Moving on from the “let’s see if I like gravel” bike
Quoted: 9 Post(s)
Liked 5 Times
Hello, I’ve now tried gravel and am ready to replace my Craigslist Nashbar “test the waters” bike. It actually is fine except for a fundamental problem: it is really heavy, a true Clydesdale. I ride on dirt/gravel roads, including logging roads, typically 20-40 miles although have gone up to 70 when combined with some paved sections. I ride hills but don’t hesitate to walk down the steep sections. I’m looking to spend about $1500 and have looked at State bikes and a used Specialized Diverge. I do know I want disc brakes. My current tires are 44mm but I am thinking they are a bit wide. I will likely put Metropolis ergonomic handlebars on any new bike. Feeling a bit overwhelmed by choices and would much appreciate any insight.
In case it makes a difference, I am a 68 year old female. Thank you!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Personally, I'd take a Kona Rove over any gravel/all-road bike State is currently making. The shop where I occasionally work carries both brands, and it's not even about the price or components; I just think the Kona rides better.
EDIT: The Salsa Journeyer line also looks nice, as do the Fairdale Weekenders.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I have a Specialized Diverge that I like quite a bit. I'm sure there are other bikes that would work for you, but I think you'd be happy with the Diverge. I'm 72, but I do think that a young person like you would find the Diverge to be a nice bike.
Quoted: 11 Post(s)
Liked 13 Times
I don't know.
Quoted: 315 Post(s)
Liked 851 Times
My bud has a Diverge. That's a nice bike. I've ridden it. He races it and adventures with it. That bike seems to be able to do anything.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
If you change a bike with drops to flat bar, you will need to buy new brakes and shifters since road/drop bar components have a different diameter clamp than flat bar components. Road is 23.8mm diameter clamp and flat bar is 22.2mm diameter clamp.
I just mention this since it may need to be figured into your purchase if the bike you want ultimately comes in a drop bar configuration new.
A couple of flat bar setups are below...
$1500 msrp and 38mm tire clearance https://allcitycycles.com/bikes/macho_man_flat_bar
$650 msrp and 40mm tire clearance https://www.poseidonbike.com/product...41092144562327
Quoted: 9 Post(s)
Liked 5 Times
Thank you to all. I haven’t been called “young” in a very long time! 😂 I’m also looking at the Shockstop Suspensión Stem to keep my arthritic wrists and thumbs happier.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
For the budget, you might be better looking at "2nd tier" bikes, yes, Specialize, canondale, Kona etc. do some good stuff in the entry budget market but people like poseidon do great things in the same budget range.
The poseidon Red wood flat bar (29lbs - gravel) or flatbar X (25lbs - hybrid) comes the similar equipment (groupet, brakes) for 1/2 price.
Alpkit sells the sonder camino flat bar.
I don't know what the US equivalent of Planet X is but its worth researching.
Look into liv too as it s the female specific range from Giant. I know a lady who loves hers after spending many years on non specific bikes.
Either way, I would go with large tyre clearance (50-55C) for comfort and then fit tyres that suit your activities (large slicks/large hard pack/large knobbly). Note that I am faster on my test loop with continent speed king (50-584) than I am with panaracer gravel king slicks (35-622).
Quoted: 1392 Post(s)
Liked 1,852 Times
In addition to a gravel bike - consider a hybrid
especially if you are considering converting to flat bar and even more so if you are considering a suspension stem
for distance riding I prefer drop bars - but I realize preferences can vary
a gravel bike in your price range might have cable operated disk brakes - and many of the cable disc brakes are typically average (or just adequate ?) in performance compared to hydraulic disc brakes ... a hybrid at that price range will often have hydraulic disc brakes
some things to ponder
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Likes For pbass:
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 908 Times
Late model Diverges can fit up to 50c if you don't need mud clearance like us Socal folks, but spec says 47c max. I run 32c road slicks up to mtb-like 50c pending where I want to ride w/ the bike. Great do all bike, love my e5 alum (didn't want the future shock). Add carbon to the right spots later and it's pretty plush ride aka Roval Terra seatpost.
WTB venture 50c
WTB venture 50c
Rule #10 // It never gets easier, you just go faster.
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
I do have a couple of thoughts on choosing a gravel bike and on some components.
Love the Shockstop stem - I have 2 on gravel bikes - wouldn;t want to ride without them. What I have found - the recommendations by redshift for Elastomer use/settings (there are multiple varying 'stiffness' elastomer provided with stem) is really quite favored to the 'stiff' side. If you do get the Shockstop stem, don;t be afraid to immediately go to a much softer combination than their chart shows. Based on my weight, I've gone down fully 3 settings below what the chart shows and still feel I could go softer. The stem shock 'absorption' in action is really quite independent from bike & steering control. So no pogo-ing, no matter how soft.
Shifting and braking controls - You mentioned the Metropolis bars, which seem to be a more 'sweeped' version of a flat bar - actually more in line with what one would find on older designs of 'town' bikes. VS the gravel bikes with Drop Bars. Be certain of what bar type you want to end up with, because Flat Bar Controls are quite different from Drop Bars. If you buy a 'Drop Bar' gravel bike and expect to convert to the Metropolis - you may find that the controls will not work well for you in going Dropbar to Flatbar type (although, in the bike universe, I'm certain there are riders who ride Dropbar Brifter controls on flatish bars.... and vis-a-vesa).
Most of the 'Weight' on lower priced ($1500 and under), but well designed gravel bikes comes on because of some key component areas - most in this range have good,sturdy wheels which have some weight. They have good tires and matching tubes which add quite a bit of weight. !x designs (single front chainring and wide range gearing cassette) add weight due to the increase weight of wide range gearing/very large steel cogs on the cassettes. Most aluminum frames don;t vary much in weight with higher priced ALU framed bikes - money goes into more gearing and somewhat lighter components overall.
For me, a Carbon Fiber Fork is a large improvement over a steel fork (or ALU), and worth getting.
It's hard to get below 21 lbs (published weights...) without either a more expensive bike cost upfront (over $2K+) , or doing major upgrades which can be considerable.
A 24-25 lb gravel bike rides quite nicely in a recreational aspect and 'feels' light - even though 'racing' might not be as easy.
Even though I have a very 'performance' bend to my riding (for many decades), I do find the gravel bikes I now have (all in the under $1200 price grouping) more than enough 'performance' for my fun gravel biking...I've ridden much more expensive gravel bikes from my cycling buds; and yes, they are very nice and certainly a level or 2 higher performance; but don;t find a need to go that direction with 'gravel biking'. I'm 73, ride more to the 'performance' side of cycling, use my gravel bikes for more mtb-like conditions (not much gravel 'roads' near me), and mostly do some sort of cycling every day.
Shop around, try as many bikes as possible.
Didn't know Nashbar branded their own 'gravel bike'. If you;re bike is a 'hybrid/city' bike, it will be quite different from true gravel bikes.
AN inexpensive gravel bike, like the Poseidon X compared to a Hybrid/City bike similar in price, will be lighter and quite a bit different handling (in a good way) compared to the City bike...
I'll be interested to hear what you find and decide on...
Ride On
Yuri
Quoted: 9 Post(s)
Liked 5 Times
I really appreciate all the input! Thank you for your time and expertise. The search has evolved, in case anyone is interested:
*Weighed my bike: 14 kg with only a light. No wonder I am slow in my bike group, compared to on the road bike.
*Justified raising the budget. 😂
*Decided I do want drop handlebars after all.
*Seriously interested in the Diverge. Trying to figure out if I can put the ShockStop stem or something similar on the models that do not have Specialized’s comparable Future Shock.
*Want to support the LBS but they only have one Diverge in my size and it’s more than I’d like to spend. I’m a newbie to bike shopping and the distribution system seems complex.
*Keeping my eye on the used market.
The search continues.
Likes For K2dahlia:
Liked 1,852 Times
Don't be afraid to spend a little more to get a / the better bike
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
and most Alu Gravel bikes in the $1k to $2k range will be +- 10 to11 kg (without pedals and whatever else you add on, like bag, water bottle, etc).
If you want 'hands on' before buying, then shop around at LBS in your area.
If you're ok with ordering online, then there are many options.
I can recommend a FRAMED Basswood - which I bought online around Labor day. It's 1x SRAM Apex (one front chainring and 11 spd cassette), especially for combo road/gravel riding.
Well made and great components for the price point. I have about 400 mi on it in the past 7 weeks (I still ride my 'road' bike more often...) and it's been great fun, rides and handles well.
Out of the box it was 9.7 Kg, then I added my eggbeater pedals, Bottle cage, saddle bag and replaced the stock stem with Redshift ShockStop stem. Stock saddle is quite nice, but I have plenty of saddles which I know work for me, so put on one of my own - total weight 10.2Kg.
The House (online store which I've used for a bunch of XC ski purchases and have had no issues) has them lower priced than direct from FRAMED
https://www.the-house.com/qfrbwa1aw5...z-framed-bikes
I picked Orange/Tan - and like the color and combo.
One Caveat - as with many Gravel Bikes I've looked at, the Frame sizing seems to run larger than most pure' 'road' frames. I'm 5' 9" but have longer legs and normally ride a 56 cm road bike.
I bought the 54 cm size and it fits quite well.
The Basswood comes only in 51 cm and larger, nothing smaller - My best estimate is that the 51 will suit/fit a rider on the 5'3" to 5' 8" height range (160 to 172 cm) - 5'2" if rider has long legs...
It's a great riding/value bike at $1049 - if the frame sizes will fit...
... worth considering... if you can order from online comfortably.
...somewhere, in one of the threads here in 'Gravel/cyclocross forum, I did a short review w/pics... I think in "what did you buy for your gravel bike..."
Ride On
Yuri
EDIT: Found my post on the FRAMED Basswood - https://www.bikeforums.net/22647533-post1037.html
Quoted: 9 Post(s)
Liked 5 Times
Well, I pulled the trigger and splurged. A Specialized Diverge E5 Comp is on the way. It was hard to find my size (52cm) but found one halfway across the country that was on sale (!) so the cost is about the same as a bike bought locally.
Likes For K2dahlia:
Quoted: 258 Post(s)
Liked 378 Times
Congrats on the new bike! I've had a 2019 Diverge for a bit more than three years now, and it's a really nice bike. I'm sure you will love yours. Give us a report after you've had a chance to ride it for a while.
Quoted: 3221 Post(s)
Liked 2,049 Times
Gotta second the Kona suggestion, especially the Rove ST (I guess it's called the DL now). Excellent, lively steel frame--has that "thing". Super versatile. I ride mine often like a mountain bike (sometimes places I probably shouldn't) and it rips. Also super comfy and nice on the smooth stuff. The steel Rove frame is a keeper for sure.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I like my Stormchaser and want to like the Journeyer but I just find their builds a little weird.
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,102 Times
If you decide to go flat bar after all, come back and let us know. MTB controls aren't perfectly compatible with road bike brakes and derailleurs. We can help you make it work.
Genesis 49:16-17
Genesis 49:16-17
Liked 1,852 Times
Quoted: 264 Post(s)
Liked 238 Times
and to answer the question about the stem, yes, you can fit a redshift stem on this bike. Takes ~ 10 min
i fitted my spare redshift to my latest hill climb build.
Quoted: 9 Post(s)
Liked 5 Times
Thank you everyone for all your input and willingness to share your expertise and experience with a relative neophyte. Now I just need to sell or donate two bikes, part of my justification for treating myself to a new bike!
