of this with a steel core and tightening system.
I've yet to see any of these plastic hose clamp designs that don't eventually slip or strip.
-Kurt
-Kurt
Likes For cudak888:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
They just don't have a vintage look to them either IMHO.
