SRAM 11spd 32t Cassette
Bikes: Dave Kirk Custom, Clockwork Bikes Custom, Batavus Course Specialized HardRock x2 Trek 700 MultiTrack 1991 Trek 950 SingleTrack. Miyata Three Ten
Quoted: 32 Post(s)
Hi,
I was looking at the SRAM 1190 cassette 11-32t and noticed it says that 32 and 34 tooth versions are compatibile only with wifli and 1x derailleurs. I have a Shimano Ultegra RD. Would they just not work together?
Thanks!
Jon
Thanks!
Jon
Quoted: 1455 Post(s)
Liked 1,477 Times
It should be fine with an Ultegra RD.
I run a SRAM PG 1170 11-32 with Shimano GRX 810 RD and it works fine. I think the XG-1190 is just a fancier/lighter/more expensive version of that.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You haven't told us which Ultegra derailleur you have...and that makes a difference. Which model? SRAM is only going to say which SRAM derailleurs the cassette will work with, they won't ever mention Shimano in their details/spec.
Likes For cxwrench:
Quoted: 32 Post(s)
I have not actually bought it yet. I have Dura Ace 9001 shifters and was looking at the R8000 RD.
I suppose what matters in this case is the gear capacity of the RD you're using. 11-32 is 21 teeth. But if it's on a 34-50 double, you'll need 16T more take-up for 37 teeth total.
Quoted: 32 Post(s)
That is my thought. I thought sram built to shimano specs, but wasn't sure if things had changed.
Bikes: lots
Liked 2,932 Times
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I think 36T would be pushing the limit as the RD is rated for a 32T max.
