Presta tube in a Schrader rim?
Quoted: 5 Post(s)
I have an older bike that I have replaced the wheels with two used ones. Wheels have the same tires, but one tube has a Presta valve and one has a Schrader valve. I wanted to replace the Schrader tube with a presta tube, but one guy told me that because the hole in the rim is larger, I needed a little nipple-like insert to make the hole smaller, or it might damage the tube.
I can't find such an insert on-line, and the proprietor of my local bike shop has not heard of this. So, can I just replace the tube with a presta tube, or is there something I need to do to the rim.
Thanks,
Larry Forgy
Thanks,
Larry Forgy
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times
I've put Presta valves in rims drilled for a Schrader valve several times and never had a problem. I do recommend using the little locknut that comes with most Presta tubes to help hold the valve tight to the rim and seal the opening.
Likes For nathand:
Expired Member
Quoted: 3660 Post(s)
Liked 5,405 Times
This
Disappointing your shop wouldn't know of these.
Likes For shelbyfv:
Quoted: 6187 Post(s)
Liked 4,806 Times
New tube with the correct valve stem won't cost you much more if any than the adapters. You might can make your own. But unless you need to be innovative to feel good, just toss the tube and get another.
Or is it that one wheel will be different than the other? Hmm, yeah, in that case I'd buy the adapter too or engineer my own grommet or something. I might be tempted to drill the other rim and use all schrader.
Same here though I use two locknuts for added support.
Likes For runner pat:
Likes For larryforgy:
Quoted: 4802 Post(s)
Liked 3,922 Times
BITD I heard of people using washers that fit nicely over the valve stem. A quality washer with rounded edges on one side; that nice side toward the innertube should do the job well. (And shouldn't cost more than about 10 cents at say Ace Hardware. I'd bring the tube and look at both English and metric and buy the best fit You might need to bend the washer a little to fit the rim and perhaps file two flats if the washer is wider than the channel. You don't want gaps or sharp edges.
Likes For 79pmooney:
Quoted: 5 Post(s)
Larry
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
Stuart Black
Stuart Black
Expired Member
Liked 5,405 Times
^^^Those look very much like the nuts that come on Conti tubes.
Likes For cajunpedaler:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
a brass grommet inside the rim through the schrader hole could work, too. hmmm...(off to the shed to find grommets)
Quoted: 2026 Post(s)
Liked 1,096 Times
Buy the adapters and use Presta tubes in both wheels. It greatly simplifies tube inventory, pump heads, etc.
Quoted: 5 Post(s)
I hope you can find a better bike shop. Adapters to sleeve a Schrader rim hole down to fit a presta valve are made in several configurations including the Wheels Manufacturing shown in the Amazon listing, rubber grommets to reduce the diameter, valve nuts with a ridge to center them in the rim hole, etc. Any worthwhile bike shop should have one or more of these and certainly should know what they are.
Quoted: 211 Post(s)
Liked 199 Times
Bike shops are so busy with repairs that they have little time for small issues sadly.
This is due to no inventory so everyone is "dusting off" their bikes and getting them rideable.
Some bike shops are 3 WEEKS out on repairs!!!!
It's a crazy time for sure.
Glad you were able to resolve with the " wealth " of knowledge by this awesome site and its members
Liked 3,922 Times
Schraeder to presta adopters (so you can use a presta pump to inflate schraeder valved tubes) - we used to make them but I cannot for the life of me remember how. (1977. The shop I worked at was a regular early evening stop for a guy named Sheldon Brown: friend of our equally odd mechanic.) My TBI was that fall. I just now remembered that the two of them used to make those adapters. I did too and I made some. Just now remembered I think we used the common presta to Schraeder screw on adapter and an innertube presta valve. Did we use the fully threaded valves and simply screw the adopter onto the innertube end? If that worked, easy, small and light! Going to have to go through my old tubes and find a good candidate.
Oh, the universal name for those adopters in that part of the mid-'70s Boston bike world was the very PinC "damsel in distress" valve or adopter. We carried them to be able to assist women (who in that era were almost all on Schraeder) with flat tires.
Liked 4,212 Times
They come with various tubes but not with all tubes.
Stuart Black
Stuart Black
Likes For cyccommute:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,979 Times
It'll almost certainly be fine without any adapters - especially if you're careful with removing the pump.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
If you search for “Presta adapter nuts”, you’ll find these. They are a bit simpler than the inserted adapters. Both work.
Yep, we salvage the nuts from damaged Presta valve type tubes for this reason, got a small drawer full of them
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
It almost certainly is an unnecessary risk. An adapter nut, linked above, is the safest answer, and the only way I'd ever recommend anyone attempt to use a Presta valve in a Schrader hole..
It's MY mountain
Liked 2,979 Times
Six years I rode my commuter bike with presta valves in Shrader holes just like that photo. Never once had a valve stem issue. Those little nuts are fine - they're just not as necessary as you think.
Quoted: 532 Post(s)
Liked 621 Times
Maybe you can make it seven...I won't even try for one day. To each their own.
They aren't necessary when the Presta valve is poking though a Presta sized hole...back when I used tubes, I never used nuts...but I was pushing the valve through the holes they were deigned to fit through. The same is not true for Presta valves in a Schrader hole. I'm not saying it won't work, I'm saying there is some risk involved, more than I am willing to accept and more than I am willing to recommend anyone accept when the solution to remove that risk is readily available for pennies.
Quoted: 283 Post(s)
Liked 262 Times
I've used rubber grommets from a real hardware store before, prob cost 32 cents each. I reamed my mtb rims for schrader tubes just in case, but used presta tubes with a grommet.
Member in Training
I also heard of cutting the top off of a presta valve stem cover and flipping the cap upside down, screwing it all the way down it will fill the hole in the rim and prevent rattling of the stem in the hole.
Likes For Ryno317:
