FS: SunTour bar-ends; Shimano bar ends indexed
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
Up for sale are:
1. SunTour bar-end ratcheting shifters; light use, plastic is good. $45 shipped. SOLD and SHIPPED!
2. Shimano 8 or 9 speed indexed bar-ends; slight scuffs but great condition. SOLD!
Edumacator
Liked 3,122 Times
I think they are 8 AND 9. The label says 8 if 7400 series, and 9 if 7700 series? I have never used them though. Not a bar end fan.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
that's indicating what derailleurs they're compatible with. if you get eight clicks on them after the first position, they're 9spd. if seven clicks, then 8spd
Edumacator
Liked 3,122 Times
Yep. Absolutely. I just have not counted the clicks to confirm! I was saving them to put on a flat bar conversion of sorts, but then decided otherwise.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
okay. i was just trying to clarify they will only index for 8 speeds OR 9 speeds. just not both. of course, in friction mode, you can shift any speed
Edumacator
Liked 3,122 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
I have 2 sets of these Shimano shifters and they index for 9 speed using either a 7700 Dura-Ace RD or an Ultegra 6700 RD. I think that the 7400 series uses these and will work with these with an extra click
Edumacator
Liked 3,122 Times
So basically, you have an un-used extra click when using the 74xx RD?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yes. for the right hand shifter, there's a little ring on the periphery of the flat head assembly bolt you turn according the indicators on the surrounding black plastic ring. should say "friction mode" or "SIS"
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i had to look it up, but is there a six speed 7400 group and an eight speed 7400? and, were the dura ace eight and nine speeds the same spacing?
Will these work with other derailleur not DA or Ultegra? Is the left hand for a double or a triple?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i know the front will shift triple. otherwise, perhaps sheldon can clarify the rear shifting....
https://sheldonbrown.com/dura-ace.html
Just to add a little clarification/confusion. I am running 9 speed STIs (7700 series) with an 8 speed (7400 series) rear derailleur and 8 speed cassette on one of my bikes. It shifts perfectly.
So.... the bar end shifters should work with both 7400 series 8 speed and 7700 series 9 speed.
aka: Dr. Cannondale
Quoted: 2154 Post(s)
Liked 3,403 Times
Front shifter is friction and works with any FD.
In theory, rear shifter will index only with a 740X RD for 8 speeds OR with any Shimano RD except 740X for 9 speeds, OR any RD in friction setting.
Never used one that way myself, but that’s what’s supposed to happen according to legend.
Edumacator
Liked 3,122 Times
I am embarrassed to know so much less about these than you all...yeesh!
I do know the friction setting is okay.
i just assumed it could only shift eight speed versions of 7400 and all versions of the x700 series of nine speeds (DA, Ult, etc...)
Like I said above, I was going to try to use it at the end of flat bars on a city gravel thing with an a Ultegra 9 RD and a triple up front. I figured it was intended for the 9...
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
PM sent on Shimano shifters.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Edumacator
Liked 3,122 Times
Likes For jdawginsc:
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
Clarification on the 8/9 question.
For its 8 speed generation, Dura Ace had a different pull ratio from the other groups -- ultegra, 105, the mountain stuff. That's why you can't use a 7400 rear derailleur with any other 8 speed shimano shifter. It will only work with a 7400 shifter.
When Shimano went to 9 speed, they adopted the pull ratio from 7400 and applied it across the board to all groups. So 9 speed Dura Ace is cross compatible with 9 speed XT and 9 speed ultegra, etc.
These shifters have that same 7400/9 speed pull ratio. They will therefore work in 8 speed with 7400 or in 9 speed with anything else. If 7400, you will have an extra click, but that would be prohibited by properly limiting out the RD.
"Party on comrades" -- Lenin, probably
Likes For icepick_trotsky:
