View Poll Results: which grease
fluoro
11
55.00%
axle
9
45.00%
Voters: 20. You may not vote on this poll
record hub overhaul
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
record hub overhaul
Poll:
You're overhauling a set of Record hubs which haven't been touched since the early 90s. In the shop you have Finish Line fluoropolymer grease, and automotive axle grease. Which do you prefer?
Edit: There was a poll attached. wtf?
the poll is there. I usually use what ever i have available. right now i have a tube of "garage door grease" i am using. I am partial to Phil Woods grease though, but I am out. You can always buy the extra good Campy grease! I used to use that when i had Campy hubs and other non sealed bearings.
Quoted: 1607 Post(s)
Liked 2,216 Times
I have a beat up Campagnolo container of grease that is still good and not separated from 1973. I only use it on Campy equipment, otherwise I use Phil Wood's.
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
Park grease is not terrible, but I am a long term Phil user.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Is the Fluoro grease also good for my teeth?
I still have some Phil left, so that's what I've mostly been using in hubs (& BB). Some have gotten some brand of Synthetic I picked up at the auto store. Headsets have been packed with marine grease.
Quoted: 1819 Post(s)
Liked 1,693 Times
I voted for the fancy grease because you say that you have some already. I used to love the smell of Campagnolo grease before mine ran out.
smelling the roses
Liked 901 Times
Hmm. Never used Phil. I have always used axle grease, but bought this FinishLine stuff because my S&S couplers wanted only that. The grease that came out looks like that, only gray. Likely it was just fine. What does Phil grease look like?
I will say that these cones and races are the shiniest I've ever seen, and the first Campy I've ever seen.
The fancy grease seems so light, like there is no body to it. This is what concerns me.
Quoted: 874 Post(s)
Liked 2,287 Times
I use automotive wheel bearing grease and it works well. I did a set of Record hubs with some high tech grease I used on my CNC machines( very expensive!) and honestly I could not tell the difference. I am not a racer so regular wheel bearing grease is great . I also use it on headsets and bottom brackets. Joe joesvintageroadbikes.wordpress
Quoted: 4511 Post(s)
Liked 6,378 Times
I usually use Phil, if there is any roughness, I use axle, this goes for all bearings.
My first cup and cone experience was in high school, new Mizutani Super Seraph came with a beautiful "Mighty" Sugino Mighty Competiton crank.
Dumb azz me let the BB get washed out of the pathetic amount factory grease and nominally compromised the spindle and cups, replaced the bearings, set it up with thick axle grease and overhauled it every month for about six months, slowly increasing the tension each time.
It smoothed out quite a bit and lived on for another 25 years when it was stolen with the Raleigh Super Course it was on.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Shag it, red marine grease, more impervious to water.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Lowes sells white lithium grease in an 8oz tube for $5. Been using that. Reminds me of Campy, and it's thicker than Park.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Fluoro.
Fluorinated grease is a miracle of the universe.
Whichever one is white. Nice feature to be able to see when dirt has gotten into the bearings. Generic white lithium is fine. Finish line will clearly greatly increase your speed though, for only an extra couple bucks.
I used to use campy grease BITD for campy stuff, but it wasn't silly priced. I've also used Phil and Park grease. Whatever, it's just grease.
Quoted: 3464 Post(s)
Liked 2,829 Times
I want lightweight, low viscosity. And fill the chamber 25-30%. No grease oozing out after.
if you are building up for commuting- “waterproof” axle grease- and use disposable Lower tier Shimano hubs.
Quoted: 18373 Post(s)
Liked 4,508 Times
You want a light to medium consistency grease.
So, stay away from some of the thicker greases out there like disc brake hub grease, or some of the red and tacky greases.
I'd probably choose your bicycle specific grease, whatever you have available. My preference is Phil, but I'll use what I have laying around.
Liked 4,508 Times
Oh, in theory you can oil your old Campy hubs. I don't know if anybody does that, but that is what the hole is for.
Morgan Blue Competition Campa is nice and is kind of like the old Campy grease.
Rock n Roll SuperWeb is also really quality grease.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Phil.
It Is Known.
It Is Known.
Same here (kind of). My brother uses the Phil grease (Valvoline?) and I've found it separating on stuff of his that I have overhauled. I still use my '70s Campy grease on my Campy stuff, especially hubs. I also bought a couple of 100g things of Miche grease from a place in Germany, but haven't opened it yet... supposedly the same as Campy. I know miamijim here swears by the DuraAce grease, but that just seemed sacrilegious to me... I also use SuperLube grease.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
My thoughts precisely. I would use the grease I have. I don't know what I have, and I don't know what you have, but if I had what you have, that's what I'd use.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 930 Post(s)
Liked 1,291 Times
Another vote for Phil Wood waterproof grease.
Agree with the Phil Wood disciples
Chris
Crapmaster Emeritus
Chris
Crapmaster Emeritus
Quoted: 472 Post(s)
Liked 1,028 Times
And Polyurea sounds like mixed livestock p p so it's gotta be good, eh?
Quoted: 4559 Post(s)
Liked 2,802 Times
I've used Phil's for years for everything. Never had a problem with it. Never seen a bearing infiltrated with water using Phil's.
But Phil's lacks the buttery, cohesive feel of my Shimano Ultegra hubs with the original factory grease, whatever they use. Dunno if it matters when it's rolling. Hard to describe, but when I spin a wheel on the stand, hubs with Phil's grease emit the slightest "tink" sound of the bearings as friction heats up the grease. But not with the Ultegra hubs and factory grease. Might be lithium, I dunno.
I'm kinda tempted by Rock 'n' Roll's Super Web grease.
Quoted: 1856 Post(s)
Liked 664 Times
This is really just Teflon in the grease. I can’t seeing it being a bad thing. I’m not an expert on greases, but with vintage Record in excellent condition I would be careful. Replacing cones and races is not easy, can’t just buy them at the LBS. But if genuine Campy grease is available, I’d use that if it looks and smells good. I use one called “Red and sticky” because ... the Advance auto guy was selling it to LBS owners.
