Front wheel drive vs rwd
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Huffy RedRock (first bike), Aostimotor S17 ebike
Quoted: 191 Post(s)
Liked 264 Times
I'm building a new bike, received the motor, but it's a fwd instead of rear. Is it worth the hassle exchanging it? It's a 1500 watt, 48 volt set up. Would there be an issue with traction? The other thing is that the front wheel can't be easily removed for easy transport, but I guess I can remove the rear wheel now.
Devil's Advocate
Well you would need a super strong headset and steel fork with fender eyelets to support a pair of GrinTech TorqArms V2, to handle that kind of power from a front hub!
It’s not too difficult to remove a front wheel drive even with those torque arms installed — much easier than a rear. Can’t say whether traction might suffer on loose gravel or under slippery conditions, because in effect you’d have dual drive — just that the rear wheel would be relatively underpowered (obviously). I’m amazed by how well the 500W front drives perform on my two dual drive LWB recumbents, where those wheels are comparatively lightly loaded. On a standard upright with weight more evenly distributed it doesn’t make all that much of a difference where the drive is, AFAIK. Not to mention, the weight of a 1500W motor in front would certainly help shift the balance forward!
That said, have never actually heard of anyone performing a conversion with such a high wattage front drive. But as the company actually sells it, there must be some legitimate use cases, one would think.
BTW, I take it this is for a fat bike?
Likes For andychrist:
Quoted: 340 Post(s)
Liked 275 Times
They were selling those big DD motors in front and rear drive versions when I converted my first ebike in summer of 2015. However, I wanted the freewheeling of a geared motor, and all the veterans suggested rear drive as better/safer for the newbie. Too easy to rip out alloy forks with a strong motor.
As I gained some experience, I did put a 250W motor on a 20" bike with alloy forks, The bike had a sweet 8 speed cassette and trigger shifter, and I didn't want to lose it, I used double torque arms, and this year I finally found a steel fork to replace the alloy. I feel safer.
Also this year, I came across an inexpensive 500W front motor/wheel/tire (used) for 45 bucks, and I put that on a bike that also had steel forks, What is in common with both bikes is tire slip when starting out on loose surfaces, or wet pavement, especially when I hook up a trailer that weighs around 75 pounds with load. It it were wet leaves, I'd probably fall over, but I've been wary of wet leaves ever since I almost fell on a motorcycle years ago..
On both bikes, I used torque arms or torque plates. I used to mark the nuts with ink on the first bike, and they never moved. With the 500W motor, because the cable did not go thru the axle, I was able to use a torque wrench to set the axle nuts. I did a long search, but found nothing definite. It seems like one bike maker tells his customers to go 25 ft-lbs. Seems light to me, but in truth, it was more than what I was doing on all my bikes with a 10 inch 17mm wrench.
I'd still suggest to the OP that he switch it to the rear. 1500W, even if it's only a peak number, is a lot of force to put on a fork,
Likes For Doc_Wui:
Quoted: 882 Post(s)
Liked 821 Times
I had a 350w, 36V front hub system and really enjoyed it as an errand bike and off road where I "learned" to weight the front wheel when ascending pretty steep hills. However, I agree with DW that 1500w is too much for a front hub. Plus the ramifications of a failure could be astronomical.
Likes For 2old:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Agreed. don't do it. I wouldn't go above 250-350 watts on the front (actually, I wouldn't do it at all). The front fork is not designed for this torque at all. If that motor spins in the dropouts and breaks the dropout, you are going to the hospital. That is assuming you don't have any traction problems. Sure, you may have traction 90% of the time, but higher power FWD put people in the hospital too often.
Likes For chas58:
Quoted: 191 Post(s)
Liked 264 Times
Requested exchange just out of principle, plus all good points made here. It is a fat bike, with front suspension to soak up the bumps. My prior ebike was a Schwinn Stingray chopper and each bump chipped my teeth. For the next bike I'll try to procure a dual suspension fat bike.
