Glasses with thermal face mask
Old 10-17-21, 08:22 AM
bampilot06
Quoted: 3855 Post(s)
Liked 1,779 Times in 778 Posts
Had to start wearing glasses this past spring, and this morning’s chilly ride reminded me of a concern that I have. In the past winter seasons I learned pretty quickly that sun glasses were not really an option when wearing my thermal face mask. My breath would cause them to fog, so I just didn’t wear sun glasses.
This winter I prefer to wear my glasses, my vision has started to suck, but I don’t know how to keep my glasses from fogging.
Anybody have some advice on this issue? I’m considering goggles but if there is a better option I am all for it.
bampilot06 is online now
Old 10-17-21, 09:33 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 2007 Dahon Boardwalk, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1188 Post(s)
Liked 1,067 Times in 526 Posts
A few years ago I started cleaning my glasses regularly with just soap and water. I noticed that winter that they fogged up less and "defogged" quicker. If I stopped they fogged, but if I started riding again they defogged.
Also, I switched from a heavy-ish face warmer, to a thin nylon belaclava, just enough to keep the cold air off my face...that also helped.
BobbyG is offline
Old 10-17-21, 09:42 AM
bampilot06
I do have a thinner bachlava, but I have never worn it, I have always just worn the same one. I was my glasses with soap and water too, but they still fog pretty bad when I have to wear a regular face mask at work.
Old 10-17-21, 11:14 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4039 Post(s)
Liked 1,075 Times in 700 Posts
I would imagine it depends on the face mask style. Something like the below allows breathing out the mouth and shouldn't fog your glasses. I assume your glasses are covering part of the mask and the hot air is partly escaping up under the glasses?
Sy Reene is offline
Old 10-17-21, 11:21 AM
bampilot06
it’s is what I wear. I think my lips would hurt with the above picture.
Old 10-17-21, 07:53 PM
jaxgtr
jaxgtr's Avatar
Bikes: Trek Domane SLR 7, Trek Emonda ALR 6, Trek X-Caliber 8
Quoted: 316 Post(s)
Liked 656 Times in 407 Posts
I found that if I adjusted my balaclava in a certain way, the fogging of my glasses did not happen while I was moving.. sometimes it fogged up when I stopped if it was exceptionally cold, but found I was generally good. I got one of these or something very close to it by this company.
https://www.amazon.com/ROCK-BROS-Bal...4521704&sr=8-2
Brian | 2021 Trek Domane SLR 7 | 2016 Trek Emonda ALR 6 | 2016 Trek X-Caliber 8
Originally Posted by AEO View Post
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Old 10-17-21, 07:55 PM
fooferdoggie
Quoted: 309 Post(s)
Liked 335 Times in 204 Posts
do you need your mouth/nose covered? Never need that and ever have a fogging issue. Now when I use it as a mask the nI go into a store then I get fogging.
fooferdoggie is offline
Old 10-17-21, 08:01 PM
bampilot06
I cycle outside all winter, last year the lowest was 15 degrees American. With the mask on my sun glasses would fog, especially the harder that I breath.
Old 10-17-21, 08:02 PM
bampilot06
I’ll check this out thanks.
Old 10-17-21, 08:06 PM
fooferdoggie
Quoted: 309 Post(s)
I have only gotten to about 25 but never covered my mouth, when it is that cold I use two of them a thin one and my normal one then I would breath through the thin one.
Old 10-17-21, 08:12 PM
bampilot06
Thats a thought.
My lips get crazy chapped in the winter even with the mask on, that’s why I havnt considered one with a hole in the mouth.
But this might be the only option.
I read somewhere that you could use snow boarding goggles over your glasses, but didn’t know if anyone here had tried that or if it was even practical.
Old 10-17-21, 08:13 PM
fooferdoggie
Quoted: 309 Post(s)
Thats a thought.
it was a really thing one I got at a local bike shop. really too thin to do much. but layering does great and it was much easier to breath through.
Old 10-17-21, 08:27 PM
seypat
Quoted: 2040 Post(s)
Liked 1,019 Times in 689 Posts
Do the companies make full face MTB helmets with the flip down front? That would take the mask out of the equation.
seypat is offline
Old 10-17-21, 08:30 PM
bampilot06
sounds heavy.
Old 10-17-21, 08:39 PM
seypat
No flip front, but probably would be warmer.
https://www.bellhelmets.com/bike/c/m...-bike-helmets/
seypat is offline
Old 10-17-21, 08:48 PM
seypat
Here's an option. Also. Some of the companies such as Giro make winter helmets.
https://bikerumor.com/2016/02/12/pro...th-the-visorx/
seypat is offline
Old 10-17-21, 08:51 PM
seypat
Here's an option. Also, some of the companies such as Giro make winter helmets.
seypat is offline
msalvetti
Bikes: Mongoose Crossway 4.50
Quoted: 20 Post(s)
Liked 72 Times in 28 Posts
Having to wear my glasses and masks for Covid has been really frustrating due to fogging. Especially for work when I have to wear safety glasses. My optometrist recommended Fogaway: https://www.amazon.com/Spray-Glasses...ef_=ast_sto_dp
It's not perfect, but it reduces fogging better than any other product I've tried.
Mark
msalvetti is offline
Old 10-17-21, 08:57 PM
bampilot06
That’s pretty sweet. I would be willing to try that.
Old 10-17-21, 08:58 PM
bampilot06
Mark
This is an option as well, but I have a feeling they will still fog up at some point and that could be a disaster.
Old 10-17-21, 09:31 PM
zandoval
zandoval's Avatar
Bikes: Univega, Peu P6, Peu PR-10, Ted Williams, Peu UO-8, Peu UO-18 Mixte
Quoted: 255 Post(s)
Liked 326 Times in 229 Posts
Prescription googles and these really work! And good for swimming too. I would wear them over the bachlava and a little loose.
https://www.otg-goggles.com/top-5-pr...-swim-goggles/
zandoval is offline
Old 10-17-21, 11:05 PM
MinnMan
MinnMan's Avatar
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3159 Post(s)
Liked 2,069 Times in 1,236 Posts
In my experience, I don't need my mouth covered at +15 °F. If chapping is a problem, I recommend Carmex or similar.
I ride down to -10 °F and am generally comfortable down to 0*F. Probably I'd be wearing something that covered my mouth below 10 °F.
With that said, I can ride without steaming my glasses UNTIL I stop (say, at a red light). Then there are problems.
MinnMan is offline
Old 10-17-21, 11:06 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 15938 Post(s)
Liked 7,554 Times in 4,211 Posts
Contacts. 🙂
Seattle Forrest is offline
Old 10-18-21, 05:27 AM
Hiro11
Bikes: To the right: opinions, not facts.
Quoted: 690 Post(s)
Liked 335 Times in 180 Posts
"Chilly" might mean something different for you than it does for me, but for sub 20F I've found ski goggles or mountain biking goggles work well. Goggles with double-walled lenses prevent fogging very well and as the bottom is sealed work well with something covering your nose and mouth. I have a cheap pair of low profile enduro goggles and they are effective never fogging and with comfort on really cold (sub 20F) days. I have to admit I rarely use them as regular glasses with a hat under the helmet is more comfortable most of the time. Also, I personally don't like riding with something covering my mouth.
One tip: make sure the googles work with your helmet before buying. Also, don't buy ski helmets for cycling as they're way too hot.
Hiro11 is offline
Old 10-18-21, 06:05 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Contacts. 🙂
I presume eye protection would still be wanted, but I thought the same, in combo with an aero+shield helmet like the Giro Vanquish
Sy Reene is offline
