Installing hydraulic disc brakes
Even if prefilled, you still need to bleed. Get the appropriate bleed kit.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
With Magura you don't need to bleed to shorten the hose, but you do need some olives and the tool to press the fitting. There are videos all over the internet on how to do the initial fit of Magura brakes, but the bleed kit is relatively cheap.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
And the same is true of Shimano and Campagnolo. Now, sometimes you do but with new installations, if things go correctly, you can just attach and go.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
