Shimano Mountain LX brifters.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I just scored these today, dirt cheap, at that same collective where I scored my Stumpjumper recently. 😎 I love the “motorcycle” levers & hoods. Notice how those hoods say Exage on the back though? This kinda confirms the overlap of Exage & LX. I might have read about it, but seeing makes it easier to “get” the quality of these things. 😎
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
Got the exact 7 speed set on my bastardized Bianchi. The brake levers seem kinda floppy. Maybe that’s to keep them loose for all the crashing I do.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
wow.....had no clue integrated thumbies were ever made! cool score!
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I had integrated thumbies on my high-school-and-college-MTB in the nineties. They were GS level, I think
Genesis 49:16-17
Genesis 49:16-17
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Nice. There were a few others, Mtn Exage and County Exage to name 2. Suntour had at least one model as well.
Likes For stardognine:
Quoted: 4559 Post(s)
Liked 2,802 Times
Yup, the Exage 500 CX and Deore LX rear derailleurs were nearly identical. I have both, no significant differences. Cosmetically different faceplates. Even the model numbers were nearly the same.
The Exage 500 CX group on my early 1990s Univega Via Carisma included "integrated" brake levers and indexed thumb shifters. Both the front and rear derailleurs were indexed, no friction mode available. The thumb shifters were modules that bolted onto a mounting plate that extended from the brake lever housing. The setup located the shifters under the handlebar, which felt more natural to me.
It was a great setup while it worked. Not sure why it didn't catch on, and appeared to have been fitted to only a few bikes for one or two years. Photos of this group are scarce. I need to photograph my own and upload 'em.
The brakes can be used without the shifters -- fortunately, because both shifters finally quit a few years ago. Flushing with WD-40, etc., didn't help. The shifters can't be used without the brake set, unless the owner fabricated a handlebar clamp from scratch, which probably wouldn't be difficult for a metal shop, or perhaps a 3D printer.
Currently I'm using the brakes, despite the gawky looking empty mounting plate, sans shifting modules, because they work well. I switched from flat (well, slightly arced) handlebar to albatross swept bars and bar-end shifters a couple of years ago. Great setup for converting a MTB-lite/gravel-ish bike to an all around city/path bike.
Quoted: 4722 Post(s)
Liked 3,036 Times
It was a great setup while it worked. Not sure why it didn't catch on, and appeared to have been fitted to only a few bikes for one or two years. Photos of this group are scarce. I need to photograph my own and upload 'em....
Shimano's CX series was a short lived (4 years) attempt to design groups specifically for the hybrid market. It was introduced in 1992 with the 200CX and 500CX groups which were replaced by 500CX and 700CX for 1993-1995. As noted, they were heavily based on existing ATB groups. My recollection is that the 500CX levers were Rapidfire and almost identical to Exage 500LX units. If the shifter levers are located under the bar, that sounds like Rapiidfire and not thumb shifters.
Quoted: 656 Post(s)
Liked 469 Times
The Mountain LX shifter with Exage brake lever came as original equipment on my ‘89 GT Karakoram.
Never cared much for the levers. The plastic mount for the right shifter snapped in one of the many spectacular tumbles I took with that bike. I was able to rig a newer Deore thumb shifter which looks fine and works great to this day.
Liked 2,802 Times
...Shimano's CX series was a short lived (4 years) attempt to design groups specifically for the hybrid market. It was introduced in 1992 with the 200CX and 500CX groups which were replaced by 500CX and 700CX for 1993-1995. As noted, they were heavily based on existing ATB groups. My recollection is that the 500CX levers were Rapidfire and almost identical to Exage 500LX units. If the shifter levers are located under the bar, that sounds like Rapiidfire and not thumb shifters.
I need to plug in my NAS file server, which has my photos and other info for this bike. My backup copies on photobucket and Google appear to be gone or the links were changed.
I may have a larger copy of this on my NAS file server.
This is my own bike from around 2017. I don't have a closeup available at the moment.
Someone else's photo, same model but a mixte version with original handlebar, etc.
I had a hybrid with 700 CX, it was very nice stuff. Felt like the "performance" level stuff I was used to from mountain and road bikes as opposed to sloppy and clunky like the cheaper groups, shifters in particular at that time.
I killed virtually all of it in Ottawa, but it did well.
Anyone happen to have an exploded view of the pod? I'm having a heck of a time getting this m050r back together from a complete year down!!! Help!
Liked 3,036 Times
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Check out Campagnolo's Euclid group.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
