Straightening a RD cage
Quoted: 161 Post(s)
Liked 267 Times
I noticed the cage on my old Sachs Huret DuoPar eco is a bit bent. From what I’ve read, this was a common complaint back in the 80’s when this derailleur came out. Should I bend it back while on the bike or take the derailleur off and apart, then bend it against something flat?
also, is heat needed? I believe it is steel.
it shifts fine, but gets stuck when back pedaling.
Quoted: 3510 Post(s)
Liked 2,924 Times
Personally, I'd try to do it on the bike--you'll get more leverage that way. I wouldn't heat it.
Be advised--sometimes cages can take weird compound curves--they might be fairly difficult to straighten perfectly.
Quoted: 1943 Post(s)
Liked 2,164 Times
If you do it on the bike, I would be concerned about bending the integrated hanger and not the RD cage.
John
Edit added: As far as bending it off a bike. Get an inexpensive universal/claw type hanger and mount it in a vise.
John
Likes For 70sSanO:
Quoted: 1438 Post(s)
Liked 1,092 Times
Bending it against something flat will not help, you have to overbend the metal to get it to deform and take a new shape.
Liked 2,924 Times
You think the thick hanger will bend before the thin cage?
Liked 2,164 Times
I’ve straighten the hanger and a steel frame with a large crescent wrench and a square. It doesn’t take a lot of effort.
Whether or not straightening the RD will tweak it I can’t say. If it were me I’d take it off the bike. It might even be necessary to remove the outer plate.
It looks substantially out of line. I will say that the cage will break before the hanger.
John
John
Quoted: 161 Post(s)
Liked 267 Times
John
John
Liked 2,924 Times
Well, a vice is a good idea too. It'll take some time before the cage breaks, if it's steel.
But anyway, if it can't be straightened, replacements are on eBay. Although I'd be inclined, myself, to upgrade to something more modern (i.e., a slant parallelogram).
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Taking it apart and getting the plates flat in isolation is what I'd do.
Quoted: 4233 Post(s)
Liked 2,948 Times
Quoted: 303 Post(s)
Liked 136 Times
The hanger probably won't bend but there is a lot of flexion in the RD body that will occur when you
start to bend the cage if mounted on the bike. Best to remove from bike and dismantle the cage so only the inner cage
is exposed, then you can clamp in a vise and precisely bend it back. No heat needed.
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...that's one of the few rear derailleurs I routinely replace with something that works better.
I know thee are people who like them, but I never could get them to work as well as the long cage alternatives.
The ones I've encountered seem to wear out at all the various pivot points...I don't imagine bending and straightening will help that.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
How valuable is the bike vs your time? I bend a lot of old RDs back into shape on bikes donated to non-profits. But I don't care about the bikes. If this is your baby, treat is as such and enjoy the process. Get out the old toothbrush and shine it as you go.
Likes For andrewclaus:
USAF Veteran
Maybe because the bent cage throws the angle off a bit but it looks like the guide pulley is not aligned either.
Quoted: 1142 Post(s)
Liked 1,739 Times
I would chunk it, I bet your bike has a lot of clattering.
If you want to give it a shot, align the dropouts, align the hanger, reinstall rd examine the top pulley align that to the cogs, then attack the cage align to the cogs. In fixing bends I try to reverse engineer the bends.
Quoted: 161 Post(s)
Liked 267 Times
