A couple of things I dont understand
#76
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
I run latex and butyl tubes in clinchers and latex in tubulars. I pump all tires every time I ride. It is sort of a pre-check inspection before riding. And I check electronic shifting battery charge. Generally, I put the bike on the car and drive to a route.
I carry a multi purpose tool, CO2, spare tube, patch kit, latex glove, tire irons, tire boot in case of tire cut and a mini frame pump. Lately, I have been riding my tubular race wheels on my time trial bike so I carry an inflator with latex sealer. I had to use my phone once to get a ride due to a sidewall cut where nothing seemed to work.
I do not watch videos of other riders and certainly if I did, the last thing I might observe was their tool/flat solution. Having said that, on a coastal ride in San Diego on the weekend, I will see between 50-100 cyclists on the road. So I get a pretty good idea of what is market for bikes, wheels, setup, toolkits/ bags, clothes and etc. I might see one rebent or a trike. I see more handcycle cyclists. I think the small power climbs on the coast, ahem, cause the rebents to choose other routes.
And if I stop and dismount, I am regaled by cyclists wanting to know if I am okay. I stopped to use a Jiffy John on Fiesta Island and as I was walking my bike to the john, a couple of cyclists yelled, are you good. In SD, we take care of each other so on any given day, we are very long on tools, tubes, expertise, CO2 and pumps.
#77
Quoted: 3949 Post(s)
Liked 7,295 Times
Although, I did just that about two weeks ago. The last person or Olympic weight lifter who tightened my rear through-axle did a fantastic job. I got a gashed tire (I might have been able to boot it) but could not get the through-axle loosened. I cursed, prodded and bent a tire level in futile attempts to get the thing loose. I even took off my bike shoe and tried using it as a hammer. It required a decent sized rubber mallet's 2-3 good hits to move it.
#79
Liked 7,295 Times
Likes For tomato coupe:
#80
Quoted: 383 Post(s)
Liked 690 Times
Rigid soles and spd but I guess I could not grasp them and get a good angle on the through-axle lever. And to make matters worse, I do have a hammer toe. I do recall years ago jumping on a tire iron along I-90 trying to get a bolt loose on my car's rim.
#81
Quoted: 1273 Post(s)
Liked 1,392 Times
Likes For mschwett:
#82
Quoted: 3352 Post(s)
Liked 1,056 Times
Real men bike riders know how to repair their bike on the road if need be.
#83
Expired Member
Quoted: 3664 Post(s)
Liked 5,412 Times
Likes For shelbyfv:
#84
Quoted: 7652 Post(s)
Liked 3,473 Times
And wearing oversized panties, apparently, but that was a lot more information than I really wanted.
Likes For Maelochs:
#85
Liked 7,295 Times
#86
I carry a patch kit and multi-tool.
I've never carried a spare tube, tire, or brake and shift cables.
I have carried enough tools to disassemble the bike down to the bare frame. They came in handy when the freewheel came apart. Since I didn't carry any spare bearing balls, I had to walk back a hundred yards until I figured that I found enough.
Likes For Frank S:
#87
Quoted: 18409 Post(s)
Liked 15,530 Times
I don’t bother checking my LHT’s pressure every day for my 1.75 mile commute. Usually don’t bother with a pump or flat changing stuff unless I’ll be going somewhere after work.
Right now I’m 4 days into a tour from northern VT to home. Haven’t checked pressure once. Maybe at the end of the day tomorrow.
#88
Quoted: 980 Post(s)
Liked 776 Times
I check my tires before each ride and then I stop 1/3 of the way into the ride to check them, and again at 2/3 into the ride for my last pressure check.
At the halfway point of each ride I also stop to re-lube(dry ofc)my chain.
And I know it goes without saying, but I also change the batteries in my helmet light at the halfway point in case my hub dynamos fail.
Again, I know it also goes without saying but I also check my saddle bag before and during each ride to make sure my drivers license, medical ID card, credit card, next of kin list, and last will and testament are secure.
Anything less would be irresponsible and dangerous.
#89
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Nope. I don’t use hot wax. I use wax in solvent. Easier to carry and just as effective.
Stuart Black
Stuart Black
#90
Quoted: 4227 Post(s)
Liked 2,488 Times
Likes For wolfchild:
#91
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
#92
Liked 3,473 Times
Likes For Maelochs:
#93
Liked 15,530 Times
OP also doesn’t understand “racer boys” and DF bikes.
#94
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
You're probably better and quicker at changing tires than I am. The last tire I changed took me more than 24 hours. I had trouble getting the tire to mount and broke all my tire levers (three of them), and finished the job the next day after visiting the LBS to buy more tire levers. If I'm riding too far from home, I'll take my cell phone and call my wife to get me, but so far, I've not yet needed to use that option. She's offered, so I wouldn't feel bad calling her.
Likes For Random11:
#95
Quoted: 896 Post(s)
Liked 2,063 Times
Somewhere out there on the internet archives is a bit of cycling wisdom that says, ever so well, that you can never be prepared for every eventuality. Carry what you decide to carry, fully aware it may not be enough. And it will be okay.
Likes For downtube42:
#96
Quoted: 4559 Post(s)
Liked 2,802 Times
Depends on the bike, distance, etc.
I prefer latex tubes on my road bikes. Not so much for the slight speed advantage, but for comfort. My neck is busted up from injuries, and latex tubes with supple tires are comfy. But those skinny 700x20-23 latex tubes don't hold air for long, so I have to check 'em before every ride.
I carry at least one butyl tube as a spare. And my minimalist spare kit fits in a very compact Lezyne Road Caddy: tube, CO2 inflator and cartridge, one lever, very slim multi-tool, sometimes a spare chain quick link. My other road bikes for longer unsupported rides will have two butyl tubes and two CO2 cartridges. And every bike has a mini pump, usually in a clamp bolted to the water bottle cage.
But my heavy comfort hybrid errand bike is mostly for short trips and I might not bother with a patch kit or anything else. I use heavy duty puncture resistant tires that have never had a puncture, even when I've pulled out staples, nails, glass, etc.
On group rides I and others have bailed out fellow riders who were under-prepared or completely unprepared for flat tires. Shouldn't be necessary, but that's how it is. If you watch videos of pros doing solo training rides, they almost always have a seat bag with spares. I don't get the vanity of recreational club roadies who don't even race amateur crits, but won't bother to carry a minimalist spare kit because it might slow them down or looks bad or something?
So on longer group rides I'll often carry extras for those folks. It's a little annoying, but I'm not gonna make a big deal about it during a ride. Easier to just help 'em out than fret over how to get them home.
#97
Liked 3,473 Times
I was wondering what happened to @rydabent. It used to be that every four months or so he would start a thread about cycling wear, or diamond-frame bikes, or a couple other silly topics .... I was a little worried that it had been so long since we had heard from him.
I guess he was just busy riding ... and dreaming up new, even sillier positions to both defend and use to attack others.
Welcome back, Mr. Rydabent.
#99
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I maintain my bikes well enough that I only feel I need a patch kit, tire levers and CO2 inflator for the roads and routes I ride. I do however have a multi-tool and spare tube in my saddle bag. Bike-packing, touring, solo century riding and jumping off of cliffs on a poorly assembled Huffy from Walmart may have different equipment needs.
I do find it interesting that along the way in this thread masculinity is starting to be measured by the ability to fix a flat or the number of wheels on the bike. As long as folks are riding what they enjoy I don't think it should matter to me if they ride a recumbent pulling a sag wagon full of gear.
#100
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Also, pretty ridiculous that masculinity is somehow the ideal for this. I've gotten some damn good roadside advice from a woman bike mechanic who just happened to be riding by. Just shows how gender imbalanced BF is that someone gets away with the implied put-down of femininity.
Likes For livedarklions:
