Rubbing Noise Sound Cant find
Old 04-01-14, 08:59 PM
CajunGTO
I just bought a 2013 SL4 Tarmac Expert and I have a front sounding noise that sounds like a low pitch vibration but is not brakes, I loosened the brakes to be sure ....the noise is not continuous but begins around 3-4 miles and very hard to describe except as like a low pitch brake drag vibration or a dry bearing. I have changed out front wheel axial and wheel with no luck... The noise continues even when you stop peddling so I would not think it is drive train related. I have noticed that noise seems less when going 19+ mph but that could be the wind noise canceling it. I will change out the back axle and wheel to see if the frame is transferring the noise to the front. Any help is greatly appreciated!
CajunGTO is offline
Old 04-01-14, 09:25 PM
FBinNY
Quoted: 5366 Post(s)
Liked 1,807 Times in 1,024 Posts
Before you make yourself totally crazy make sure the end of the front derailleur cable isn't rubbing the rear tire.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
acejin
Bicycle Mechanics
3
03-19-14 06:54 PM
Vcycleta
Bicycle Mechanics
30
07-20-13 04:19 PM
curdog
Fifty Plus (50+)
4
12-04-11 01:14 PM
XringX
Bicycle Mechanics
1
08-19-11 06:43 PM
Cold.
Bicycle Mechanics
12
07-11-10 11:49 AM
