Holdsworth help with date and model
Bikes: Seven Cycles ID8 & steel Axiom; Bridgestones: MB-1, RB-T, XO-1, '85 Orange Gran Velo; electrics: Bionx, Swytch, Eflow Nitro; Merlin early MB; Raleigh Twenty & a lot of comings and goings
I searched and read all the threads and looked at the terrific Holdsworth history site https://homepage.ntlworld.com/nkilgariff/. I was told a bike I just acquired was an early 80's Mistral but the bike has no model name on the top tube and is all double butted 531 including forks and stays while the Mistral was not in that timeframe. The wheelbase measures 40" which is more like the race bikes than the Mistral which was more of a touring bike in the early 80's. The bike is all Campy NR except for the wheels one of which was changed and the other was missing but it originally came with sew-ups. The bike is quite light and not just because of the missing wheel. The fork blades and chain stays are more round than Raleigh's high end bikes of the time.
The serial number is 041335 and above the number it has an 8. The bike is silver with white transfers and looks exactly like pictures of the Nuovo Record in the 1982 or the NR Professional in the 1978.
Any knowledge others have gained would be very appreciated.
Stop reading my posts!
Quoted: 1440 Post(s)
Liked 1,058 Times
Maybe Skip Magnusen will see this and respond...he's been making a Holdsworth serial number database. In any case, pictures would be helpful (beating East Hill to it).
I hate to take pictures of a bike before I fix it up or at least clean it. It is like showing pictures of it in its underwear but here are a few pictures if they work:
https://im1.shutterfly.com/procserv/4...0AYsWLNi4bN2NA
Bikes: Basso, Holdsworth Nouvo Record, Italvega Nuovo Record, Gitane TdF, Bridgestone (700, RB-2), Shogun tour, Univega Sportour, Raleigh Competition
I have the same bike, or frame at least. It is an 82 Nuovo Record available as a frame as listed in the 1982 catalog you mentioned. I purchased mine from the original owner (from England) that built and used it as a race bike. I believe that model was available for only one year. Mine has the tange headset and the rest is Campy/Ofmega/Galli as built up at the time. The serial number is 8 over 041356 (not far apart). It is a great riding bike, smooth and quick but not twitchy. My Holdsworth has been off the road for a year due to an accident that dented the top tube and put it out of alignment. Yours looks like it will clean up nicely, and it is well worth the rebuild. I have a number of old rides and rated that bike near the top.
The bike may be older than it looks. The NR rear derailleur has "Patent 1973" on it and the cranks do not have the diamond with the date in the center that started in 1973. The graphics on the bike are unlike any in the early 70's and the bike doesn't look like it has been repainted. The wheel and freewheel are not original to the bike and I don't believe the Cineli stem and bars are original either. Is there something else I should be looking for? Ron
SkipM
Bikes: Italvega 1971, Italvega 1972 SuperSpeciale, Holdsworth Mistral 1983.
Hi Ronp6,
Every time I see a Holdsworth serial number, I add it to my data base, I have a bit over 50 now and need to give the DB some attention. Your s/n 041335 according to the numbers I have collected place it between 035267 (1981 a Special) and 047637 (1983 also a Special). My 1983 Mistral is s/n 062734. I also have a s/n 041150 (1983 - orange color) which is fairly close to your s/n. My Mistral is 62 cm, Met. Maroon - I haven't mastered inserting the big pictures in the forum but I can send you a picture of mine if you PM me your email address. I displayed my last year in the Seattle Bike Expo but it is ridden and is complete with scratches and chips - but looks nice.
Skip Magnuson
Spokane, WA
Skip Magnuson
Spokane, WA
Intheshop- Thanks! I couldn't ask for a closer match for a serial number. I was concerned about the age when I saw the dates on the derailleur. The headset on mine is indeed a Tange and the catalogs only list that in the 80's so that is good confirmation.
I do have a couple of cosmetic dents in the top tube, too bad about yours. Sheldon Brown mentioned on his site that he straightened the Reynolds tubing on a Raleigh International that was out of line with a practice swing of the hammer on a piece of lumber. It couldn't hurt to try.
Thanks again for you help.
Ron
Ron
Skip,
Thanks PM sent!
Ron
Thanks PM sent!
Ron
Campy NR / SR forever
That's not a 70s bike. Holdsworths from the 70s had a rivetted on headbadge. I still miis my old mistral or pro (never did figure out what it was - it was their team colors pumpkin and blue).
Thanks, with help the bike was determined to be a 1982 Nuovo Record. It is a fairly rare model and should make a great bike once I pick out some wheels for it. I saw you have a Raleigh Pro. I am hoping to get mine out on a pair of clinchers this weekend. It has been sitting too long. Sad to say but the tubulars aren't safe to ride.
The Shogun is a nice bike also. I gave a friend a 600 that has the same frame as your 400 only the components were different. Ron
Bikes: Ron Cooper fixed audax, Holdsworth Monsoon fixed, Falcon hack fixed, Graham Weigh 531 24 speed, plus others in bits.
This guy doesn't take e-mails anymore but there is enough imformation there to generally date most Holdsworths
Bikes: Denti Scheggia, 1974 holdsworth super mistral as a single speed
just read the post - i'm new to the forum.
i myself own a nuovo record. 1982 model and it's rare top end. apparently the difference between these and the pro is the headset
mine's in black and was my hack back for quite afew years. i will dig out my serial number tonight, but from memory it seems close to yours...
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I have a 1973 Super Mistral #69559 that was custom made for me as a Christmas gift from my parents when I was 16. I believe this model referred to the their top of the line customs.
but the serial number is a lot lower than your. i wonder how the numbers work
does yours have the chromed rear triangle with campag dropouts, and the sloping head chromed forks?
would like some pictures to compare it to mine if you have any....email please?
not sure if it's a mistral or super - definately not a fastback version though
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
i've just rescued a holdsworth frame #41310 from about 1974 / 75 (according to the holdsworth expert)
i've heard from a friend that he bought it in 1978.....the frame is a super mistral but the chromed forks aren't. doesn't matter
my nuovo record #41366 so it's quite close to the above 2.
black with the tange headset. i'll never part with it.....
