26" rear wheel for 700c road bike on a trainer?
Quoted: 753 Post(s)
Liked 737 Times
Any reason not to use a smaller diameter wheel on a trainer? I've got an aluminum Trek 1200 with out a rear wheel, but have a bunch of 26" wheels. I was going to mount a dumb trainer on a homemade rocker board so the bike will be pretty high up. I'm pretty sure "pedal strike" will be a non issue.
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Zwift doesn't really care what kind of bike you ride as it calculates your power based on how fast your pedaling but this probably would vary based on whether you are using a smart wheel on/wheel off trainer or a dumb trainer. If you are using a wheel on trainer the tire you use might also have an impact on the numbers you produce on Zwift.
I'm sure there's a more detailed analysis out there somewhere if you were more interested.
Quoted: 4403 Post(s)
Liked 4,856 Times
Quoted: 18375 Post(s)
Liked 4,510 Times
Find a narrow tire so it fits between the stays.
Quoted: 4234 Post(s)
Liked 2,949 Times
If you're using a dumb drainer without a power meter, be sure to get the wheel diameter put in their correctly as the power estimation calculations will be based on speed of wheel rotations, and that'll be different for differently sized wheels.
