Trek's misleading fender-support claims for Domane
Bikes: 2009 Trek Soho
One of the reasons I bought a Domane 4.5 last week was the way-cool hidden fender mounts. I want(ed) to use it as a long-range commuter including in the rain, so fenders are essential and I've had my fill of strap-ons. Nearly every review mentions this feature and specifically that the bike has clearance for 25s with fenders (as was my local dealer's understanding).
So when the Bontrager-approved set arrived this week I was excited...until I tried to install them. But the front mounting bracket doesn't fit the Domane fork (at least for the 4.5, or if you want to get picky, the 4.5 that was sold to me). moreover, no way there is rear clearance for fenders with the stock (25c) tires. we barley got them to fit with 23s, and we still can't get the front fenders to fit.
so, if you care about fenders don't buy Domane. great bike otherwise
thanks, did that + tweeted @trekbikes (public complaining = best way to get attention from most companies)
Likes For kv501:
Bikes: 2014 Cannondale SuperSix Evo Hi-Mod, 2013 Fuji Gran Fondo 2.1c
Sorry that you had your "fill of strap-ons".
If it's any consolation, I was able to modify a set of cheap Avenir plastic fenders so that they fit my Fuji Gran Fondo. It has 23c tires, but clearance is still tight. You only need a few millimeters of clearance though fo them to work.
Bikes: 2013 Cannondale SuperSix 3
Since you bought it only a week ago, return the bike and get the Domane that accomodates the fenders. They'll do it, Trek is really good at exchanges.
but yes, I have had good experiences with Trek trying to make things right in the past. will push them on this
Ever cross your mind that the fenders you got are problem and not the bike, trek/bontrager make a number of different models of fenders that are different sizes and shapes. It is very possible that the particular fender you selected does not fit, but that does not mean that a different fender system will not work.
I'm hoping my LBS is confused somehow, but I doubt it. and, staring at the rear brake, I just don't see the clearance for fenders with a 25c tire.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 669 Post(s)
Liked 969 Times
Domane would be perfect for my commute if it the fenders worked, thank you.
there actually is a stretch of cobblestones, yes. but more generally, it's a 13-15 mile commute with two distinct stretches. the first half is smooth suburban roads built for speed, where a race bike would be great. but the second half is urban jungle with lots of potholed streets where you'd like a bike that can handle the bumps. most of my bikes are good for one half or the other; Domane does both.
that's why I so disappointed about the fenders. it is back at the LBS again today for another try, and the dealer is calling his distributor to find out what is going on. he's quite upset at Trek as he is already out a pair of tires to try to make this work for me
Quoted: 9 Post(s)
Full fenders on my Volagi Liscio. 700x25 conti or rubino pros.
https://imageshack.us/a/img560/2672/imagexdq.jpg
Quoted: 1975 Post(s)
Liked 232 Times
did your dealer trim the fenders around the calipers? This almost always increases clearance. A little time with a dremel should fix most if not all your clearance issues.
great idea, thanks. he already took a hammer to the misshapen clamp, so I'll suggest this. we also put washers on top of the screws that hold the clamp to the fender to reduce the amt the screws stick out below the fender. may mill them down further too. not giving up yet!
645f44
I have a Domane 4.5 with full fenders and 25mm tyres. I'm using crud road racers but I don't see why other fenders designed for close clearance frames / calipers would not work. I also know a couple of people with full fenders on Madones with 23mm tyres.
There is a page here showing a different fender on a Domane. https://classiccycleus.com/home/pdw-full-metal-fenders/
I suspect your dealer is a bit clueless and is blaming Trek instead of admitting his own ignorance. I just can't see Trek telling him to fit their own brand 35mm wide fender to a bike that can only just squeeze in 28mm tyres alone.
I also have to second the comments about the appropriateness of this bike for the task. A Domane is horrible on potholes or cobblestones. It's just marginally less horrible that a conventional bike of its class like a Madone. It still has narrow tires, light wheels and expensive components. I'm not going to say it's the wrong bike for you but it would not be my choice for that task.
Likes For d_D:
thanks d_D for that helpful post. maybe the problem is that the Bontrager fenders are not the best match. the LBS got it working with 23c tires, but I'll check out the Crud and PDW fenders.
/thread
/thread
Bikes: Colnago C59 Italia, 1981 Bianchi Pista
Quoted: 5 Post(s)
-pave
-cobbles (x4)
-rough roads
-potholed
I'm sure it's a perfectly fine choice for this situation.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
The best way to get a dedicated fender bike as I posted in another thread is to build one. The bike industry (at least in the US) still doesn't get it.
