Hybrid 3x (flat bar) conversion to Road 3x (brifter) has me stumped
Howdy folks. Today I was asked to convert a 3x Hybrid to a Road 3x and I thought it would be a no-brainer but I just couldn't get the Road 3x Front Derailleur to work perfectly.
Opus bike, original crank / chainrings were 42, 32, 22 - replacement cranks / chainrings are Ultegra 52, 39, 30 (I think?). The Alivio derailleur was not swapped as I thought it was capable of handling such a change.
I'm of an era which doesn't know a lot about the technical side of product differences but should a Triple FD not be capable of such a change? We also swapped from Trigger shifters to Brifter STI style...
Cable tension and routing... Check. F Derailleur alignment and height... check. DT Barrel adjustments done with slow and careful tweaking... Check. Still couldn't got all three to play well together.
I wish i had more info to offer. I'm sure your comments will stir my memory.
Thank you all in advance.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Older Shimano triple front derailleurs used different amounts of cable pull for "road"vs. "mountain" setups. The Ultegra requires less pull than the Alivio so try it.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 4201 Post(s)
Liked 3,857 Times
I'll also add that road and MtB frt ders (by Shimano) have rather different chain ring sizes they are optimized for. Also some MtB cranks space their rings apart more then some road ones. Andy
AndrewRStewart
AndrewRStewart
Not compatible. You need a road triple fd, ideally designed for a 52t big ring (some are designed for 50t, you can probably get one to work but it'll be worse. )
Expired Member
Quoted: 3665 Post(s)
Liked 5,413 Times
Yes, be sure you get the FD that is designed for the 39t middle ring. Some are for 42t.
Quoted: 405 Post(s)
Liked 430 Times
I've never seen any Shimano road triple front derailleur not work on any non-weird triple crankset, including MTB cranks on 9 speed STI touring bikes, where 46/36/26 was pretty common stock gearing. Shimano didn't make a road triple FD that was "designed for" a 46T big ring, but lotsa Treks, Cannondales, and Surlys were built that way, and they shifted great.
Bicycle drivetrains are really forgiving, and specs are really conservative. Most combinations work so well that no rider in the world could tell the difference blindfolded. (Before they crashed.)
--Shannon
Distinction without a difference, IMHO.
--Shannon
--Shannon
Expired Member
Liked 5,413 Times
Yeah, when Shimano switched their road triples from 52-42-30 to 52-39-30, folks found the newer FD would not clear the 42t on the older cranks. And conversely the much shallower inner plate of the older FD did not do a good job pushing the chain off a 39t. Not a biggie if folks don't know this, was a long time ago. Maybe just a reminder that we can't know what we don't know.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
It may not work in this case, but try clamping the cable on the other side of the pinch bolt.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
One proviso: Set up and performance is generally easier and better, respectively, for Shimano’s cheaper front derailers. Tiagra and lower are easier to set up and have a wider useful range than the higher “better” Shimano derailers.
Ifixbikes: your issue is with the mountain bike vs road bike derailer. Swap to a road and everything should work.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 802 Post(s)
Liked 703 Times
--Shannon
--Shannon
Jeff Wills
Jeff Wills
Quoted: 405 Post(s)
Liked 430 Times
Still, a good thing to have in the knowledge vault!
--Shannon
