A bit of a problem.
A bit of a problem.
I'm running new old stock Saturae rims laced to Campy hubs with new spokes. I went out for my first ride on it today on the local trail. There are a few rough spots on the trail and I tried to be as careful as I could, but I noticed halfway through the ride that the rear wheel went out of true. I'm running 700x23 tires. My questions are as follows. Are these wheels just not strong enough for my weight (225lbs) and the type of road conditions? Should I go to 25mm tires and run 100 or even 95 psi?
Quoted: 4195 Post(s)
Liked 3,837 Times
Which version? IIRC Saturae offered a few models. One much like a Mavic Open Pro and another an aero shaped thing. All were pretty narrow in their internal widths.
At your weight I would suggest running wider than 23mm tires. At least 25s and if 28s fit all the better. The only thing skinny tires do better, then wide ones, is to feel quicker. But perceptions are not reality often. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
This is the rim.
Quoted: 4224 Post(s)
Liked 2,944 Times
Did you build them up yourself? Stress relieve them properly?
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Likes For himespau:
I did not build them myself. They came on the bike I bought a few days ago.
Liked 2,944 Times
OK, it's just that, when I hear of new rims laced to hubs and then they go out of true on the first ride, I always come back to the thought that maybe they weren't stress relieved properly and a proper stress-relieving and retruing might make them hold true for thousands more miles. Not that you personally wouldn't skip the stress relieving step, just that I know that I might not do it as thoroughly as a professional wheelbuilder might. Trying to find something other than the rims to say is the problem (and give hope for an easy solution).
Expired Member
Quoted: 3654 Post(s)
Liked 5,392 Times
Another vote for an improperly built wheel. At least try correcting it before giving up. Agree a wider tire would be more appropriate if you have clearance.
Likes For shelbyfv:
Any guesses on the likelihood that having them trued by a master wheelbuilder will correct the problem?
Really Old Senior Member
I too think the wheels were built with uneven tension.
Assuming the front wheel is also built by the same "builder", it'd also be suspect.
IF it's a "standard, non disc" front, all spokes should have identical tension, since there is no dish like a rear.
PLUCK individual spokes and compare the tone to other spokes. If you can tell a noticeable diff..........
aged to perfection
Quoted: 829 Post(s)
Liked 1,241 Times
you might not need a master wheel builder but someone with experience in wheel building will be able to improve the situation
I don't think the situation is terminal. By riding them you are doing the strain relieving on the bike haha
just take them to a shop that you trust with a good service dept.
/markp
/markp
Likes For mpetry912:
Possibly it's just a photo "aberration"?
Since the wheel is "out of use", back off all the nipples to the 1st thread showing.
That will also give your "repairman" a consistent place to start. (you might want to take a few pics from different angles & distances in case they want to know "what it looked like before")
If there aren't any noticeable "kinks", you're probably good.
IF it's hit hard enough to "stretch" the metal......
Quoted: 5766 Post(s)
Liked 2,538 Times
Weight alone isn't an issue. I toured on light wheels with 25mm tubulars for years and never had problems. Note, that I've never babied my bike or wheels, rode on all sorts of roads the same way I'd ride on the track. Also note that if/when weight is a factor it doesn't happen right away. So, look to a build issue. That list is too long, so I suggest reading everything you can find on building durable wheels.
FB
Chain-L site
FB
Chain-L site
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,955 Times
A good wheel builder or a good mechanic can true them back up and get them ready to roll. That is probably all they need and if you explain the situation they can do their best to correct for that. If it was really done poorly then have a wheel builder rebuild the wheel.
Liked 2,538 Times
FWIW a common cause of new wheels going out of true on the first ride is spoke twist. Friction causes spokes to twist with the nipple as they're tightened. This is worst on final true when tension is highest.
As you ride, the cyclical easing of tension allows the spoke to untwist while the rim holds the nipple. This is most common with lighter spokes and rims, but is not serious and easily resolved.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 6177 Post(s)
Liked 4,794 Times
You shouldn't have to be scared of rough spots or be careful of road hazards just for the sake of your rims. Just make certain that any wheel you ride has been checked out by a wheel person soon after you get that wheel. It's usually pretty inexpensive. Less than a few beers in the tavern.
Once they've been checked out, they should probably be good for a long time. But you should always check your spokes every once in a while, to make sure they all seem about the same tension. And are not too loose.
I haven't had a wheel go out of true in a very long time. Probably since I started letting a wheel person go over every one of my new wheels instead of trying to DIY them on my own.
Likes For Camilo:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 318 Times
OLD rim with corroding eyelet holes. There's the problem. I hate eyelets on new rims even worse.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,455 Times
Likes For SurferRosa:
Quoted: 4340 Post(s)
Liked 1,526 Times
OP, no one knows why your wheels aren't true. Don't futz with them yourself if you don't know what's going on. A decent mechanic can tell you if the wheel is wrong or just needed truing and tension.
Likes For Kontact:
First thing yesterday morning I tool them to my LBS. The owner is an older guy who is master wheel builder. He had a good look at the wheel and said he thought the wheel just wasnt tensioned properly. He didnt seem to think correcting it was a huge deal.
