Let's see your crankset
Quoted: 3015 Post(s)
Liked 3,797 Times
I need some inspiration for a new build. I am most interested in single-ring setups, but I'm happy to see anything. Show me the best you have.
Here are/have been a couple of mine.
FB Cranks 1 by iabisdb, on Flickr
Bianchi Crank 01 by iabisdb, on Flickr
FB Crank 01 by iabisdb, on Flickr
Columbia Crankset 01 by iabisdb, on Flickr
Likes For iab:
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
Really, really like that first FB! I have come to appreciate older cottered immensely, even on old ten speeds like the Olmo I have. More design and less bolts. Hope these help!
Sugino with factory drillium, I pulled the small ring and put the large ring to the back. Work in progress...
58' thin arm 151bcd + block chain
Please ignore the cruddy water paint I tested on lugs and never cleaned off
Schwinn 39?+ bike is 40'ish based on SN
Raleigh from 51' Clubman in first pic
SE 09' all black bike with only chainring bolt color. Just in case you try and figure color in..
62-73' 151bcd
62-73' 151bcd
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Durax fluted cranks, Automoto chainring. I still haven't gotten around to starting this project.
Likes For Sluggo:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Late 30's CCM
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,470 Times
Brent
Likes For obrentharris:
Pedalin' Erry Day
Here are my favorite looking older cranks, Nervar Stars, they polish up stunningly well and have neat details. If these strike anyone's fancy, they're actually sitting unused in my box-o-parts at the moment, I just don't have the right bike to put them on:
Can't go wrong with Record cranks either though:
Not C&V, but I really like how Sram Red cranks look after taking the logos off:
TA Pro 5 Vis arms w/Cyclotouriste rings, as found only on the early 1971 Schwinn Sports Tourer. Includes 36-54T rings, a unique to Schwinn inner ramp ring, plus an outer guard, domed bolts and pedal eye plugs:
Top Line double, not antique but they came w/ a weight limit that I happily to do not (quite) exceed.
Beautiful CNC machining and finish from the 1990's era and very Light.
-Bandera
Liked 3,797 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Zeus 2000 Pista crank:
Same bike this year with lower-geared TA crank:
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
No crankset thread is complete without a Viscount pic.
Likes For Pogliaghi:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Thanks for this thread. Well-timed, as I got these two recently, and no idea yet what to do with them.
Steel, A. Duprat Universel:
Duralmin, unknown maker:
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Forgive me for going low- brow -- LOL, but you DID ask for pics of cranksets (The early cottered cranksets that are pictured in this thread are a bit before my time -- but I sure like looking at them )
You also mentioned single ring set-ups ---- I'm sure this isn't what you had in mind, but it is "interesting" ---- was on a dedicated time trial setup -- all I cared about was getting a bigger wheel on there -- the QBP ring does not fit the spider very well at all, --- but for a privateer TT effort, -- this helped to haul the mail for a flat course
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
Was wondering/hoping this would come along.
I kinda did the same. The thread was up a while so I posted a ton of cranks to catch it up. hahaha
Thats not fair. Kinda like saying, take a look at the ring on this naked chicks hand.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The drive side crank on my Fothergill is marked CONSTRICTOR while the non-drive side is marked BSA (with the classic BSA pile of rifles logo). Both made by BSA, they appear to be a matched set; 6 1/2" arms with the same profile, same deep flutes on both sides. The chain ring is only marked 46. This is a typical crank on higher end English bikes of the 30's-40's. It has a five pointed star like a Stronglight, but it's a very different design; note the five pentagons.
The Williams 1200 was their top of the line model, very thin arms, forged spider. This is a lighter crank than the Constrictor above, but I'm not currently using it because the arms are 6 3/4" which is a bit long for my taste. Arms fluted on only one side.
It has the same bolt circle as most continental 3-arm cranks, such as this Magistroni. But the Magistroni is inexplicably heavier (and it's not just the extra ring)
My oldest cotterless crank is this Stronglight 57, from about 1958-9. The design is pretty similar to the Stronglight 49D:
But lately I've become fond of the SR Custom 3, made for a short while in the 1970's.
It's "melt forged" which is a pretty cheap manufacturing method, and I think results in a less than perfect finish, but it's well designed and the spider is small enough to take a 27t ring. Until recently the 86 mm bcd rings were unique, but now FSA makes a line of cranks using this same bolt pattern, so a limited range of replacement rings is available. The inner ring shown here is an FSA stainless steel one. I think of it as the cheapskate's Rene Herse crank. Speaking of which, someone has to post one of those, but it won't be me, since I don't own one. What about it, @gugie?
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 7348 Post(s)
Liked 2,464 Times
TA arms with Viscount (Lambert) ring.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
1960 Agrati. Like the Magistroni shown earlier in this thread, its drive side arm and spider were made out of a single piece of steel, rather than being swaged together.
Mine has the 3-to-6-bolt Simplex adapters and aluminum Simplex chainrings. (58(!)-45 shown -- I have since obtained other ring sizes and plan to use either 49-46 with a 6-speed freewheel or 49-45 with a 5-speed. 45T is the minimum in this 6-bolt pattern, which may explain why 52-45 was so popular on French bikes for many years.)
