Homebuilt Grocery/Cargo trailer Warning-Long
Quoted: 16 Post(s)
Liked 24 Times
We are Car-Light but have been driving to get large loads of groceries & cat litter and/or garden supplies. Tried grocery panniers but they are awkward to load on the bike when full and have limited capacity. We decided it was time for a trailer.
Goals were;
High load capacity at a reasonable weight - Low CoG for stability – Fast, easy one-handed hookup - Parkable in a small space - Cost effective. I couldn't find anything commercially available that met those criteria. So I figured it was time to see if these arthritic fingers could still lay down a decent TIG weld. (First few beads were a little lumpy but I guess it's like riding a bike.)
Fabrication isn't a problem for me, but we haven't used a trailer since the original Cannondale Bugger 35 years ago. So, I read everything I could find about them on Bike Forums' Utility Bike section. Lots of interesting homebuilt trailers there. Most are clearly built on a tight budget by someone with limited tools and design & metalworking experience. This is not a criticism – Lack of money, tooling and skills brings imagination to the forefront. So there's some very clever stuff here.
Acceptable compromises;
Weight - All the features I wanted added up to 23 lbs but it's mostly flat around here.
Width – 32” for stability. Can't wheel it through most doors, but it's kept in a garage.
Ground clearance – 4” Not a problem so far, but it's best to be mindful of it when towing.
Far too many welds to think about making more to sell.
Chassis is mostly 1-1/4” x 0.049” square mild steel. Mounting the box well below the axles made for lots of extra work. Axles thread into short pieces of 3/4” chrome moly bored and threaded to 14mm x 1mm. These are brazed into the uprights, along with reinforcing washers to spread the load over a large area of the square tube. Zero camber and just enough toe-in to be sure there isn't toe-out.
Wheels are inexpensive BMX units with nice 48h Weinmann Zac30 rims and no-name 14mm axle hubs. Enough of the axle was threaded to allow me to move the cones over and have abt. 2.5” sticking out on one side. Tires are CST Cyclops. Light and fat enough to roll easily @ 35 PSI.
Finish is Rustoleum “Hammered” silver. Reasonably tough, fast drying and hard to screw up.
Box is from Home Depot and cost about $16. Forget what it's called.
It's impossible to make a clean intersection of two same size square tubes at a compound angle. So I brazed the chassis and the tongue to a piece of 1-1/4” round. When not on it's tail or hooked to the bike, the trailer rests on the front of this tube. So I reinforced the bottom with a thick, short section of 316 stainless tube.
Rearward extensions are lightweight 1-1/4” x 5/8” x 0.035” chrome moly and do not support the load. But combined with small rubber bumpers on the back of the box they support the trailer when parked on it's tail, with the tires off the floor.
The ball is attached to the bike with a mount carved from 1/4” aluminum structural angle. After removing a 6mm axle spacer, (got lucky there) the mount is securely clamped between the left dropout and locknut. Slotted to match the vertical dropout, it does not interfere with wheel removal. When the wheel is off, it is held in place with a 6mm bolt through the rack eyelet. I'll eventually make a “Clamp on the rear stays” mount for a ball in case I ever need to tow it with another bike.
Hitch is a modified QR ball joint. The added tabs allow quick, one handed attachment to the bike. The body pivots on a piece of 1/2” threaded rod. Ball and hitch have been modified to double the up/down range of motion. 316 stainless hoop is for locking, hanging and maneuvering.
Flag Mount
I needed to be able to fold the flag when the trailer is parked on it's tail. So I needed a pivot with a controllable amount of friction. Flag is riveted to a piece of aluminum plate that is sandwiched between a piece of stainless that is welded to the left upright and another piece of aluminum plate. The piece of aluminum adjacent to the spring is not attached to the frame but can't pivot around the bolt due to it's shape.
Maiden voyage was a revelation. 4 very full bags of groceries and 20 pounds of cat litter had no effect on handling and was only noticeable when climbing. Tow bike is a homebrewed 69'er based on a very light '85 Trek 850 with a damaged headtube. (Excess cable length is because I need to flip the bars and raise the stem another 3 inches when my Polymyalgia Rheumatica kicks in.)
Goals were;
Flag Mount
Bikes: Madsen
I agree! This looks awesome!
Is the inside of the plastic bin smooth? You can put bumper stickers in there... just an FYI!
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 711 Times
Excellent. It shows you thought before building it, not after. Great workmanship too.
Bikes: 1995? Trek 830 (with mods); 1980ish Fuji S12-S
This is a very nice trailer. I just recently picked up a BoB Yak off CL for not too much, but if I had your mad skills I might have tried this sort of thing.
Nice work!
Nice work!
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Your trailer is very well built and nice nice but requires a lot of skill and equipment to build for the average rider.
For those without the skill or special equipment this trailer can be built with simple hand tools and recycled material (or new) on a weekend by anyone who can read.
https://www.motherearthnews.com/do-it...z81jazraw.aspx
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Quoted: 16 Post(s)
Liked 24 Times
Thank you all for the nice comments.
In a way that's a weakness of mine. I'll obsess about every little detail (in this case for over a year) when I could have made something useful right away and already had a year's hauling out of it.
For 15 years I commuted on my 1st homebuilt recumbent. Almost very commute I would think about what I could have done differently to make it better. I finally built my idea of "The Ultimate Commuter Bike" 6 months before I retired.
In the intervening years I'd built several high performance bent's, including two successful racing machines that were each built in a weekend. But a commuter is a much tougher challenge than a bike (recumbent or conventional) built just for racing.
Quoted: 10 Post(s)
Liked 6 Times
Something for everyone!
That is very nice. You have avoided one of the great evils of many trailer designs, and placed the floor much lower than the axle(s). Also, you relied on the strength of the tote, and resisted the temptation to place a large rectangular frame (and heaven forbid a plywood floor!) under it. Well done!
Thanks so much for sharing! Thank you for the great detail you shared as well! This is very similar to what I was envisioning. I was pleased to read that you used steel, I never was very successful at aluminum welding and I am not keen on exclusively using fasteners.
Quoted: 16 Post(s)
Liked 24 Times
BTW the tongue design shown in my original post was a failure. If I leaned the bike over far enough, ground clearance was inadequate over bumps. And the sloping arm broke off the kickstand on a sharp turn. The fix looks a bit kludgy but works great. I hauled home 3 steel fence posts, 2 boxes of cat litter, a 6 pack of paper towels and a weeks supply of food for 2 adults and 3 large cats on Tuesday. And if there was any flex in the tongue, it was not noticeable on hills. It's a good thing I enjoy welding, there is a lot of bead in the chassis now.
Quoted: 801 Post(s)
Liked 1,000 Times
Great job. I really like the ball hitch. Was that custom made by you? It is real simple and look secure.
