Campagnolo BB with Shimano cranks?
Old 10-20-04, 03:12 PM
Berodesign
Liked 2 Times in 1 Post
Is it possible to use a Campagnolo bottom bracket with ordinary shimano cranks? Shimano 600, the ones with a square hole... And / or can I use a Shimano axle in a Campagnolo bottom bracket?
Berodesign is offline
Old 10-20-04, 03:32 PM
sydney
sydney's Avatar
Different spindle tapers on more recent stuff.I,ve seen mixed spindles/cups.
sydney is offline
Old 04-22-14, 08:08 PM
gfk_velo
Bikes: Too many!
Quoted: 108 Post(s)
Liked 79 Times in 44 Posts
In general no.
As sydney says, the spindle tapers differ - depending on the age, Campagnolo tapers may be their own proprietory design (similar, but not identical to, ISO), wheras Shimano use JIS - the difference is that whilst both use a 2 degree angle on the taper, the length of the taper differs as does the size of the "starting square" - ISO is smaller than JIS so if a JIS crank is fitted to an ISO (or near-ISO) taper, the crank tightens too far up the taper.
At best this will result in a chain-line that is not optimal unless this is catered for in axle length selection, at worst the crank may tighten so far up that the fixing bolt bottoms the crank out against the back of the bolt washer, or the crank migrates so far up the spindle that it is drawn hard against the shoulders of the taper. Either way, the fixing of the crank is compromised and in the latter case, crank failure is common.
Mixing spindles and cups is a real lottery - the contact angles of the spindles and cups have to match, plus the shoulder width on the bearing surfaces of the axle have to suit the thickness of the BB cups as otherwise you may not get the desired offset on the gear side, or the adjusting cup may not screw in far enough, so possibly causing BB thread failure - or may screw in too far to allow the fitting of a lock-ring.
"Back in the day" experienced mechanics would sometimes combine BB cups and axles from different manufacturers but there was never a matrix of what might work with what to produce result "x" as the number of possible variations was enormous - it was largely a matter of trail and error and memory (I speak from experience ...) and not to be recommended - it was always the least-favourite option or more commonly, a work-around to try and solve some other problem ...
Your best bet with a Shimano 600 crank set is a sealed cartridge bearing unit from Shimano or some other JIS maker ... UN52 in the Shimano range (if you can still find one) has an excellent price to quality ratio. If I recall correctly you will need around a 113 mm axle, although that will depend on what chainline you are trying to acheive.
HTH
Graeme
gfk_velo is offline
Likes For gfk_velo:
Old 04-22-14, 08:34 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
You do realize you are answering a question posed and last answered almost 10 years ago, right.
HillRider is offline
Old 04-23-14, 10:26 AM
gfk_velo
Bikes: Too many!
Quoted: 108 Post(s)
Well, you read it, no?
A lot of people Google topics and take info from very old posts, so the info they get might as well be full and complete :-D
Cheers
GFK
gfk_velo is offline
Old 11-24-22, 10:47 PM
Guerc
Guerc's Avatar
Quoted: 11 Post(s)
Liked 117 Times in 36 Posts
Well, good information has no expiration date. This thread answered my current question perfectly.
The original question was posed 18 years ago, answered 8 years ago, and still relevant today.
I'm like a cat lady, except male with bikes.
Guerc is offline
Likes For Guerc:
no67el
Classic & Vintage
9
12-13-18 03:59 PM
asshauler
Classic & Vintage
2
05-31-14 09:39 AM
Swen
Bicycle Mechanics
4
05-09-14 07:02 AM
trek330
Bicycle Mechanics
1
08-06-11 07:34 AM
mapleleafs-13
Bicycle Mechanics
3
09-27-10 07:57 AM
