How does power change with saddle set-back?
#51
Quoted: 1814 Post(s)
Liked 923 Times
No but...hard to go fast without watts.
Suffice to say, one size doesn't fit all.
Whatever you do guys, how ever you sit on your saddle, whatever you do, don't do an Indian Larry on your saddle without a helmet. In case you didn't hear, this was the last thing he did:
https://www.youtube.com/watch?v=cheLr1JufCQ
Yes, gotta have watts, but some think that putting out 300 watts to go 24 mph (for example) is an improvement
over putting out 250 watts to go 24 mph.
Disturbing video....
#53
I agree :-) I have in fact already had a pro fit for this bike, and the changes I have made have been to fine tune (or experiment a little) with the fitter's suggestions. The fit certainly wasn't a waste of time; far from it. I got an a reasonably accurate set of measurements, a properly adjusted saddle height (mine was much lower than optimum) and some good changes to saddle and bar position.
I'm now at the stage of having ridden this fit for a couple of months, and have identified some areas that I think could do with improvement. So I'm experimenting first, and will then go back to a fitter (probably not the same one, but to a dedicated fit professional, not a guy in the LBS).
Well, that's my plan anyway!
My view of fitting services is that you are paying for professional advice and should take note of it, but it isn't infallible or cast in stone. Unless you are a serious professional rider (or racer) who is following a strict training and physio development programme, I don't feel contrained to just accept the fitter's recommendations if I start to feel uncomfortable. My alterations may be "wrong", but at least I'm learning something from them, and hey, I can always go back to square one if I make a mistake.
#54
Quick update to my OP. I moved my saddle forward 15mm so that it sits in the middle of the rails, where my fitter has originally placed it (I had moved it back to try and get better balance, and feel less cramped with the 90mm stem I originally had fitted on the bike).
It turns out my measurement of saddle set-back was inaccurate, and that it was previously only about 75mm, and is now 60mm.
With the 120mm stem (8 degree, flipped up) my reach is OK, but I do need to rotate my hips forward and flatten my back in order to get my torso long enough for comfort.
The 15mm saddle shift feels OK, am I am noticeably engaging my quads more. It's hard to tell whether my power output is the same or not, but my times on my standard commute have been slightly slower. However, I haven't ridden enough for statistical proof yet.
I haven't yet adjusted my saddle height (I estimate I should raise my saddle 5mm in the forward position), and this could affect my power output.
I've noticed that I am no longer pedalling heel-down, which I tended to do before.
One potential problem is that I now find I can't easily maintain a position in the widest part of the saddle to the rear and tend to shift forward. This could be a problem on longer rides. Previously, with the saddle further to the rear I found that pressure on the pedals would tend to push me slightly rearward and keep my position on the saddle.
I'll see how it goes!
#55
I would avoid monitoring your power metrics and just try to get comfortable first. Comfort is smooth and smooth is powerful.
#56
saddle setback
I've been playing around with saddle set-back in an attempt to get more comfortable (on my sit-bones) and to find a good balance point to avoid putting too much weight on my arms and pressure on my shoulders.
I ended up with a quite a lot of set-back - about 10cm from the bottom bracket to the tip of the saddle (a Fizik Antares), which does tend to make it feel as though I am "pushing the pedal from the rear" rather than pressing down on top of it.
I'm about 3-4cm behind KOPS.
I often find I end up pedalling slightly "heel-down", which can cause some lower leg strain if I don't watch out for this. I've also had a bit of foot numbness, but don't know if the set-back is the cause, or whether this is due to cleat angle or simply having my shoes done up too tight!
In terms of power output (and muscle usage) how does this vary with saddle set-back, and is there an optimal position for an individual? More importantly, could this optimal position be different to the optimal "balance point", requiring a compromise position to be found?
I've recently tried using a longer stem with a lower angle (I was using a 30 degree riser stem before), because I was feeling a bit cramped in the cockpit, and felt I need to get into a lower position that allowed my arms to "drape" over the bars more easily. I have found that this position stretches me out noticeably more (it's increases reach by 37mm compared to the riser stem), and that my seated position on the saddle has come forward naturally by a little bit.
Given my saddle set-back was already quite large, should I move the saddle forward to compensate, so that my sit bones align to the widest part of the saddle as before? Am I likely to undo all my work finding a good balance point to keep weight of my hands if I do this?
It seems every time I try to fine tune my position for comfort by changing one thing, I end up affecting a lot more parameters!
#57
You're right that the bike is probably a size too small for me. It's a Giant TCX "medium", and I'm 177cm (5'9.5") with a 86cm (34") inseam. My long-for-height inseam means I'm generally better off on a bike one size larger than my height suggests, but I then have to play around with stem and saddle position in order to get comfortable.
Unless you have a seatpost with more than 25mm of setback, it's nearly impossible to move the saddle too far back. Seat post do tend to be a little steeper in the small sizes, but the total range is usually 73-75 degrees, with only the very smallest being 75.
#59
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
FRom what I saw on pro riders bikes was that small range for the kneecap behind pedal axis going from 0mm (or the zero power position to about as much as 10mm. The riders with 0 setback seatposts with much more forward saddle may contradict this and I encourage you to ignore that, and remember this valuable info shared from a few books, one of them had input by Bernard Hinault called ROAD RACING technique&training by Claude Genzling
Find what works for you, not something made up four decades ago.
#61
I use a 10cm saddle to bar drop with a 110mm stem and have the saddle relatively far back. No problem, even in the drops. It's the saddle to bar drop that affects the knee to chest clearance far more than setback. If I were to go to an 11 or 12cm drop, that would get to be uncomfortable.
#62
Bikes: bikes
Liked 1,429 Times
I have to run 165mm cranks and have my saddle quite far forward to get the appropriate bar height and reach (130mm stem), otherwise my knees hit my chest and I have to sit much more upright.
That's quite a common fit issue for people that want to get low and long.
#63
Under typical road geometry and saddles, a lot of riders can't tolerate a saddle position like that unless they pair it with a very upright posture.
Likes For Chi_Z:
#65
Quoted: 3949 Post(s)
Liked 7,292 Times
#66
Quoted: 850 Post(s)
Liked 344 Times
Generally speaking, moving the saddle forward puts more weight on the hands because you "fall forward" more. More weight on the hands = less weight on the butt. This is why tri/TT people have elbow rests. Too far forward, and you'll end up with numb hands pretty quickly. Way too far forward and you'll actually see a decrease in power because your CoG is in front of the pedals and engaging the glutes/hamstrings against the counterweight of your body becomes difficult.
The further back you go, generally, the easier it gets to engage the glutes and hamstrings, but the harder it is to get aero. You might see a decrease in cadence because of hip mobility issues. Also, if you go far back enough, your CoG will be behind the pedals and you won't be able to counterweight the pedals as much with your body. This will force you to either get out of the saddle or twist the bars under hard efforts (which are probably infrequent during commutes).
You might think "how do pros deal with their super forward positions without elbow rests?". A) they are light and B) they are strong. The more pedal force you put down (relative to the upstroke, which you should not be pulling hard on), the more weight is taken off the butt and hands and is transferred to the foot. The stronger you get, the lighter you get from the perspective of your hands and butt.
I would say for consistent efforts (like commuting) where aero is not important (ie not TTs), you should err towards being too far back. Like a beach cruiser but obviously not as extreme. Being too far forward can cause all sorts of issues. Being too far back just means you might not be able to dump 600 seated watts. As your CoG moves further away from the sweetspot, it becomes increasingly critical to keep a high cadence to maintain efficiency.
#67
Quoted: 338 Post(s)
Liked 408 Times
I tried doing 20 min power tests moving the saddle forward and back by a centimeter or so. There was no real difference as best as I could measure.
Saddle too forward made lifting hands off the bars a bit more discomforting and made me grip the bars more tightly which led to some numbness in fingers when trying to go hard for hard on the flat for longer periods. Saddle more to the rear felt weird when trying to keep low and push out some power on the flat, although it felt very natural while climbing.
In the end I put the saddle as far forward where the handling was still fine and balance still felt right.
