New training for me, 5 days on two days off!
Quoted: 1854 Post(s)
Liked 662 Times
In a few weeks I may be starting a new full-time job, but other than that I'm ready to start some regular riding after at least a year in front of the TV fretting about masks and such. I plan to use the rhythm of polarized training as a framework in which to build my endurance and strength - I'll build up to a comfortable level (30 minutes per day) and sustain it for two weeks, then build the duration up 10% per week. I need to train saddle tolerance, fit refinement, aerobic base, and some increased effort , Seiler Zone 3 for 30 minutes. I need not only to train skills and capacity, but to convince my wife to be confident in my bike and traffic handling, et cetera, and settle her fears.
At first my target is to ride this routine for at least two weeks, exercising all of these skills. I expect that achieving the 30 minute hard day will be a challenge at first and perhaps for a few weeks, but I'll do my best, keeping up the effort until it's too hard, than ramp down while heading home. I'll keep slowly extending it until I'm sure I'm good with a full 30 minutes and can repeat it comfortably for the week after that. Continue the 10% growth, AAAnd we'll see about the winter. If I can ramp it up to maybe 7 hours per week outdoor/indoor by the beginning of March I'd feel like trying a metric or a century. If I recall RUSA Michigan usually hosts a 200km at that time of year, or there is one in central Ohio. Also the Ann Arbor club still hosts some longer rides.
I think a pattern like that is better than to train five days in a row doing 10 easy 10 hard 10 easy, for 5 days in a row. I think the day scheme will be easier for me to keep track of, so more likely that I will actually do it. And for the hotter or humid days I can take the slower route and leave the harder route for cooler days.
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
I did something like that last winter, Oct.-Jan, coming off about 6 months of doing nothing more interesting than walking. Worked, IMO. I worked up to 2 hrs. at steady Seiler max Z1 pace, going by breathing, gradually increasing effort (watts) as the weeks went by, some days short, some days long so I didn't overcook. I kept at it until I could do the 2 hours, almost no HR drift, staying below VT1. Took me until the middle of December to be able to do that. Then I added the Seiler Z3. You can't do 30' of Z3. Try 3 X 4 X 4 after a good warmup and gradually increase the three numbers, going for a max of 4 X 8 X 4. I did that for a couple months, then started normal riding, the heck with all that structure, I just had fun, one 40-60 mile hilly ride/month and whatever other work I thought was best to be able to be fast on the long ride.
Results matter
Results matter
Likes For adamrice:
Liked 662 Times
My first sentence said I've been sedentary (really sedentary) for a year. My thought is to use the basic bones of Seiler polarized as a way to do base for a while, starting at a level that feels comfortable right now, add volume incrementally, and bring in some intervals later as I feel prepared for them. I would aspire to do a pattern like yours, but I don't think I'm ready for it at the moment. I hope that in December or January I'd be up to 5 days an hour each, with some interval a few days a week. At that point I think I'll have a better idea what recovery I'll actually need. Metric or a 200k maybe in March or April.
Liked 662 Times
In the 3x4x4, I assume we're saying 3 minutes SZ1, 4 minutes SZ3, 4 minutes SZ1. If that's correct, how much of the 4 minutes SZ3 phase is taken up trying to get your HR up to LT and beyond? Outdoors, I would see charging up my "mountains" as hard as possible until reaching SZ3. Do I have this right?
Liked 1,938 Times
Reading some of the papers on Seiler polarization, it looks like his Z3 (SZ3) begins near LT, so ... it should feel pretty difficult. I'm used to I would certainly have some SZ2 as I ramp it up from SZ1, and perhaps that is just part of doing intervals. I pedaled some SZ1 (metered by RPE) yesterday and it is comfortable. Going up to SZ3 will be unusual. On my Wahoo I need to do spinup pretty often, and it did not feel too hard, but would be hard to sustain. I think charging up some of our Southeast Michigan Alps would be a better way to get in those miles.
Got that? The concept is simple, but the application is not so simple. I assume you intend to do your workouts, including intervals, on an indoor "dumb" trainer, that is a trainer with no output measurements other than speed. Finally coming around to the answer to your question, on the bike you want to use power or its analogue speed to determine what zone you're in. If you want to be in Z1, you stay at or below VT1 while observing your speed and HR. The Z1 endurance goal is to hold VT1, speed, and HR steady, i.e. little or no HR drift when holding a constant speed. The goal during an interval effort is to hold speed (power) steady and arrive at VT2 and your Z3 HR at or before the end of the interval. The application of this theory takes a good bit of practice. You'll have to guess at what your RPE and speed should be in order to reach VT2 and go over threshold HR during the interval. Takes practice.
Outdoors it's exactly the same. Indoors you have the advantage of being able to hold a constant speed, knowing that you'll also be holding a constant power. The same thing is true outdoors IF the hill (or flat) you are using for your workout is at a constant gradient. IOW, you also can go by speed outdoors to enable you to hold power constant. Using HR to do an outdoor workout, one guesses by RPE how fast to go, then holds that speed, working hard enough to bring breathing and HR up into Z3 and holding that speed for the interval duration. If you can't hold the speed, you guessed wrong, back off until you can hold it and observe the speed. Similarly if you don't come up into Z3 go harder next time. Next interval, start off at the speed you've established, see if that works perfectly for your interval goal. I observe how far up the hill I got during the interval. On succeeding intervals, I will hopefully reach that same point. If you're going by HR rather than speed, eventually, maybe 4th interval, you'll fall short of that distance because your power has dropped off due to HR drift and quite possibly exhaustion. If it's the latter, you're done, if it's the former, try another interval or so.
By how you might have realized why so many riders have gone to riding by power instead of HR - it's way simpler and easier! Not necessarily better, as there a reasons other than ease of application to go by HR. Though you'll probably find that HR will vary some from day to day at the same power or speed, during an interval set it's quite useful as even that day-to-day variation contains information on your fitness..
Results matter
Results matter
Liked 1,938 Times
He's not intending to ride any threshold intervals. He's using Seiler's and the European zone system of 3 zones. His week will consist of Z1 rides and 1 or 2 days of warmup and then Z3 intervals.
Results matter
Results matter
Liked 1,938 Times
Results matter
Results matter
Liked 662 Times
I really like what Carbonfiberboy said he did, to work up to a very comfortable (no heart rate growth) 2 hours a day before adding the SZ3 stuff. Sounds like base training to me!
Adam, thank you for sharing your plan, but I'm starting at a level that is quite a bit behind you. Plus my age is not a low number.
Liked 662 Times
I should mention that it's entirely feasible to do polarized training outdoors. Once one can ride the trainer is a steady Z1 for say 1.5 hours and also do Z3 intervals, one can go on long outdoor rides holding it to Z1 with gearing, and attacking every hill, not all out, but at a hard pace which will produce steady panting. Works great. One will also experience a good bit of HR Z2, but that's OK. The idea of mostly using Z1 outdoors is to allow one to maximize the amount of Z3 one can accomplish. It's the training at the high end which really increases one's average speed on a ride. It is said that high end training drags all one's zone boundaries up.
Liked 662 Times
No worries, Adam, tthanks!! Looks like you gave yourself the dopeslap, so no reason for me to do it as well! No worries, except for the actual riding!
As far s the plan goes, certainly several different ideas were under discussion.
