Saddle and pedals: keep or remake?
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
I have an old vintage saddle (selle italia sprint). Is not in perfect contisions since when i got it it was full of plants and even a nest of something under it. I took with patience and i cleared , since it is white i used some bleach and other stuff to make more whitish as possible.
Now i have a few roll of synthetis leather (with a very nice texure).
(Black spots are just a bit of dust)
Is better to keep the actual conditions or make a new cover with the leather?
For the pedals , i want to clear and remove all rust possible but is kinda hard since is not a fully flat surface. The only option i think is okay is the electrolysis but this one i have the fear that will ruins the bearings....
Any solution? electrolysis? replace? or keep at the actual conditions because "they are original"?
Quoted: 4510 Post(s)
Liked 6,377 Times
The pedals need to be disassembled and soaked in Evapo-rust or OA, then will probably have to be wire wheeled or cleaned up with partial bad chrame showing.
You could just wire wheel them but it takes off more than you want, not just rust, the original metal suffers for it.
Quoted: 333 Post(s)
Liked 168 Times
I'm in different to the saddle but I would treat it with some kind of dressing to stave off the cracking that is already winding up.
is not super-smooth but i'm pretty happy about the results.
Liked 6,377 Times
I would be careful, very clean, it might discolor the white by pulling dirt or? through the finish, start very sparingly, tiny bit at a time.
You could also take it to a shoe shop to refinish or maybe get advice.
Wait, did you put new leather on the black one?
Liked 6,377 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,478 Times
Liked 6,377 Times
Quoted: 2588 Post(s)
Liked 4,824 Times
Nothing to add about the saddle or pedals, but I've got a question: Tomasini with one "M"? That's what I read on the seatstay cap engraving. Different builder than Irio Tommasini?
DD
DD
Quoted: 333 Post(s)
Liked 168 Times
Somewhere in the forum there is a tread with the full photo of the bike.
I bought the frame for 46$ , i think that was a good deal even since the seller were asking for 100$ as starting price. The bike was missing the handlebar and the wheels and other little parts but since i had some spare parts i decided to assemble for the eroica event.
Now i'm doing some little works to make it perfect for next year eroica (hopefully without covid).
When i'm done i'll post some updated pictures ,if you want to take a look here is FEB-2019 https://www.instagram.com/p/BuDv8uoA..._web_copy_link
Quoted: 333 Post(s)
Liked 168 Times
degreased , sandblasted and inserted new bearings with grease too. But i think im going to use the first couple since for me looks more nice with that little spike. Also because they reminds me the campy pedals.
My friend came to my house when i was inserting the bearings , and told me i should paint. Do you think is better to keep in this way? or to paint for prevent the rust formation again?
Quoted: 964 Post(s)
Liked 1,451 Times
If they are not so valuable, then just spray them with some cheap silver spray paint. This will stop the rust, and they may look slightly better than sandblasted. You may be able to heat them up a little before or after painting to make the cheap spray paint cure a little better.
Another alternative is to "blue" them using a bluing compound. This usually contains selenium dioxide and is commonly used on pistols.
Or you can get a "black oxide" finish by using some other chemicals, or by letting them rust and then rubbing them down with some oxalic or phosphoric acid followed by oil.
Or you can heat them up and put them in linseed oil to get a blackened oil finish.
There are lots of choices!
Quoted: 333 Post(s)
Liked 168 Times
I know nothing about Italian bikes or equipment, so I can't judge these pedals on value. If they are very valuable, it is worth disassembling them and seeing if someone can plate them, either with zinc (cheapest) or nickel or chrome (expensive and possibly prohibited due to environmental regulation). It should be doable and this would put them back to original.
Quoted: 333 Post(s)
Liked 168 Times
Now , i think i can focus on the saddle now.
Quoted: 333 Post(s)
Liked 168 Times
Update:
Used a white dye , fixed a bit the cracks and hand painted a new logo as the original.
Likes For CrowSeph:
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Holy crap... that's a really, really nice result on your saddle renovation.
Nice work!
Nice work!
