Frame/fork weights & dimensions - any interest?
Bikes: many
Quoted: 1442 Post(s)
Liked 1,388 Times
A recent weight weenie thread on Classic Rendezvous and my experience dunking three different frames in oxalic acid over the past week got me thinking it might be interesting to weigh and measure bare frames and forks. To that end, I created a simple spreadsheet which y'all can edit:
https://docs.google.com/spreadsheets...it?usp=sharing
Note the yellow section before entering any values. The idea is that you measure and weigh your bare frame and fork. (I cheated with my Conti, as I decided not to dunk its fork, so didn't remove the crown race. I didn't clean out the inside of the Atala's frame because I knew I had added Frame Saver once upon a time.) I didn't bother measuring the chainstays and seatstays, figuring they wouldn't add much variability to column I, the ratio of frame weight to "perimeter" length. I will add more of my frames as the opportunity presents itself. If you are so inclined, feel free to enter figures you have for your frames.
Likes For smontanaro:
Quoted: 4510 Post(s)
Liked 6,374 Times
I weigh many of the bikes and frames I acquire, can't seem to weigh them before AND after I strip them, kind of like before AND after pics, can't seem to get them done either most of the time.
One thing I highly suspect is that some of our favorite delusions of grandeur are dashed by the truth of the scale, many truly iconic and thought to be light "just because" of their lofty place in cycling, many are, many aren't. Many of the one's that are, are not by very much and some are far heavier than we would ever imagine.
Not sure where my big list is right now, started a new one that only has a few and any of the completes are apples and oranges so....
Quoted: 1607 Post(s)
Liked 2,214 Times
I started with dimensions as I have already stripped the bikes down so don't have measurements for all of them. My column headers include:
Year,
Frame - Decal
HT angle
HT
Steerer length
Fork DO
Fork Spacing - duh, 100mm
Rake
Trail
TT
DT
ST
ST Angle
BB
BB drop
Rear DO
Rear Spacing
CS
SS
Rear brake bridge to Axle location at intersection of stays
Pinch Bolt
Linear Brake Bolt to DO
WB - wheel base
Sit to crank - approximate location of sit bone location on the saddle
Sit 2 CL of HB - Center of the HB or stem mount CL
Sit 2 crank KOP - I really need to think this through with the wide variation
The last three are an effort to record and duplicate saddle and HB locations. The dimensions ay also reflect comfort.
I don't have information on several columns yet, i.e. BB drop, rake, and trail.
Year,
Frame - Decal
HT angle
HT
Steerer length
Fork DO
Rake
Trail
TT
DT
ST
ST Angle
BB
BB drop
Rear DO
Rear Spacing
CS
SS
Pinch Bolt
WB - wheel base
Bikes: many
Liked 1,388 Times
Thanks, done. Note that I allowed anyone to edit the spreadsheet. That means adding columns as well as rows is allowed.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 344 Post(s)
Liked 266 Times
If we have weights and frame dimension and material will that be enough or would you really prefer to have top tube length, etc?
Quoted: 344 Post(s)
Liked 266 Times
True. To clarify, if all we have is frameset weight, material and seat tube height do you want us to still participate in the charting? I have those measurements for several older frames I no longer have and for which other dimensional info is impossible to obtain.
Bikes: many
Liked 1,388 Times
Enter whatever you have at hand. I'll adjust the formula for column I (g/cm) to leave the cell empty if any lengths or weights are missing.
Quoted: 3464 Post(s)
Liked 2,827 Times
Likes For repechage:
Bikes: many
Liked 1,388 Times
Someone named Mackers entered data for something called a "Duell Attack" which has a rather implausibly long head tube (93cm). Could you maybe re-measure and correct that?
Quoted: 1105 Post(s)
Liked 1,326 Times
Bikes: many
Liked 1,388 Times
Thanks.
Just so everyone is on the same page, keeping the units to cm for length and gm for weight(or mass) simplifies any derivative calculations (such as columns I and J).
