sebaceous cysts in perineum at base of scrotum
Quoted: 1163 Post(s)
Liked 442 Times
I managed to not get major saddle sores this year by working my core much more in yoga classes and body works classes at the gym. This has helped me to deploy preventative measures that have help reduce constant perineal pressure. Using better hygiene in that area along with clean bib shorts (or bib tights) that are fully pulled up and not pinching - all of these measures got me through 2021 with better results than last year.
Last year I was calling the condition "Perineal Nodular Induration" - which is my internet self diagnosis. A urologist who examined me said I had a bad sebaceous cyst.
I healed 2 of them up over the winter and as the inflammation went down, the hard as a rock quality got better - the inflammatory process quieted, the hard grape softened....
But now I have a new hard grape, fortunately this one is slightly further out of harms way. in the center of the base of the scrotum. I have been washing my perineal area with warm water and soap and drying the area before donning my shorts to try to keep the area really clean. It is not terribly painful but the hard grape is still there. I plan next to try last year's trick which is to place a slice of fresh Turmeric root directly over the sebaceous cyst and cover the area with tegaderm for as long as I can keep the Turmeric in place. My theory is that the antioxidant properties of the Turmeric root can topically apply their magic by capillary action which can then soften the inflamed nodule and thus allow it to send a stuck hair to the surface and not necessarily drain but soften and reduce in size.
Just thought I would share a work in progress and my apologies if my descriptions are nasty.
Likes For tyrion:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I get little rocks down there some times. I imagine going to the doctor and having someone squeeze my soft bits and diagnosing nothing. So far they always go away on their own, but they're probably cysts.
Quoted: 1609 Post(s)
Liked 2,589 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
At the risk of being a killjoy, I've never found any traditional, homeopathic/naturopathic, folk remedy, etc., solutions that effectively treat cysts, boils, warts, etc. Tried several, no results. I suspect that at most the lubrication reduces the chafing a little while the area heals naturally at its own pace, but lacking other medicine folks convinced themselves about the efficacy of some drawing salve or poultice.
I use Walgreens brand moisture barrier cream for occasional saddle sore ouchies -- usually ingrown hairs or chafing from a seam or wrinkle in my shorts on a long sweaty ride. The Walgreens stuff comes in a large green tube, usually found in the "seniors" aisle for folks who are incontinent and spend a lot of time in a wheelchair, nursing home bed, etc. I got it for my mom at first as her condition declined. But I discovered it works great for the usual saddle sores.
It's mostly zinc oxide, which is very persistent stuff and isn't easily sweated out or washed out -- it takes some hand scrubbing with a strong detergent such as Fels Naphtha bar soap to clean out the whitish cream. It has some useful added ingredients, mostly for topical pain relief: menthol (very mild, no stinging against sensitive skin) and a few other things. The many other ingredients are not listed as "active ingredients" and are common to many folk remedies, so it's basically a "natural" ointment made more effective with zinc oxide and menthol as a topical analgesic.
It's also great for really painful hemorrhoids, although a sitz bath in warm water with Epsom salts works even better. So try those leisurely soaks in a sitz bath for ingrown hairs, cysts, etc. When the solution is strong enough to make your fingertips wrinkly -- usually one or two cups of Epsom salts per bathtub -- it's effective at reducing swelling in the nether regions.
If the knotted spot was persistent and uncomfortable in any seated position, I'd consider shaving the region (with an electric shaver -- safer and gets close enough) and using Dr. Scholl's Moleskin or comparable adhesive padding. The trick is to cut out a circular area to allow the swollen area to peek through, while the raised area created by the moleskin or bunion type bandage to relieve some pressure. After the swelling decreases soak the bandage, use rubbing alcohol, etc., to gently dislodge the adhesive. Usually it just peels off on its own after a couple of days, depending on the person's perspiration, skin oil, etc.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
The use of the term "magic" seems interesting, I really hope you don't hurt yourself further using undocumented treatments, I'm pretty sure there are different biological processes at play there.
My father suffered a few sebaceous cysts, albeit on his back, but they were very painful and you have my sympathy. As always, the best option is to follow a GP's advice. There may be a surgical procedure that'll provide relief. Applying turmeric? I have my doubts.
My second bout with something like this needed local anesthetic, and minor surgery. The surgeon said he might need to clean up the sebacious glands in the area if these keep forming. It's been a couple seasons since that interaction. While unpleasant, it was way better than a prostate biopsy. (or 4)
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
You may recall that I also had a PNI a couple years ago. I went to a dermatologist who also diagnosed it as a sebaceous cyst. Misdiagnosed, that is. He injected a steroid into it which basically melted all the flesh in the area and which hasn't healed completely in 2 years and may never recover from his treatment. He told me originally that the injection would cause the cyst to open and discharge its contents in a week and everything would be fine. Wrong. Thus I'm very wary of that diagnosis. I think surgery would have been a better option. Mine was much larger than a grape, maybe 2" long as 1/4" high. But who knows what the thing behind you scrotum is. Not a PNI anyway. Mine was from an imperfectly fitting saddle and I'm guessing just plain age. The best thing I treated my post-op injury with was a hydrocolloid dressing.
Results matter
Results matter
Quoted: 1068 Post(s)
Liked 784 Times
Expired Member
Quoted: 3665 Post(s)
Liked 5,417 Times
Just have the dermatologist cut it out. I had one on my neck that annoyed me for years. Quick and painless to have it removed, half dozen stitches.
Liked 442 Times
I asked the dermatologist if he would. I think if it had been on my neck they would have. But mention your private parts and then they are not real keen on cutting you down there - they sent me to the urologist and the urologist wanted to send me to a surgeon - frustrating.
Likes For masi61:
Liked 442 Times
just an update. Maybe it is because I am not putting in the heavy duty outside miles or I would like to think it is being helped by my homegrown "poultice" but the 2 hardened nodules are diminishing. One of them is currently mostly undetectable. I believe that the duct is still there, it just is no longer inflamed so it is now soft. The other one has reduced in size no longer the size of a plump grape, now more like a hard raisin.
I plan to continue to my "poultice" of a slab of turmeric root buttered with Manuka honey and held in place with a large bandaid.
Likes For masi61:
Quoted: 819 Post(s)
Liked 1,654 Times
Likes For Bald Paul:
For Frieda!
I get abscesses in that region too from my saddle, the worst part about it is that once they happen, they’re likely to recur. Such a pain in the butt — which actually the guy in the other thread has a version of (and I’d prefer that one). Hang in there and keep us updated on the progress!
Likes For HelenP:
