Max Tire Pressure Label (700 x 32)
Old 12-31-19, 11:03 AM
  #101
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Originally Posted by noodle soup
This chart is a little whacked. I just looked at the sidewall of a 30mm Schwalbe G-One Speed, and it clearly says 50-80 PSI is recommended inflation
The sidewall is supposed to indicate the safety margin for the construction of the tire itself, not specifying the ideal inflation from a performance perspective which of course depends on rider weight and road conditions. Schwalbe calls their chart a 'very general guide'
Sy Reene is offline
Likes For Sy Reene:
  #102
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
Originally Posted by Cypress
Math. A 23mm tire will "open up" to 26mm on a wide rim. Larger diameter tire plus larger rim chamber = significantly more volume than you would think. If we treat the tire like a perfect cylinder and forget the added volume of the rim chamber (which adds to the percentage), the tire alone sees a 28% increase in volume.
23mm tire in a perfect cylinder: (2097mm ((pi)((11.5)^2))) 871,252 ml
26mm now because of the wide rim: (2110mm ((pi)((13)^2))) = 1,120,261 ml
Lol.
Doh, indeed. You're not understanding the law, nor the application in this thread...again.
And on a wide rim with more V O L U M E that a narrow rim, it is unequivocal, indisputable, and absolute proof. But again, you seem to be missing that point completely....still.
Oh, so now you agree that a tire with a bigger volume due to having a wider rim needs less pressure. Great. Moving on.
You remind me of my ex. She would always put words and feelings in my mouth as well. Are you my ex?
...or are you just an elaborate troll, and I keep taking the bait?
Methinks your name is a misnomer.
Me thinks you are the one throwing around basic formulae and charts to appear knowledgeable, and me thinks you are the one putting words and movies in MY mouth, while adding insult after insult.
As I said before no one ever questioned the the basic premise that fatter tyres "require" less pressure, only not that much less. I wasnt the only one mentioning it, but apparently you are such a hot heat you didnt even notice.
Moving on .. Bye!
Racing Dan is offline
Old 12-31-19, 11:07 AM
  #103
Cypress
Globo Gym lifetime member
Cypress's Avatar
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times in 306 Posts
Moving on .. Bye!
See above.
Cypress is offline
Old 12-31-19, 11:19 AM
  #104
Cypress
Cypress's Avatar
Bikes: Fast ones
Quoted: 410 Post(s)
So for a 30mm tire, that actually measures 31.54mm on a 23mm inner width hoop? I weigh 185#
Diameter of 31.54mm gives a cylinder volume of 1679777 ml
The Schwalbe chart sort of implies a 30mm tire to be run at 90 psi, so I used that. Your 31.54mm width would only need a pressure of 81.27 psi to be comparable to the 30mm at 90 psi.
Cypress is offline
Old 12-31-19, 11:54 AM
  #105
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
yeah, I understand what the sidewall recommendation is for, but using the chart provided would put me over the max inflation if I put on a little weight.
noodle soup is offline
Old 12-31-19, 12:21 PM
  #106
xroadcharlie
Bikes: 2018 Giant Sedona
Quoted: 183 Post(s)
Liked 116 Times in 95 Posts
Regardless of what any chart says or the advice of a bike shop tech I would not recommend going more than 10% over or under the tires printed pressure range.
In fact we can use this range to help determine the correct tire pressure for our needs as it includes many variables such as tire casing suppleness, tread compound (for traction), ect.
The heavier you are and more aggressive you ride, the higher up in the range you should use. There is a range of preasures that will likely work well. I start with my best estimate taking into account the pressure range on the tire, the results from a 15% drop based calculator, and riding conditions. Then go from there.
xroadcharlie is offline
Old 12-31-19, 12:30 PM
  #107
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
So, I'm not sure where any of this discussion leaves us.. We have an OP who weighs 190, but with 32mm tires that indicate max of 70psi. We have HED who'd recommend 55-60psi. We have Schwalbe chart who'd generally recommend somewhere around 85psi, and Cypress's calculations around 80psi. Tire inflation calculators seem to indicate a rear inflation somewhere in the 70s. Someone quoted Hunt wheels max of 50psi for 33mm. These don't seem like small disparities.
Sy Reene is offline
Old 12-31-19, 01:06 PM
  #108
Cypress
Cypress's Avatar
Bikes: Fast ones
Quoted: 410 Post(s)
It's a right mess.
I treated it like ammunition loading: Start safe (higher psi) and work your way to whatever pressure "does best" for your uses.
Cypress is offline
Old 12-31-19, 01:16 PM
  #109
bbbean
bbbean's Avatar
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times in 249 Posts
It's a right mess.
That's a good analogy. There is a lot of "what works best for my application" involved in both. Throw in the fact that current research is changing the way we approach tires/wheels/psi/aero, and you have are trying to hit a moving target.
Ultimately, "find what works best for you" is rarely wrong.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
bbbean is offline
Likes For bbbean:
Old 12-31-19, 04:07 PM
  #110
xroadcharlie
Quoted: 183 Post(s)
I do find it interesting that some tests results show that lower tire pressure then some use as a baseline actually improves speed. I know when I run my 50 mm tires at low (30 - 35 psi) pressure my assumption has always been I should go noticeably faster by increasing it to 40 - 50 psi. Yet when I ride at the higher pressures I can honestly say there is little difference in speed. Mind you I don't do controlled tests, But I was still hoping to feel some improvement. All it did was make my ride uncomfortable. Because the ride is stiffer, I end up having to go slower anyways.
Next season I'm going to keep the tires at the lower end of my range. Kenda recommends 40 - 65 psi. So I think I'll try 35 front and 40 psi rear next time. out. I try to stay within about 10% of what Kenda recommends. These are inexpensive tires, So it comes as no surprise that they are not the most comfortable or fast. But for recreational riders like myself at the lower pressure they make a very good, Dependable tire overall. I will definitely be moving to a better tire next time. One with a semi-slick tread and more supple sidewalls.
Old 01-03-20, 10:16 AM
  #111
Cypress
Cypress's Avatar
Bikes: Fast ones
Quoted: 410 Post(s)
1:25 in this video shows the GCN crew running 75 psi in their 25c GP4KS tires. *edit* presenter weighs 161 pounds
Cypress is offline
Old 01-03-20, 11:13 AM
  #112
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
https://www.youtube.com/watch?v=t0hKMgUEku4
Sounds about right (at least for the rear wheel).. 45/55 distribution for descending position (more weight on pedals). Wide rims with notorious GP4Ks wider-than-nominal inflation widths. Added 20lbs for his clothing, water bottle and bike. Perhaps he even took a little air out given intent to bomb down a wet roadway -- ie. for a bit more grip?
Sy Reene is offline
Likes For Sy Reene:
Old 01-03-20, 11:38 AM
  #113
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Really useful info from Josh Poertner here:
Some takeaways:
- the max pressure printed on the tire is simply half the tested blow-out pressure (by law).
- the max pressure spec is almost always too high for optimum rolling resistance.
- smooth looking pavement varies a lot in actual smoothness (Poertner analyzes race course pavement for pros to determine optimal pressure).
- wealthy neighborhoods usually have finer, smoother pavement.
- optimal pressure (for rolling resistance) is almost always lower than you would determine by subjective riding feel - optimal pressure feels subjectively slower!
- generally speaking aero considerations trump rolling resistance in road racing.
tyrion is offline
Old 01-03-20, 12:32 PM
  #114
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
https://www.youtube.com/watch?v=asEYkpW0vwQ
Some takeaways:
Very interesting.. led me to search Silca's site.. you might find of interest this general white paper. Salient details from this testing was 190lb rider+bike on TT rig to help ensure a close to 50/50 weight distribution on the tires. 25mm GP4Ks
https://blog.silca.cc/part-4b-rollin...-and-impedance
Sy Reene is offline
Likes For Sy Reene:
Old 01-03-20, 09:56 PM
  #115
Gconan
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times in 90 Posts
Gconan is offline
Likes For Gconan:
Old 01-06-20, 11:36 AM
  #116
noodle soup
Originally Posted by Metallifan33
Interesting. Thanks guys... I didn't realize how much individual preference/variation there is when it comes to tire pressure. I'll start dropping it from 70 and see how it feels.
Have you figured out what tire pressure works well for you?
Old 01-06-20, 12:01 PM
  #117
Metallifan33
Metallifan33's Avatar
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times in 48 Posts
For now, yes. This thread has been extremely enlightening. I found it interesting (from the YouTube video) that the max labeled pressure is around 1/2 the value at which the tire had structural failure (in lab conditions). What's interesting here is this may be more of an issue with wider tires than narrow. For example, a normal road tire may be at 100 to 110 psi (but the degrade point may be 220 or so)... well, you'd never inflate to close to that. But for a 30+ tire, the max being 70 and structural failure at (in the lab) being around 140... well, the 100 psi that the LBS set for me is closer to that (again lab conditions differ from actual road conditions... which could be worse). Further complicating the matter is the recent rise in popularity of wider road bike tires.
Regardless, I learned that its highly subjective and a personal style depending on the road conditions etc. (being an ardent Formula 1 racing fan, I can appreciate the complexities of tire behavior).
I started at 65/70 and dialed it down to 60/65... I'll keep it here for now till I settle in (only 50 miles ridden so far). I also prefer only changing one thing at a time (and currently haven't settled on a saddle yet).
Thanks again for all the comments!
Metallifan33 is offline
Likes For Metallifan33:
Old 01-06-20, 12:16 PM
  #118
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times in 440 Posts
Current trend is wider tires at lower pressure! Research suggest they give better performance.
Nonetheless, just run the desired pressure that makes you comfortable and that you prefer. You can go a little below of above the recommended one - it's just numbers
eduskator is offline
Likes For eduskator:
Old 01-06-20, 05:49 PM
  #119
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Please realize that this 2x sidewall pressure thing is speaking ONLY about the tire. There are numerous rim makers that would give you much lower values as safe with their rims. The lab testing I think referenced using a steel walled rim, that is bound to be able to withstand anything (more or less) thrown at it. Not sure also what width rim they use for given sized tire.
Sy Reene is offline
Old 01-18-20, 02:00 PM
  #120
Fendertele
Fendertele's Avatar
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times in 28 Posts
Hello All,
I have a quick question about tire pressure for my road bike (Trek Domane SL 5). The tire is the Bontrager R1 700 x 32 Hard-Case Lite.
If I remember correctly, the LBS inflated it to 90 and 95 psi (front and back). I weigh 190 lbs and live at 1200 ft MSL and the temperature is currently 60 deg F.
I went to air it up today and noticed that the tire is labeled with a "Max Air Pressure of 70 psi."
What should I air it up to?
Thanks!
Interesting thread. I suspect your bike is a 2020? My SL5 is a (2019) with same tires. The tread is different and inflation labels differ significantly. Makes me wonder how much of the difference is relative to tire engineering vs market trend. Embarrassed to post these pics after seeing how clean your bike is.
Fendertele is offline
Old 01-18-20, 04:32 PM
  #121
Metallifan33
Quoted: 218 Post(s)
Yeah, it's interesting for sure. I looked up the tire on the Trek website, and the max pressure they show now is 50 psi! You can see how this would thoroughly cornfuse a noob.
https://www.trekbikes.com/us/en_US/e...-tire/p/25927/
My bike is the 2020 version btw.
Old 10-21-21, 05:16 PM
  #122
wallace1973
Hi I realize this thread is a year or two old but I tripped over it whilst Googling.
I have the same bike (Domane DL 5 Disc) and tires (Bontrager R1 700x32 / Hard-Case Lite) as the original poster. I got the new bike a few days ago, ready to take it out for a spin I pumped the pressures up to what I have been used to with my older (thinner rim/tire) bike - 95 to 100 psi range.
I then wondered why the bike shop have given me the bike with lower pressures (seemingly 50-60 psi or so) - then I checked and noticed the "max 70 PSI" warning on the outer tire.
I immediately deflated and reinflated to around 65 PSI.
I did no riding on the tires - is there a chance I did any damage to the tire or rim by pumping temporarily to 95/100 PSI for a few minutes before deflating again? From what I've been reading here *seems* not but just checking!
P.S. I weigh 195lbs and the bike is around 22lbs so guessing 217 ish lbs combined rider + bike weight. From what I can gather it's a question of picking a starting point and adjusting to your own comfort levels from there. I am will be exclusively road riding - no gravel.
wallace1973 is offline
Old 10-21-21, 07:11 PM
  #123
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Nah, don't worry about it. Ride and be happy.
WhyFi is offline
Old 10-22-21, 12:20 AM
  #124
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
No chance you damaged anything. None. Zero.
As for starting pressure using your bike+rider weight and estimating the speed as a moderate group ride on a worn tarmac surface (some cracks), start out at 62psi (4.3bar) R and 60.5 (4.2bar) F, and adjust up or down based on feel. https://silca.cc/pages/sppc-form
Just for reference, I have a bike that rolls on tires measuring 35mm when inflated, tubeless, and the recommended pressures are about 55psi (3.7bar) and I routinely run them below 50psi (3.2-3.3bar) with no issues.
Badger6 is offline
Old 10-25-21, 10:30 AM
  #125
wallace1973
Hi great, thanks for the reply and advice, and also to WhyFi. Yeah these have tubes, and tbh although my rims are tubeless ready I am unsure if I will go to tubeless tires, so for now going to assume I am sticking with tubes.
I'll take a look at those starting pressures and see how I go. Since my intention is to lose some weight guess I should periodically review the pressures as my weight comes down.
