Downtube shifter 31.8 mm
Quoted: 253 Post(s)
Liked 223 Times
Hello,
I was about to transplat my clam-on style downtube shifters (suntour something) from my old mixtie to my "new" commuter, but it seems the diameter of the downtube is too wide to properly screw it on. Were 31.8 mm tubes not common "back in the day" and do I have to get an adapter, or can I get some other older style clamp-on downtube shifter which would fit that diameter?
thanks!
P!
thanks!
P!
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
31.8mm downtube tubes were not common "back in the day" when clamp-on downtube shifters were common.
consider switching to bar-end shifters. they are much easier and safer to use.
there are usually a few 31.8 clamp-on downtube shifters on ebay, but you will NOT like the prices.....
Likes For maddog34:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Hello,
thanks!
P!
thanks!
P!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Yeah I would have to agree on using bar end shifters or if you are really wanting to step up get the Gevenalle shifters. They combine a standard brake lever (for short or long pull or hydro) with a bar end/downtube shifter at the front and they make a version sans shifters if you want to run your old Suntour shifters. They are fantastic and combine the old school reliability of the DT/Bar end shifter and brake lever separate with the convenience and safety of the modern STI/Ergopower/Double Tap lever.
This is probably what you would want: https://www.gevenalle.com/product/audax/ but feel free to explore.
Quoted: 253 Post(s)
Liked 223 Times
First off, kudos for sticking with downtube -- OK, it's antediluvian tech but some of us stick with it. I swear I've seen handmade bands on eBay, but I presume you are looking for something like THIS?
Quoted: 253 Post(s)
Liked 223 Times
Quoted: 253 Post(s)
Liked 223 Times
Clark W. Griswold
Liked 3,958 Times
I have one bike with DT shifters now and honestly I don't ride it much. It is a pretty bike and I love staring at it but I think I might seriously want to add the Gevenalle and ruin the aesthetics minorly to improve the useability of the bike. It would suck but I have had my time staring at it and want more time riding it.
Quoted: 253 Post(s)
Liked 223 Times
Nope go with the Gevenalles they are a better product in certain ways. Your brake lever is a brake lever, your shifter is a downtube or bar end shifter they are mated together but are not totally integrated. STI levers are neat pieces of kit but I don't like them because I like a brake lever that is just a brake lever but I like the fact I don't have to move my hands to shift and brake and the same is true for Gevenalle. However with the Gevenalle I get the reliability of everything as separate pieces and in my case was able to keep some Dura Ace DT shifters (which I will admit are not ideal for the build and they mentioned that because they angle a little different).
I wanted to reuse the dt-clamp but, as stated in the first post, only noticed too late, that the downtube was 31.8 and not 28.6 (not a huge loss with a 40 € bike, but still annoying)
Quoted: 3497 Post(s)
Liked 2,911 Times
Hello,
thanks!
P!
thanks!
P!
https://www.ebay.com/str/paddythepeddler
Clark W. Griswold
Liked 3,958 Times
Respectfully disagree. I can get a pair of older STIs for like 50 USD/EUR but Gevenalle are a lot more expensive (not to mention, as i am in Europe they are bascially non-existent here). I use STIs on a few of my bikes and have no isses with the shifting mechanism and i want to be as thrifty as possibly with this and mostly plan on reusing parts from my existing bike.
Liked 739 Times
since you've convinced yourself to stay with the downtube shifters, i won't bother explaining bar-end shifter advantages to you.
You need to find a local Bicycle RECYCLER/Co-op, and hope they have a 31.8mm clamp DT shifter set in their stock... anyone else will be wanting to get top Dollar for one.... or Euro... or whatever currency you use...
Quoted: 4792 Post(s)
Liked 3,918 Times
No help here on the 31.8 dilemma. I have two bikes that are probably 31.8 but one is a fix gear and the other got "braze-ons" for DT shifters when it was built. (In quotes because its a welded frame.)
DT shifters - yeah! Dangerous? I suppose but I haven't seen that crash in 100,00 miles so I'll keep pushing my luck. (I love that they accomplish the impossible. Light, cheap and reliable as all get out. More aero too.)
Sorry, I haven't had your challenge yet. If I'd seen it, I'd have an answer for you.
Re: bar ends - I'll never go that route because I've hit the handlebar end too many times with my knee/thigh. I can imagine 1) the bar end getting hit a lot more often than the bar itself being closer, 2) that impact perhaps not being fun and 3) the resulting shift perhaps being unwanted. Never mind the potential for that shifter breaking when the bike falls over. (I've also seen a few expensive brifters trashed in crashes. My racing days - trashed brake levers were just the cost of doing business. Most worked just fine post crash. Never damaged a DT shifter, ever.)
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
One solution to the “bar ends make the bars too long” issue is simply to use a pipe cutter to trim off 1/2” (or more) from the ends of the handlebars before installing. How often do you ride with your hands on the very back ends of the drops anyway? 😉
Likes For ThermionicScott:
Liked 3,918 Times
I'd have to cut the bars back the full length of the shifter.
Quoted: 253 Post(s)
Liked 223 Times
Ahh did not know you were in Europe...that does complicate things more but yeah the shifting is fine, it is the braking that bothers me. I like my brake lever to just be a brake lever I don't like it also moving to shift that is why I loved Di2 and the Gevenalle stuff. STI levers for $50 could be a screaming deal or completely fubar'd I actually have a pair of 8 speed Tricolor levers that I did bring back from the near dead but it took a lot of work and cleaning to get them back and they still aren't great but they shift decently enough (nowhere near like a new one would). I do get the parts bin idea my favorite bike came heavily out of my parts bin and a co-workers. But I did it with trigger shifters as a flat bar/alt bar set up because I had enough drop bar bikes but nothing flat anymore now that has changed.
I feel like my cheapest-no-faff-option will likely be some form of bar end shifter to use most (if not all) of the existing stuff on my donor bike. What "vintage" bar end should I be looking for, if I want friction, seeing as most of the modern offerings only do indexed?
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I have a pair of 6500 STI levers that are in very good shape, also a pair of 4500 that are lightly used and look nearly new. Prices TBD. PM me with interest.
Clark W. Griswold
Liked 3,958 Times
I should maybe clarify, that the 50 € were for one shifter only - (the right one). As this is going to be a commuter. (Personally, i would love to use some 105 STI ST-5500s if I could get my hands on them for cheap, since i already have the RD). I will be going 1x so a FD is not required.
For friction I would do probably the Dia-Compe ENE Bar end shifters I hear they are quite nice but you can also use just about any Shimano and possibly Microshift Barcon in friction mode. If I wanted the ultimate set up probably an old Suntour or Campagnolo shifter would be the dreamiest but I don't know enough to really say those will be great in your situation as I am unsure if at least the old old Campagnolo would sweep a cassette or 8-10 speeds as I have not had the pleasure of actually using one. SunRace also make a shifter and I know Rivendell sells them individually but not sure on getting them in Europe. There is also a slight possibility that maybe you can find a shifter pod that can use your DT shifter on it but that would probably be best asked in C&V as I know bits and bobs enough to be helpful in a shop for most folks but not a ton of full compatibility and odd stuff like that to really give you the proper answer.
Quoted: 253 Post(s)
Liked 223 Times
Still pretty cheap.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
If your clamp-on shift levers are compatible with standard square-base braze-on mounts (many, but not all, are), something like this will work:
https://www.jensonusa.com/Problem-So...-Shifter-Mount
Quoted: 836 Post(s)
Liked 1,059 Times
Check out these. https://www.bricklanebikes.co.uk/via...-shifter-mount
Quoted: 977 Post(s)
Liked 626 Times
I wonder if, in a commuter/college application depending on where the bike is parked, if downtube shifters might (marginally) act as a theft deterrent? There might be a generation of younger would-be thieves that would shy away from them. Then again, maybe not.
In a very different application, I recently used one of those -- not the prettiest design but it certainly works.
