Best grease for bottom bracket bearings?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Loose ball, wet conditions? Marine grease.
Likes For Rolla:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Likes For Chuck M:
Quoted: 4802 Post(s)
Liked 3,923 Times
1) Are you racing? 2) Time trialing? 3) Riding in lots of rain? 4) Very deep puddles? 5) Want BBs that are the fastest? 6) Or go the longest distances between overhauls.
For 1) or 5), Campagnolo or Phil Wood. 2) Clean and use just oil; 3:1 or equivalent. (And expect to repeat the whole procedure every ride.) 3), 4) and 6) Marine grease. (The blue stuff in a can or grease gun cartridge at NAPA and the like.)
Likes For 79pmooney:
Quoted: 2337 Post(s)
Liked 2,821 Times
not ins this case you will get about a billion opinions, from possom fat to 30 year old aged white lithium
I prefer Phil's Waterproof. Unless you have lots and lots of bikes and wheel a tube will last for a long time it works and does not fail over time
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
Just go for Phil Wood it is always good stuff. Or don't there are tons of grease options out there and probably many of them just fine.
Really Old Senior Member
Synthetic automotive.
I used to use boat trailer grease and then realized I don't ride under water.
Likes For Bill Kapaun:
Quoted: 4199 Post(s)
Liked 3,851 Times
The answer is the grease that you will enjoy cleaning out and repacking before anything bad happens Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 318 Times
For my bikes it was Krazy Grease. But then the buggers went out of business and my jar is empty.
So far I tried 2 and their both miserable failures at not being washed out by motor oil. >> Park blue grease and a green boat grease.
Likes For GamblerGORD53:
Marine grease or SuperLube.
Likes For etherhuffer:
Quoted: 569 Post(s)
Liked 581 Times
Remember you asked. I have a lot of bikes and retired so helping in the community so I use the best type grease for people who may not be fastidious (or as I have seen not careful at all) in cleaning out old lubes so use a polyurea shear stable grease, easily found at auto parts stores. They are compatible with most any grease used. Engineers can quibble with grease compatibility a bit but you are pretty sure polyurea shear stable, not conventional polyurea, will not react with others and dry out the grease pack.
Likes For easyupbug:
Quoted: 3504 Post(s)
Liked 2,922 Times
Used to use Phil's exclusively until I discovered the longevity of Shimano/Dura Ace Special Grease. I still have my tube of Phil's though.
Likes For smd4:
Quoted: 2026 Post(s)
Liked 1,096 Times
Phils. Readily available, very durable, excellent bearing life, very water resistant and not too viscous so bearing drag is minimal. It's a bit costly in small tubes compared to generic big box grease but good in 14-oz tubes or 600 gm tubs.
Quoted: 2603 Post(s)
Liked 1,926 Times
Uhm, you wash your bottom bracket with motor oil??
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,214 Times
Phil’s or Park Tools. But this is the 21st century and we have these things called cartridge bearing bottom brackets which makes the need for greasing them moot. All the grease I use now is for greasing threads.
Stuart Black
Stuart Black
Likes For rbrides:
Quoted: 8 Post(s)
Liked 17 Times
At the risk of inciting a furor (which, truly, I am NOT trying to do):
I think Phil Wood grease is an excellent product and it always worked very well for me. But I doubt that Phil Wood has Grease Scientists who are staying awake at night perfecting their proprietary formula. It always seemed more likely to me that Phil Wood is buying and repackaging a high quality marine grease.
Several years ago, after doing some research into marine grease, I started using Peak Synthetic Marine Grease. It is blue-green in color and I have yet to find anything that distinguishes it — in appearance or performance — from Phil Wood grease. I have no idea if it is the same product or not, but it seems to hold up pretty well.
Apologies if all this has been posted before … I’m a longtime bike wrench but an infrequent visitor.
Liked 1,096 Times
That Peak Synthetic is indeed a bargain at $5 for a 14-oz tube at Pep Boys so when my near lifetime supply tub of Phil's runs out sometime in the next decade or two, I'll probably buy some.
Likes For HillRider:
Quoted: 1140 Post(s)
Liked 1,736 Times
I just opened this one, this one is great. Silent smooth.
I have another marine grease that a clear green, I don't like that one as much. It's more like a marine version that is compatible with lithium lubes. Not so silent, thinner, I'm sure it's a good product. Just not the same as the above.
Likes For Mr. 66:
