Tire Question
Tire Question
Hi Everyone, I need to replace the tires on my Litespeed Arenberg road bike pretty quick. The bike has the Michelin Pro Race Service Course size 700 x 23 tires on it now and when I brought the bike home I was thinking "good, I am set for tires for a while" but maybe not so much. The tread looks new with very little wear other than the approx 200 miles I have put on them but the sidewalls are starting to flake. I want to go with a 700 x 25 and hopefully a 700 x 28 tire on my bike but I am worried about the fit. The front fork look fine as far as fit with all the room I could hope for and the rear brake and brake bridge are the same, plenty of room but the chainstays give me cause for concern. They are tight and even with the current 700 x 23 tire on the rear wheel it is tight with maybe 4 to 5 mm on each side of the tire between the tire sidewall and the inner part of the chainstay.
I am pretty sure I can get a 25mm tire in the rear but a 28mm tire I am thinking might be a problem. Does anyone have any experience with this and can give me their thoughts? If I buy the 28mm tires and they don't fit I don't want to be stuck with them so thoughts and opinions are appreciated. Thanks.
Quoted: 1062 Post(s)
Liked 665 Times
I've been fortunate to have a fair amount of tire clearance on my bikes. But I've noticed that measured tire widths can vary from the rated width by a mm or more. One possible reason is the inside dimension of the rim, but this doesn't seem to be the only factor.
Would a shop let you try out a tire?
Quoted: 836 Post(s)
Liked 1,061 Times
I've noticed that some mfrs are also making their newer tires slightly narrower than in the past for a given marked width. Something about the trend for rims to be wider than in the past which creates a tire that measures wider when mounted. Don't know how old your Pro 4's are but the newer Michelin versions seem to come up a couple mm or so narrower IME so you may be safe with 28's. I wish I could give you a guarantee on fit but that's all I got.
Thanks for weighing in.
