Measuring 9 Speed Movements
Senior member
Quoted: 943 Post(s)
Liked 658 Times
More mods and better measurement recording- I made a dial indicator clamp and set up for the lever/cable measurements. (While a lathe is a beautiful thing a mill is pretty cool too). The measurements are now far more reliable and "stupid free" (not completely but far nicer than making each shift cable movement with a hand held caliper). A couple of immediate observations. I had concerns about the block that is clamped to the cable causing droop in the cable which might add noise to the measurements. The dial holding clamp's V groove bottom (it's crotch) slightly touches the cable and adds some support/stability to the cable. I reversed the dial's pointer direction so its spring is, like the der dial pointer's spring, helps to overcome cable friction in the upshifting direction.
I recorded the Shimano Tiagra lever and Deore der on the charts I drew up. These charts are still a work in progress but are nicer to use and also help me keep track of the various steps to get a full range recorded. Nore that the numbers vary by very little per shift. Both at the lever/cable end and the der end. I only did two series, time and the very consistent results had me not bother with a third run. I'll get around to doing the rest of the math later but since it's not a Shimano lever I am wanting to work with this follow up isn't too important. I am impressed with how little scatter there is for the two series of measurements. Only a few thousandths of an inch most of the time between the two runs. It remains to be seen how the Campy lever measures up. I am rather happy with this at this point.
Next will be measuring a bunch of lever/der/Shiftmates. What might be called the boring part of a project. Andy
It kind of works, and is generally repeatable to within a couple of decimal points, but I wonder if the ramping of spring tension may affect the pull as the spring is tensioned. That's something I always meant to do further testing on, but never got a round tuit. Maybe a winter project one of these years.
Which kind of raises the question, how the heck do you find time to play around with this stuff now in the height of cycling season??
Quoted: 4204 Post(s)
Liked 3,862 Times
Dan- I only work for $ 1 day a week and am happy with 150 miles a week. My real issue with riding season is where my mind goes while on the bike. I seem to come home with new projects or mods to old ones Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1607 Post(s)
Liked 2,216 Times
So based on the graph in post 23, The delta between bllue and red terminations are defined by the limit screws.
Does this lead to a statement that the limit screws could be adjusted to be closer to the average change in pull between gears?
If so, the large sprocket limit screw could be adjusted to increase the distance from the spokes. Don't really care about the other end.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I have nothing to add here, but appreciation for the topic and encouragement to those participating. This is the essence of what a forum like this should be -- enthusiasts helping enthusiasts learn and understand the craft, without pretense or expectation of recompense or favor. Bravo to all!
