Help! Can’t remove broken RD bolt from hanger.
Hello. I need help removing a sheared rear derailer bolt (the result of shifting gears while climbing). Drilling and extraction bits haven’t done the job. I cannot get through to the other side, either. Can the bolt be removed? And if so, do I run the risk of ruining the hanger in so doing? Thank you and Happy New Year! FYI: This is a steel frame.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Hello. I need help removing a sheared rear derailer bolt (the result of shifting gears while climbing). Drilling and extraction bits haven’t done the job. I cannot get through to the other side, either. Can the bolt be removed? And if so, do I run the risk of ruining the hanger frame in so doing? Thank you and Happy New Year! FYI: This is a steel frame.
ETA: This didn't happen because you shifted while climbing, something wasn't adjusted correctly. People shift in all sorts of situations. And it looks like your photos are flipped backwards, what's up w/ that?
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Have you tried left hand bits, in the hope they'd back it out?
Penetrating oil first?
With extreme care you might be able to drill out the center of the screw, needle file it to the minor diameter, and maybe pick the remaining helix out of the threads with a dental pick or something.
I made an interesting discovery once that an arbor press worked wonders on munged phillips heads - I could use the press to smoosh a bit into the screw and then a wrench to turn the bit and back screw, even though I was backing it out against the pressing force. Not sure that would apply here, though part of the idea of the press is cold flowing the screw head, so smooshing a phillips into what was once a hex isn't out of the question.
Likes For UniChris:
aka: Dr. Cannondale
Quoted: 2151 Post(s)
Liked 3,380 Times
Suggest you use a series of HIGH QUALITY carbide tipped drill bits in successively larger sizes to drill that out.
Then buy a Hanger Saver (basically a nut inserted from the back side) to affix the new RD.
Likes For rccardr:
I like cats.
My guess is that the OP is trying to drill and/or EZ out without first stabilizing the right drop-out on a hard surface, which would be understandable as it's an awkward part of the frame to secure..
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
If you're going to keep drilling use the correct tap drill size as you final drill and use a tap to clean out the existing threads.
https://www.homedepot.com/p/Drill-Am...1-25/304746993
If you mess up the threads use a drop out saver
https://wheelsmfg.com/presses-tools/dropout-savers.html
Got connections find a machine shop or service with a MDM or EDM machine.
https://brokentap.com/services/
Thanks. I can get good purchase on the frame. But, yes, it is awkward.
You should be able to drill through the bolt pretty easily w/ a good bit, I don't understand why this is a problem. Hammer a Torx bit in there.
Quoted: 6100 Post(s)
Liked 4,732 Times
If you aren't experienced, and I assume you aren't since you had to ask, you might just let it be a problem for your LBS mechanic. You do stand a chance of messing up that DR mount and since it's not a replaceable hangar.... well you know.
Likes For Iride01:
Quoted: 835 Post(s)
Liked 1,056 Times
Try penetrating fluid FIRST. Let soak at least 2 days and try extractor bit again. A 50/50 mix of automatic transmission fluid & acetone is about the best penetrating fluid followed by Kano Kroil Oil or PB Blaster is decent.
Thanks. But I don’t keep any of that stuff about.
Quoted: 930 Post(s)
Liked 393 Times
The real question is if I'd try to do all of that on the workbench in a way that would position it under the drillpress...
Have to go see if I can manage something similar on a nice sturdy salvaged rear rack to get what were once battery dock connectors off, one of the 4 screws on each side failed. And my arbor press is a 2 hour drive away. I this case I'm thinking what I'm going to do is maybe try to drill the screws from the back in the conventional direction in the hope that they unscrew.
Quoted: 4172 Post(s)
Liked 3,793 Times
A length of all thread and some nuts will tie the two dropouts together for real cheap.
Given all the paint gauges about the hanger I suspect there's been some "incidents" before. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times
It should be obvious to the most casual viewer he said "flip side" on the photo. Nothing wrong with the photo. And it can happen while shifting while climbing.
We have had this same repair in our shop before from the same thing.
Quoted: 327 Post(s)
Liked 248 Times
In our neck of the woods,, in northern CA, we see a lot of crazy mountain bike repairs. There is a lot of trails where they torture test the bikes. The malady in this thread and others happen. Pedals broken off or bent down from the jumps and stomping down. Bent derailleur hangers are common.
Quoted: 5219 Post(s)
Liked 3,564 Times
left hand bit
straight fluted extraction tool
a proper tap wrench
been there, done that, on my car (over torqued one of the bolts holding my rear hatch on)
EXCERPT: you need new bits, special harder cobalt bits & several because they dull going into that hardened removal tool. a cpl lefthand bits too. then, when you get a new hole in that Easyout (which is stuck in the bolt), or after you drill it out completely leaving just the original broken bolt (with a nice centered hole) then get a straight, fluted, (not spiral) extraction tool, the correct size & use a proper tap wrench to turn it
it took me weeks. good luck!
in the end you want this in your hand
these are my NAPA straight fluted screw extractors. guess I got them at an auto parts store. part # SER 720
https://www.napaonline.com/en/p/SER720
this is a tap wrench to use w the fluted extractors
https://www.amazon.com/Vermont-Ameri...rds=tap+wrench
the spiral tools & so called Easyouts & similar tools are inferior
a hole the correct size matched with the correct extractor allows the extractor to be inserted a decent depth, not just the tip
was so nice getting the new bolt installed
guess I'm not the only person to break an extraction tool inside a broken bolt
https://www.bikeforums.net/bicycle-m...ay-remove.html
a proper tap wrench
SE Wis
Liked 3,361 Times
Due to their hardness they fracture fairly easily. Did this plenty on large $$$ weldments when taps got broken off in blind holes.
left hand bit
a proper tap wrench
a proper tap wrench
Likes For daveed:
Liked 4,732 Times
for considering donation. However if there isn't any that can use that frame, don't feel bad about sending it to the scrap yard. Some think that's wasteful, but scrap yards aren't the final stop. That's were they get sent off to be melted down and become something new for less of a environmental hit than mining ore and smelting it.
