Any suggestions for a small simple hand pump?
I have a Surly CC and need a mini pump for longer rides, but the popular ones I've seen mentioned (like the Topeak Morph pump) wouldn't fit the simple look I'm going for. I understand the basic premise of function over style so no need to waste your time giving me a lecture on it, I'm just curious if anyone has any recommendations. I would post a picture of the bike, but I believe I'm still under the 10 post rule as I really just lurk here thanks for any recommendations!
EDIT: hit the 10 post mark so here's a pic of the ride
Likes For John Bramson:
Quoted: 6192 Post(s)
Liked 4,807 Times
You can still upload a pic to your user gallery and then tell us it's there. Or just write the URL to it in your message and then remove the https:// and put a blank space on both side of the . (dot).
Mini pump as in one for just topping off those 32mm or bigger tires?
climber has-been
Quoted: 3427 Post(s)
Liked 3,561 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Google Lezyne Road Drive to see if it suits your need. I am considering it or a similar Bontrager pump but my lbs didn't have it in stock.
Quoted: 18372 Post(s)
Liked 4,507 Times
One of the more unique pumps is the Specialized AirTool Dual Air.
https://www.ebay.com/itm/164068744585
I think they've been discontinued, so they are where you find them.
Not the most compact, but it has a couple of useful features.
Presta/Schrader head (on the newer models), so no need to keep pulling the gasket every time you need to switch.
Handy patch kit (or bandaid) compartment in the handle.
Looking at the Specialized lineup, they have a few sleeker designs that would be worth considering, but I do like the patch kit option.
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,984 Times
Topeak Road Morph but I want to keep riding sooner rather than pumping for a long time with those tiny pumps. If I had to go small I guess the Race Rocket HP is a fine one and one I do occasionally take out with me if I also have CO2 and inflator.
Quoted: 1062 Post(s)
Liked 665 Times
The most recent pump I've purchased is a Lezyne HP Drive, and I'm quite happy with it. Whatever you get, I strongly recommend the kind of pump that comes with the little hose, rather than the conventional chuck. The reason is that the flexibility of the hose will be much more gentle on your valve stems, and like it or not, stem leaks are a known failure mode of tubes. It's hard to guess from threads about the topic whether it's a design flaw or user error, but I think the hose makes the problem less likely. The hose fits inside the pump, so it doesn't add bulk.
Also, in addition to the mini pump, I assume you have a good floor pump for at home.
Because it's so small, the "look" of the Lezyne is immaterial, since it fits inside my sag bag.
Liked 4,507 Times
I've been looking at the Lezyne lite drive per your recommendation to look over Lezyne products and I must admit I do like it. The branding is annoying, but I think I've reached the point of being too picky. I also think it will look good on my bike in the silver color.
You could paint or steel wool the barrel if you wish.
I might try to steel wool it if I get it, or just roll some duck tape over the branding for emergencies. I was also looking at the road drive vs. the lite drive and couldn't find any information on bike forums. I'm wondering if anyone has any experience with both, or even knows the differences?
Liked 4,507 Times
From the specs,the Road and Lite look very similar.
Lite appears to only be listed in small/medium, and is slightly lighter than Road which comes in small/medium/large.
Lite lists a Presta/Schrader hose.
Road lists ONLY Presta hose.
I've gotten a fair amount of use with a Schrader head, both from helping people stuck beside the road, as well as my trailer.
Likes For CliffordK:
Liked 665 Times
Likes For Gresp15C:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
FWIW, I just got the Lezyne Grip Drive in size small. Works as I imagined. Sucks to have to keep pumping past about 65 psi.
EDIT: What "emergency" demands that branding be invisible?
Likes For Gresp15C:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
When my last pump fell apart on the road (never did find all the pieces) I got me one of these. It works great, the price is right, and the mounting is such that it snugs up to your water bottle. It also has a pin in the lower handle part that fits into the mount so you can't lose half of it on the road. Presta only, if that's a problem, but the color matches your bike.
https://www.ebay.com/itm/292334271418
Are you putting the pump in your pocket or on the bike? If you use the water bottle holder bracket and have on the bike, it's an obviously simple affair to turn the logos into the frame so you wont see them.
Liked 4,507 Times
You may actually have to stop for some of those people dead beside the trail!!!
Once you take the screw on part off, gently open/close the lock to help push the parts out.
Quoted: 383 Post(s)
Liked 690 Times
Likes For kahn:
Clark W. Griswold
Liked 3,984 Times
Get the Topeak Road Morph, it is a good pump that works well and is easy to use when you get a flat you won't give two turds about the branding or the size but you will thank me when it is just a little easier to pump those tires.
Likes For veganbikes:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 318 Times
Here is the best I've had. >>> https://www.primeauvelo.com/en_ca/mi...EaAqlgEALw_wcB
It's a mini floor pump with a hose. The ONLY kind to get IMO. It takes about 110 strokes to fill a 36 mm from empty.
The ones you TRY holding still in the air are all pathetic. Lucky if you get the tire half full. And very TIRING. There may be times when you need to refill FAST and roll until the slow leak empties again.
Quoted: 961 Post(s)
Liked 1,628 Times
Lezyne Pocket Pump...
