Shimano Nexus 4-Speed Hub - Blocking the Freewheeln
Hello Community.
I owe a Shimano Nexus 4-Speed hub with drum brake and freewheel.
But i need to block the freewheel that the pedals are fixed to the driving wheel.
Does some one know if this is possible or even better has someone a manual how to do this?
Quoted: 1438 Post(s)
Liked 1,088 Times
The "freewheel" you refer to is intrinsic in the design of the hub and cannot be removed.
Quoted: 5256 Post(s)
Liked 1,561 Times
Freewheel IGH hubs can not be changed to fixed wheel mode. The internals of free and fixed IGH hubs a re completely different.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Old fart
Quoted: 3409 Post(s)
Liked 3,014 Times
Converting a Sturmey-Archer AW Hub Into a Two-speed Fixed Gear
You're on your own trying this with the Nexus 4-speed hub, though...
Shopping solution : You want the S-A S3X* in the rear wheel if you want a 3 speed fixie..
sell your rear wheel buy another.. shifter etc , whole kit.
*https://www.sturmey-archer.com/produc...d/3/id/47.html
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 9 Times
I kinda like the shimano IGH-4's. If you also have a shifter I might be interested if the deal is good enough
Quoted: 7093 Post(s)
Liked 2,006 Times
@rhm intuited that my S3X is probably a 5-speed hub with a few differences to make it fixed, and the consequence is that it's only a 3-speed.
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
More generally, IGHs can generally only gear in one direction (i.e. above or below direct drive) if they're fixed-gear, which is why the new S3X fixed hub, the old SA ASC fixed hub and my ancient SA TF all gear down from direct drive only. That 4-speed has direct drive somewhere in the middle, I believe, and as such couldn't be converted to fixed-gear even theoretically without losing at least one gear. SA AW hubs can be converted to fixed-gear, but again, you lose the abilty to gear up, so they become two-speeds.
S3X is .. 1:1 for high, .75 and .63 for second & low yes those are the lower 3 gear ratios same as 3/5 ths of the 5 speed.
the driver splines are also threaded so a freewheel can be screwed on later, if you change your mind & want a freewheel hub again.
Quoted: 147 Post(s)
Liked 7 Times
Go S3X if you want a fixed gear hub. Its quite enjoyable and you can adjust your fixed cadence depending on headwind resistance or to get more out of pushing yourself to your limit.
Senior member
Quoted: 911 Post(s)
Liked 539 Times
It is. I've seen a diagram of how it works. Some of the components are lifted straight from the new wide-range SA 5-speed (including the right-hand ball ring, which has a completely redundant ratchet face on the inside as a result of that fact)
Hopefully, this explains it better than drawings can.
https://www.youtube.com/watch?v=AJmUds2YQ74
flippin_bikes
Singlespeed & Fixed Gear
3
09-08-11 05:29 AM
greensprout
1
02-24-11 12:05 PM
