Parts cleaners and cleaning formulas?
Quoted: 1856 Post(s)
Liked 664 Times
I bought a small parts cleaning ultrasonic cleaner, and I now have a load of dirty parts to process. What cleaning fluids or solvents are safe and effective and can be poured down the drain? Lots of 50 year old, caked grease on these ol’ bits!
Quoted: 3810 Post(s)
Liked 6,693 Times
I'm a fan of Incredible Pink.
Quoted: 3015 Post(s)
Liked 3,802 Times
I use a brush, mostly brass, but also steel and nylon bristles, along with Simple Green to remove the bulk of filth. Then just Dawn and water in the ultrasonic cleaner to finish the job.
Quoted: 1106 Post(s)
Liked 1,328 Times
I put the parts in a ziploc bag with whatever solvent I'm using, then hang the bag in the cleaner filled with water; saves on solvent and mess. My cleaner is years old and has only ever had water (directly) in it.
Quoted: 4511 Post(s)
Liked 6,378 Times
This is a Pro tip/commercial trick, many use to keep the tank from getting nasty and it controls the cost factor greatly.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I must say that mineral spirits have done the best job of cleaning grease off of parts for me. With it, you can minimize what you pour down the drain by just saving the "dirty" mineral spirits in a jar and letting the crud settle out. Then, you can reuse it many times by just decanting the clean-ish mineral spirits off the top. Come to think of it, I've never actually poured dirty mineral spirits down the drain!
Liked 1,328 Times
That's a good idea; I'm going to start looking for a plastic jar that'll not dissolve. One thing I also do sometimes is hang the parts in a smaller mesh bag I made from window screening, the dirt collects in the bottom of the larger bag and the clean parts are held above it. A jar will work better, a round screen that sits in the bottom will do the same.
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 82 Post(s)
Liked 141 Times
I am a glutton for punishment with grimy old projects--this is what I can recommend:
+1 to mineral spirits, great for bearing cages and other small parts with greasy little nooks and crannies. And +1 to small brushes, obviously. A must. Cotton swabs are great too.
--Hot water and Dawn dish soap usually gets me at least 70% of the way there on a project. Gotta be careful with stickers/decals though.
--I only recently discovered the joys of Evaporust. A truly "works as advertised" product. Although similar to the issues with ultrasonic cleaners, sometimes it helps to make sure there aren't any layers of grime on the part.
--Even though I'm sold on Evaporust, I still frequently use the old water/Barkeeper's Friend paste standby. It's a great rust remover and cleaner in general.
--And finally, I kinda feel that with all the products and methods out there, WD-40 has become overlooked in the cleaning game. It works great.
Likes For PugRider:
Quoted: 566 Post(s)
Liked 1,048 Times
The only other chemical I would add is acetone to clean the braking surface on a rim.
Likes For RustyJames:
Quoted: 569 Post(s)
Liked 581 Times
Two of my fails with my industrial cleaner:
From the Simple Green web site on Aluminum and they are correct: Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. So I now use Dawn. I use large glass beakers as they are super easy to clean the goop out but pad the bottom or keep anodized surfaces off the bottom (RD with wheels down) as anodized surface will get rubbed out in the vibration with the glass.
my name is Jim
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
You and I are kindred spirits (not punning on the mineral spirits) in our processes since I would have made exactly the same recommendations. I too am a huge fan of WD-40 as a cleaner.
If you need aerosol (which you really don’t), Finish Line Speed Degreaser contains all the good stuff without the added oil.
Stuart Black
Stuart Black
Quoted: 566 Post(s)
Liked 1,048 Times
The problem with WD-40 as a “cleaner” is the 25% mineral oil that is added as a lubricant. The 75% mineral spirits in the mixture works well but only if you want to deal with the oily residue. It’s better to just use mineral spirits. Cheaper too.
Drivetrains need to be cleaned not degreased.
Dish soap + water for frame and wheels only.
I clean my main bike and commuter weekly and at most, regular WD40 + a cloth is enough for drivetrain.
Why people insist on using water and degreasers to strip grease/lube from bare metal is beyind me. You're not painting the bits, just re-lubing / re-greasing them. Unless of course you're a waxxer, in which case a kettle is what you need.
Ultrasonic cleaner + petrol or kerosene for chainset if cleaning industrial quantities, or for a bike shop.
Liked 4,218 Times
It’s less about removing “grease” than removing oil which is basically thin “grease”. Of course if you don’t use oil, you don’t have to remove it. As an added bonus, you don’t have have to clean the drivetrain all that much. My drivetrains never need degreasing or even cleaning. I’m not a hot waxer but I do use solvent wax lubricant and never need to “remove” it.
Or car wash.
Again, if you don’t use something that traps dirt, you won’t need to clean. Frankly, you clean about 52 times per year more than I do. This is my drivetrain about 800 miles into a 1500 mile tour. This is typical of my drivetrains even without being on tour.
My chain, cassette, and chainrings last as long as others report with a minimum of cleaning.
Stuart Black
Stuart Black
I would be afraid of using petrol (gasoline) -- do you really do that? Kerosene has a lower flash point, I think but is smelly. I used to use that many years ago but switched to paint thinner (mineral spirits). Probably even that caused me brain damage back in the day. None that I can see now, though.
Only petrol, no need for a flame thrower on this job, lol.
Fumes from like 500ml of petrol in an open space igniting? Not even Bear Grylls can make that fire.
What will set the petrol on fire, will set acetone, mineral spirits or alcohol on fire too. If that's a concern for people (clumsy or whatever) stick to water based degreasers, don't risk it, bike maintenance is not that important, lol.
I clean my bikes outside and don't have any sniffing habits heh.
Quoted: 569 Post(s)
Liked 581 Times
While you are correct a caution to readers, the ignition temperature of gasoline is super high, something like 500ºF, what often gets people in trouble is not only an open flame but even a small spark which will ignite gasoline vapors at any temperature.
Quoted: 1607 Post(s)
Liked 2,216 Times
,,,,,,with the right air/fuel ratio.
Liked 2,568 Times
Likes For ThermionicScott:
Liked 4,218 Times
Gasoline has a flash point of -50°F (-45°C). That means it is easy to ignite and requires very little energy to do so.
Theaccidentalinitiationofcombustionbymeansofcontactofgaseousmaterialwithanexternalhigh-energysource,suchasaflame,spark,electricalarc,orglowingwire.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1949 Post(s)
Liked 2,010 Times
I'm a kerosene user and never thought of using mineral spirits. These days in CA, mineral spirits are precious but I might try some of my stash on a special rebuild. For those that no longer have access to "Mineral Spirits", does the imposter and readily available "Paint Thinner" work as well.
Quoted: 569 Post(s)
Liked 581 Times
I think I see better performance for basic parts cleaning by OMS than any thinner I have tried. Thinners I understand are less refined so have other solvents which while stinky and likely more volatile don't help with what I am looking for in OMS.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Citrikleen. An industrial-strength citrus-based water-soluble degreaser. Highly concentrated, you mix a few ounces of it in bucket of water. Very safe to use, but very aggressive...it'll leech the oils out of your skin. I've never used it on bike parts, but I've used it on really grungy old car parts...just throw the parts in the bucket and let it soak overnight. You have to be sure and spray the parts with WD40 after removing them from the solution and rinsing, because they'll otherwise start to rust almost immediately...that's how aggressive the stuff is.
https://www.penetone.com/citrikleen-product-line
