How does Strava know the incline grade pct. of various roads?
Is this some public GIS based topographic geo database they overlay your GPS location over?
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I used to think it was done by known elevations at certain geographic points. But I think it more likely it is done by smoke and mirrors.
Likes For Chuck M:
Quoted: 18409 Post(s)
Liked 15,530 Times
Thinking the secret ban has expired.
Likes For indyfabz:
Expired Member
Quoted: 3664 Post(s)
Liked 5,412 Times
Yep, hitting it hard again. Disappointing....
Likes For shelbyfv:
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,430 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Quoted: 1273 Post(s)
Liked 1,392 Times
https://support.strava.com/hc/en-us/...-Your-Activity
Likes For mschwett:
Sr Member on Sr bikes
Strava doesn’t know. The GPS (receiver and software in your phone) resolves your elevation. The Strava app uses that GPS data and applies it to the various aspects of the app. GPS can resolve your vertical position the same way it resolves your horizontal position. It uses timing signals between the GPS satellites and your GPS receiver device down to the nanosecond (One nanosecond is to one second as one second is to 31.71 years.). When you go up or down a hill, that timing signal gets longer or shorter. When it detects that, it goes one step further and does the math to determine the degree of inclination, or percent grade.
Dan
Dan
Liked 1,392 Times
Dan
Dan
Likes For mschwett:
I can't fathom there is topo data that is so granular that some agency or entity actually recorded incline of every neighborhood street in USA
Likes For CheGiantForLife:
Dan
Dan
I am going to test out this feature of the phone on my next walk
Quoted: 3949 Post(s)
Liked 7,293 Times
Most of your answers about Strava-provided elevation can be answered at this link: https://support.strava.com/hc/en-us/...-Your-Activity
Dan
Quoted: 506 Post(s)
Liked 638 Times
It may well be that you can't fathom it. That doesn't mean it isn't real. If you work with RideWithGPS to map and record routes, they have all that elevation data built in. They use Google Maps and OpenStreetMap as two of the choices in their map data, but their elevation profiles come from Google Maps, which shows the elevation changes in detail. That data is there before you ever get on the bike, so no need for either barometer or GPS input. It's one thing to ask questions because you don't know or don't understand, but it's another to be wrong and yet be sure you are right.
Liked 1,392 Times
there are several sources for this data, but the one i’ve most commonly used is the national elevation dataset, which is free. it covers (at varying resolutions) the entire surface of the country. all you need is that and the coordinates of two points on a road to determine the slope between them.
google uses this data (as well as many other similar datasets) for maps/earth/earth engine etc.
Bikes: Bicycles? Yup.
Quoted: 480 Post(s)
Liked 1,575 Times
I should have kept my original Strava record from the Five Boro Bike tour, it showed a vertical, 100% grade, 1200 foot change in elevation in lower Manhattan.
I used Strava's fix tool to remove the levitation. Strava got the original data from my GPS bike computer, so the GPS signal probably was bouncing off the buildings.
I was in a private parking lot today, and Strava knew the % grade. No way that is in public topo data, but it has been driven by Google Maps!
Liked 1,392 Times
the public (USGS) data comes from satellite and aerial measurements. it includes the entire surface of the earth, including private parking lots.
