Front hub (rookie mistake)
Quoted: 7 Post(s)
I was servicing my hubs for the first time ever and managed to do rookie mistake. I measured ball bearings from the back and it was 1/4. So I didnīt check front hub bearings and changed them as well to 1/4. I already got rid of the old bearings and realized afterwards, that front hub might be using 3/16 bearings? Is there any possibility that front hubs uses 1/4 bearings ever? My bike is Felt Verza Speed 20, model year 2017 and it has "noname" brandless hubs.
Quoted: 836 Post(s)
Liked 1,058 Times
Not likely the front takes 1/4" balls but can't say for sure and I can't find any info on what the hubs are. Try contacting Felt directly as they should have that info.
Bikes: a couple
Quoted: 563 Post(s)
Liked 862 Times
You've had the hub apart? You changed the balls out? If you don't mind taking it back apart (no big deal) you can take the cone you removed from the axle and see if it seats into the bearings correctly or not. if the bearing hits the center of the cone race with the bearings in the hub, they are most likely correct. if the cone doesn't drop in and the bearings just ride the edge of the cone, you need a smaller bearing size.
Likes For Schweinhund:
Quoted: 504 Post(s)
Liked 637 Times
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
What is the front hub? Most fronts are 3/16".
https://bike.bikegremlin.com/2255/st...ng-ball-sizes/
https://wheelsmfg.com/hub-parts#front_road
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
cchki ... 3/16" balls, ten per side, is the safe guess. If it's a QR type hub, leave a tiny amount of play in the Bearing adjustment.
Felt also has a support page for customer contacts, as well as a Knowledge Base. Didn't see a toll free telephone number.
I believe I did see elsewhere on their website that they try to answer customer contacts within 1 or 2 days.
Quoted: 5766 Post(s)
Liked 2,538 Times
You don't have to take anything apart, the hub will tell you.
If you used the wrong balls, the axle length, lockout to lockout will now be longer. So a simple measurement will tell you where you stand.
Likes For FBinNY:
Quoted: 7 Post(s)
Liked 2,538 Times
Yes. Larger balls push the cones out, so if you use all the original parts, the OLD will be greater than before
FB
Chain-L site
One accurate measurement is worth a thousand expert opinions - Adm Grace Murray Hopper - USN
FB
Chain-L site
Quoted: 7 Post(s)
I took the measurements with the caliber and it was exactly 100mm. But I was thinking that I put 9pc 1/4 bearings and 3/16 bearings you need 10pc. You think it should still be more than 100mm if bearings are not correct now? Everyone is telling, that there is no such hub existing, that take 1/4 bearings in front hub.
Likes For maddog34:
Liked 739 Times
the oddest hub i have here is a nutted axle with an 80mm O.L.D.... off some old Huffy or something. I don't toss it out of curiosity.
No one stated that 1/4" ball front hubs Don't Exist... but they are RARE. Last bike i recall having the 1/4 ball front hub was a Columbia Women-specific "Trail Head" MTB... they were 4 bolt Disc hubs... yes... FOUR bolt discs. alas, the rear hub used odd Cones that are badly trashed/pitted, i had none in stock..... rims/spokes were fine... i replaced both hubs... the front hub is in a stock bin now... after some serious upgrades, the bike now weighs 26 lbs. and is a blast to ride!
Likes For maddog34:
Liked 2,538 Times
So, correct OLD confirms correct size balls. Keep in mind that we're talking about a small difference, so accurate measurement is required.
Liked 739 Times
guess away.
assuming that the axle set Parts weren't changed or some spacers weren't left on the bench........ If the O.L.D. is good, and the axle spins fine....
run it.
i've ranacross a couple front hubs that had 1/4" balls installed by mistake or bad rumors(BMX world!)... they were not a happy setup... crunchy, damaged, and notchy as hell come to mind.... and the OLDs were all over the proverbial map.
one customer said his buddy told him the 1/4" balls made the hub "beefier"... he also had not put grease in since grease "would slow the bike down.".........
