Need New Shifter Cables
My levers are 1970's-era Campagnolo Nuovo Record.
Which shifter cables will fit (the barrel end)?
Who makes good cables these days?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1078 Post(s)
Liked 1,801 Times
honestly, there are issues with newer derailleur cables.
With today's technology, they are both thinner, stronger and less resistance.
The problem with that, is our vintage stuff was designed to take thicker cables with less "slick"
I go to the local co-op and grab from the bin. sometimes its $1, sometimes they say, "get outta here"
Bring a lever with you, but most cables come with two ends and you cut off the wrong one for your bike.
"Leave the gun. Take the Colnagos."
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 971 Post(s)
Liked 624 Times
I dunno; last time I needed a Huret-style end cable, at the LBS they rummaged around and "this is the last one". This won't impact the OP, as Campy/Shimano/Suntour end is prevalent.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
So, the modern barrel ends do fit the old Campagnolo shifters. That's good to know because I was planning to order online but don't want to by incompatible parts.
The shifter cables I have do seem very thin. Several strands actually wore through or broke somehow and I am probably headed towards a broken cable (bad). I want to replace them before that happens.
We don't have any co-ops around here. We barely have any bike shops that aren't sales outlets for ebikes and beach cruisers. Performance is long gone. Bikecology is gone, Ted Ernst is long since gone,... The last brake pads I bought came from Europe (England, IIRC).
Edumacator
Quoted: 2433 Post(s)
Liked 3,106 Times
https://www.amazon.com/JAGWIRE-Slick...%2C177&sr=8-12
Quoted: 3490 Post(s)
Liked 2,909 Times
I'm looking forward to trying the Alligator 31 strand cables. They look to be of very high quality.
Likes For smd4:
My shift cables are not inside a housing.
Does anyone know what wire diameter to look for and what to avoid as too thin?
Liked 2,909 Times
Quoted: 1872 Post(s)
Liked 692 Times
I think we're over complicating things here. Campy shifters of that era used a slightly smaller barrel end on the cable. If you just buy a regular cable these days it'll likely have the larger Shimano barrel size, and then you have to file it. Look for Campy compatible cables and you'll be fine.
An example: https://www.ebay.com/itm/22391471451...3ABFBMpuP11Yth
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Quoted: 1607 Post(s)
Liked 2,213 Times
I believe the shift cables today are 4 mm vs C&V at 5. Smaller housing too.
RD still requires a housing to get from the CS to the RD
Liked 2,909 Times
Liked 2,909 Times
I get that. And if you need to have the name brand, you just have to pony up. But the OP seems like he's looking for any cable that'll work. And there are many that are a lot cheaper than $30 for a single cable.
Liked 2,213 Times
I would not pay $30 for a single cable regardless. My $s were for brake and shift cables with housings and ferrules'.
Liked 2,909 Times
Oh, right, that makes sense. The OP says he doesn’t want to pay $30 for a single downtube shift cable, which seems to be out of the realm of reality—even including a foot or so of housing.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,454 Times
The shift cables I buy for my vintage Campy are $1/ea on eBay (shipped with tax).
https://www.ebay.com/itm/17536390288...Bk9SR6D1uNeLYQ
Likes For SurferRosa:
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
I'm not familiar with Campy gear, but I thought barrels were for MTB brake cables.
Note-I too buy in bulk from China and average a buck a cable for stainless- both shifter and brake. I get my housings in 3 meter lengths for around 5 bucks.
Liked 2,909 Times
Is there an accepted term for the bit of pot metal at the end of a shift or brake cable? I've never heard of "barrels." Lugs, maybe?
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
I can't get the image to load w/pics and names of all the different ends. Campy's are slightly different though from Shimano
señor miembro
Liked 6,454 Times
https://www.ebay.com/itm/392825985680
Liked 2,909 Times
Likes For smd4:
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
FWIW, I've converted standard "in-line barrel" cable ends to functional Huret disc-type cable ends by squeezing the barrel in a vise until it fits into the slot on the Huret shifter. Often, a little touch-up with a file is needed to get the proper fit. It seldom takes more than a couple of minutes altogether to modify the cable end.
Likes For JohnDThompson:
Quoted: 500 Post(s)
Liked 466 Times
From my favorite source. Note the Campagnolo-specific shift cables in two lengths - $13 for 2.3m, $18 for $3.1m, plenty in stock:
https://www.universalcycles.com/shop...&category=4385
Edumacator
Liked 3,106 Times
For very old shifters you have to file a bit of the barrel even with Campy ones...I think.
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
Yesterday, I couldn't find brake cables that cheap on eBay. Got a link? I needed a couple and just bought a Shimano kit with housing for $10.
mycocyclist
Quoted: 909 Post(s)
Liked 811 Times
Likes For machinist42:
