My sprocket size and ratio research.
#51
Quoted: 790 Post(s)
Liked 348 Times
By coincidence I was looking in a book on bicycling from 1982 with a lot of technical information in it and it did state that if you have a large set of sprockets and a small set which both give the same ratio, the larger diameter set will put less tension and wear on the chain, which would also give the lower friction one member responded with above.
As far as crank length goes for cyclists, lots of individuals have opinions, whether they have a lot of experience with cycling or not, they are still individuals with opinions. I have no opinion on the subject, just passing on what the laws of physics and engineering say about it. There has never been a scientific research done on the length of bicycle cranks using riders of different sizes, they have all been done using the same cyclist/s testing different length cranks, not different length cyclists testing the same or different cranks. So outside of what engineering and physics have to say, I will never be interested in individual opinions on the subject, at all.
Likes For beng1:
#52
Quoted: 790 Post(s)
Liked 348 Times
On the whole, being large and tall is a disadvantage in cycling. For similar level of training, W/kg scales with an exponent of about 0.7. The work against gravity when climbing obviously scales with an exponent of 1.0. That’s why smaller, lighter riders tend to be the ones who are the fastest climbers.
Larger riders have a smaller relative advantage on level ground, since the increase in frontal surface area scales with an exponent a slight bit less than 0.7.Otto
#53
Quoted: 140 Post(s)
Liked 72 Times
Ask me how I know.
em
#54
Quoted: 4403 Post(s)
Liked 4,856 Times
As far as crank length goes for cyclists, lots of individuals have opinions, whether they have a lot of experience with cycling or not, they are still individuals with opinions. I have no opinion on the subject, [b]just passing on what the laws of physics and engineering say about it. [\b]
#55
Quoted: 140 Post(s)
Liked 72 Times
Sheldon Brown was right about most things, and he was right about gear ratio and crank length, however poorly he explained it. Crank length is a personal preference, and even riders with identical body dimensions may want different cranks, dependong on the strength or flexiblity or training. But really, cyclists obsess over the difference between 170 and 172.5. The difference between 165 and 180 is only 9%, or less than one gear change.
Get over it.
em
Get over it.
em
#56
Quoted: 790 Post(s)
Liked 348 Times
Not around here in Upstate NY. Most races at all levels are hilly road courses. There hasn't been a sanctioned TT or even a crit in years. Even club rides become competitive climb fests. Gravel rides are the new big thing here, and small guys have even more advantage because descending speed is limited more by road conditions than aero drag, which makes it harder to close gaps. Big guys are definitely at a disadvantage.
Ask me how I know.em
#57
Quoted: 140 Post(s)
Liked 72 Times
Guys going for a GC win don't risk crashes to take sprint points, and they don't waste energy going for KOM. Those things are gifts to rookies and second tier riders. Wallk around the start of any pro race and you'll see that they're all small guys.
Maybe learn something about racing before you comment on it.
em
#58
Quoted: 790 Post(s)
Liked 348 Times
Sheldon Brown was right about most things, and he was right about gear ratio and crank length, however poorly he explained it. Crank length is a personal preference, and even riders with identical body dimensions may want different cranks, dependong on the strength or flexiblity or training. But really, cyclists obsess over the difference between 170 and 172.5. The difference between 165 and 180 is only 9%, or less than one gear change.Get over it.em
#59
Quoted: 790 Post(s)
Liked 348 Times
Nice statement, except that any five-year-old can tell someone the same thing, so unless you point something out specifically or add some logic, common sense or facts to your statement, your statement has no more value than that of a five-year-old.
#60
Quoted: 140 Post(s)
Liked 72 Times
em
Likes For eddy m:
