Cinelli SC Pista for commuting
Hi all,
I recently managed to get a NOS Cinelli Supercorsa pista frame from a good friend in my size, and was thinking of building it up for commuting purposes. (There are no velodromes near where I live) I would like to know if anyone has owned one of these bikes before, and how do they ride? From the geometry charts provided on the Cinelli site, the frame doesn't seem crazy aggressive (for a track bike I mean), and it's a gorgeous frame. I also live in a very flat area with lots of rain year round, so I thought going on a fixed gear for commuting would make sense.
Do let me know your thoughts, thanks!
Likes For Anfieldtramp:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I've commuted for years on assorted fixed gears. I never minded the steep angles, but I'm used to the toe-overlap that comes with most any track bike under a 56cm. You'll be on your own for hauling your kit and/or water, no eyelets. Fenders will be impossible to fit, unless you lace up a set of 650b wheels and then potentially be limited to ~35mm tires by the frame.
You can commute on anything, but this sounds like the kind of thing that's best saved for special road rides or sell it to someone who likes to go in circles.
Quoted: 964 Post(s)
Liked 1,451 Times
The geometry doesn't seem untoward. That would be fine on the road, handling wise, I'd think.
The trouble is those forks have a track crown, don't they? You can't drill a track crown for a front brake. I'd not commute without a front brake, no matter how flat it is. S**t happens. Drivers are unpredictable. You need brakes.
You can get a Keirin brake adapter. They are expensive and there may not be room, depending on clearances. You could also get a different fork. Just about any 700c/27" fork should be ok.
Or disregard my post completely if you've got brakes worked out.
Likes For P!N20:
Quoted: 786 Post(s)
Liked 517 Times
Depending on the year, that could be a quite valuable frame, especially NOS. If it were me, I would not use it as a commuter.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
When I think about commuting, it means taking risks, riding in bad weather, picking up stuff from stores and using a big effin' U lock whenever possible.
I wouldn't do that to an NOS SC. There's too many other nice road frames to convert.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
For commuting, especially in a rainy area, I'd want something with enough clearance for mudguards. And unless you have a safe place indoors to lock it up, I'd want something less flashy. An old English 3-speed served as my commuter for many years (retired now). Low maintenance (internally geared hub), mudguards, rack to carry things, no theft appeal, inexpensive. What's not to like?
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 134 Times
I have a keirin brake for my samson, they make a couple types depending on the shape of the fork blades. Personally I like to ride it without the brakes. I don't really like the idea of the stress on the fork legs.
That said, they do make an adapter that mounts from underneath internally into the steertube through the fork crown.
(pictures are worth...)
On my bike I'm limited clearance wise and can barely fit a 24mm tire let alone with that mount. On yours it should work.
As far as a commuter, it's your bike, ride!
I was also wondering about the stress on the fork from the clamp on front brake. If the brake is there for emergency purposes and legal reasons (since I'm quite confident in stopping using my legs most of the time), and it's not used very much at all, would it still be a problem for the structural integrity of the fork? My thinking is that since it won't be used often, it should be ok? Or is it just the fact of having something clamped to the fork that makes it in itself problematic.
Quoted: 331 Post(s)
Liked 332 Times
Fixed is safer
On a fixed bike you have to anticipate everything. You dial into the road traffic otherwise you are roadkill. City couriers use fixed for this reason. I used a track bike in traffic for commuting, just change the forks with a drilled crown.
For the first 60 years all bikes had clamped on brakes- so no problem there. Resilion brakes were always clamp ons as well as most rod brakes.
Get a good coat for road spray and/or there are plenty frame mounted fenders to help out. You must have a front brake minimum (in Europe it is illegal and if an unbraked bike is involved in a crash the cyclists are treated the same as a drunk driver) pedestrians can't hear bikes and step out without looking. Many drivers simply don't care if you are on a bike competing for roadspace. You don't exist for some. A rear brake is next to useless for stopping.
Quoted: 3464 Post(s)
Liked 2,827 Times
this is not a disc brake
plenty of other reasons to not use it all year but the clamp on brake does not worry me
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
I loved a track bike for commuting so I'm a bit envious. I also place Cinelli SC at the top of my bike list, again, I'm even more envious. Some of my most memorable times have been on a 'commuter' track bike. Now I wish I was young enough to enjoy those times all over again. Gee, this has been a 'sad' thread for me but a fantastic one for you Anfieldtramp. Wishing you all the best.
Oh yeah, with such an iconic frame I would be worried about fitting a brake to the Cinelli front fork. I'd try to source a replacement front fork that would accomodate a brake calliper. I can understand the urge to go brakeless - Shhhh - I'd go brakeless too.
Quoted: 18353 Post(s)
Liked 4,502 Times
@Anfieldtramp's Album:
https://www.bikeforums.net/g/user/521356
https://www.bikeforums.net/g/album/18690715
Well,that doesn't look like a Cinelli.
Quoted: 3011 Post(s)
Liked 3,788 Times
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,921 Times
Back in the day, 87-91, I commuted a lot and while I would occasionally ride my prized possession, a 90 Bianchi Proto, mostly I’d ride my older Sport SX or borrowed team Cannondale frame. personally I’d never buy something like that with the idea of commuting on it.
Sugar "Kane" Kowalczyk
Friendship is Magic
Bikes: old ones
Quoted: 26392 Post(s)
Liked 10,366 Times
Likes For 3alarmer:
Quoted: 964 Post(s)
Liked 1,451 Times
Finding a road fork with very little rake would be a possibility, but a non-original fork would also ruin the aesthetic of the track bike. If you can get your hands on one of those Keirin adapters, it'll be a bit more seamless.
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
My two cents
The clamp on brake, in question, made me nervous in my limited use. Plus I have seen pictures of fork damage caused by this setup. I used it once on a shakedown ride, and immediately went for the quill adapter option.
It is expensive, but a beautiful piece of machining. Shipping and service is top notch as well. Do it right the first time, it will be cheaper!
I too, considered the fork route, but expense would be approximately the same and would change the looks and characteristics of the bike as well. It is something to consider though as a fork designed for a brake caliper will offer best fit and performance of said caliper.
Good luck and keep us posted.
Friendship is Magic
Bikes: old ones
Liked 10,366 Times
I hope this might help in your decision...
...I know that it is declasse of me to bring this up, but I'll say it anyway. thre are a lot of relatively well constructed track frames coming out of Taiwan now, that are inexpensive compared to your Cinelli, and some of them are even drilled for a front brake. If you absolutely must have the experience of commuting on a track frame, build one of them up, or even buy a complete bike like a Bianchi Pista (depending on where the Pistadex is sitting on Craigslist right now).
You can build some kind of coaster brake rear wheel for your current frame, and it will be at least street legal in California and most states.
But there's no getting around the fenders, rack, and wider, more durable tyres that most people want on a commuter bike any place it rains and if you need to change clothes, carry your lunch, do any of the mundane things that are involved in commuting by bicycle year around. I believe this has already been covered by others offering advice.
Here are two photos of commuter bikes I've used in the past. the Raleigh three speed was by far the best all around commuter, but the black one is something I put together to go faster in good weather, which we have here for about six months out of the year in California. It originated as a "track" frame, made in Taiwan, and on half price year end sale from Performance online. It's smaller than any track bike I would ride for that purpose, because it turns out to be an advantage in traffic to have a more upright position for visuals. Those New York City messenger bike guys, with their heads down in full tuck, look impressive in the movies, but they have an unfortunate tendency to run into cars and stuff. Good luck. Bike commuting is one of life's grand adventures.
Slow but not too bad with custom lighter wheel rims.
Mechanicals built around a SRAM P5 IGH
A Bianchi with a flip flop hub, and some elevation for the bar provided with an up angled stem. By the time I got this, I was retired. Which I highly recommend when possible.
Likes For 3alarmer:
