Belt drive, gravel size tires? Cheap?
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
As the rainy season begins and I dread having to clean and lube my chain so damn much, I find myself wondering about belt drive. And the terrain is mostly flat for my go-to ride/commute. So why not single speed?
Except I don't know where to shop, since I imagine belt drive bikes that fit 35-50mm tires are a bit of a niche product. Edit: Drop bars are a massive preference.
Do y'all have any suggestions for bikes to look at and consider?
Thanks.
Thanks.
Non omnino gravis
That all comes down to the budget. Lots of flatbar options out there, from a $450 Motobecane Elite Eight to $1,900 for a Cannondale Bad Boy 1 or $3,000+ for a Co-Motion Siskiyou.
Spot Bikes makes some gorgeous belt drive bikes. The Rallye SS is particularly attractive. In the commuter class, the Ajax is also nice.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Trek District SSB - 2016 - $299
https://www.trekbicyclesuperstore.co...b-233067-1.htm
It comes with a bit smaller tires, 32's.
This is just an example. They come up on craigslist once in a while and there is some old stock out there.
-Tim-
-Tim-
Quoted: 169 Post(s)
Do you have any other drop bar suggestions? For IGH or single speed?
Quoted: 169 Post(s)
-Tim-
-Tim-
I don't NEED big tires, I can do the ride on 28mm gravel kings. It's not particularly demanding hardpack, but when there's a bit of snow or mud, I just like to be able to choose my own line, rather than have the ruts dictate my line.
Quoted: 99 Post(s)
Liked 115 Times
Belt drives need larger cogs because they are harder to flex. Also, they can be damaged if sharp stones or glass get trapped between the belt and the cog. In normal use, they last a long time and are low maintenance. However, it would limit your options for tweaking the bike. Probably cheaper and easier to have two or three chains, swap them once a week or so, and have a chain cleaning session every so often. Introduce economies of scale into the cleaning process!
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Belt drive and serious mountain biking are sometimes incompatible but it should be ok for dirt roads and is certainly great for commuting.
Priority makes a few options... a commuter and a cruiser. Soma has belt compatible MTB frames, not just the Wolverine. Ventana is made in the USA and has belt compatible MTB frames, and they can make you a custom, but $$$ compared to larger volume Asian products. Many belt frames are convertible between hubs using optional dropouts.
- Soli Deo Gloria -
Liked 736 Times
The Priority 600 has a Pinion 12 speed gearbox. It is an interesting product.
https://www.prioritybicycles.com/products/the600
There is a thread on it in the General forum.
-Tim-
-Tim-
I can help you with belt drive, gravel and single speed. I can't help you with cheap:
https://www.rodeo-labs.com/flaanimal4/
Quoted: 169 Post(s)
I regret it. A LOT.
That blue is so damned sexy.
I'm probably going to forgo belt drive and get a kilo WT, then swap the tires and add fenders.
