How much am I over oiling?
Old 10-21-21, 11:13 PM
AJW2W11E
Quoted: 52 Post(s)
Liked 15 Times in 12 Posts
I have two White freewheelís now.
I am always worried about getting them shark toothed, so I oil every time I ride. I use that wet lube that comes in a black bottle with a green label. Forget itís name but you see it everywhere. Finish line, thatís it.
After a while, my bike started to look like one of those old cars with bad gaskets. The whole bottom frame was greasy.
I do my healthy 20 miles a day, not fast , but lots of hills. How much should I be oiling? What amount of drops and how often?
AJW2W11E is offline
Old 10-22-21, 04:29 AM
Colorado Kid
Quoted: 200 Post(s)
Liked 64 Times in 30 Posts
Drop or two is all you need. I only put it on when it seems "dry".
Colorado Kid is offline
Likes For Colorado Kid:
Old 10-22-21, 05:46 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Bikes: '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022, '21 Tsunami SNM-100
Quoted: 1455 Post(s)
Liked 1,512 Times in 800 Posts
Both your chain and your freewheel should appear clean and dry. So, after you lubricate each link and work the lube in a bit, you must wipe down the chain thoroughly. That means no visible lubricant on the outer plates, on the rollers, on your chainring or on your freewheel teeth. Spend 5% of your time applying the drop-by-drop lube to the roller/pin/plate joint and 95% of your time wiping clean afterwards.
And you don't need to lubricate every time that you ride. Think about what you are doing. Want to prevent wear? Then don't create a slurry of oil and grit through which you run your chain and cogs. What do you think that is accomplishing? Accelerating wear? Most likely.
Keep it clean and keep it quiet. The rest is irrational.
Phil_gretz is offline
Likes For Phil_gretz:
Old 10-22-21, 08:05 AM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 540 Post(s)
Liked 221 Times in 140 Posts
I agree with Phil Gretz. Generally less is best. Precision application versus slobber it all over the chain is better.
drlogik is offline
Old 10-22-21, 10:38 AM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 352 Post(s)
Liked 511 Times in 345 Posts
Well said. I also have had great luck using Boeshield, a wax-based lube. It helps keep the chain clean and dry, and that helps it attract less dust.
Otto
ofajen is offline
Likes For ofajen:
Old 10-22-21, 12:55 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2770 Post(s)
Liked 1,539 Times in 951 Posts
An over-oiled drivetrain collects grit and can actually accelerate wear. As others mentioned, less can be better. A precision oiler, with a small drop on each chain roller (but not the side plates) followed by a wipe-down to get rid of excess works for me. Don't clean/reoil until the chain/sprockets are noticeably dirty, or when the chain gets noisy.
JohnDThompson is offline
Likes For JohnDThompson:
Old 10-22-21, 02:06 PM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 452 Post(s)
Liked 270 Times in 162 Posts
T-9 Boeshield is my favorite. I didn't want to dive into the millionth chain lube discussion/argument, but here's what I like: there are oily lubes that work best for wet riding conditions, to keep corrosion at bay, and there are very dry lubes designed for dusty conditions, to avoid trapping grit in the chain. Boeshield seems like a good compromise for mixed conditions. I apply it about every 2-3 weeks, which works out to 5-10 rides or somewhere between 100 and 200 miles. I don't keep close track, but just lube when I feel like it. This is excessive, and I could probably go five times as long between applications without any trouble. As suggested above, lubing too often is not a problem. Applying it too heavily and not wiping off the excess is what results in a mess.
I like to clean my chainrings and cogs fairly often too. I don't use any special brushes or machines for this, usually just an old cotton t-shirt. Friends often comment on my sparkling drivetrain. I tell them "It's like a sickness, I can't help it."
Broctoon is offline
Old 10-22-21, 09:09 PM
Rolla
Gyro Captain
Rolla's Avatar
Bikes: 4 Singlespeeds, 2 Gearies
Quoted: 551 Post(s)
Liked 1,378 Times in 611 Posts
Clean the chain regularly and well, and you can use less lube. +1 on the Boeshield.
Rolla is offline
Old 10-25-21, 09:02 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Premature Wear From Overoiling
Close up of FD-4703 Cage Wear (pencil point)
This was today's customer who frequently oils his chain, but rides on trail and in dirt. The oily sludge helped his chain to cut through his FD cage in only 3 years. I had warned him last year (and the year prior ) to keep the chain drier and wiped clean. Oh well.
Old 10-25-21, 10:03 AM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Don't treat your drive chain like the Tin Man. It just gets dirtier a lot faster.
Philasteve is offline
Old 10-26-21, 01:48 AM
Lazyass
Quoted: 2382 Post(s)
Liked 560 Times in 346 Posts
When my chain needs lubed I can hear it.
Lazyass is offline
