Crank axle keeps working loose
Old 07-28-21, 06:48 PM
robertj298
robertj298's Avatar
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 556 Post(s)
Liked 257 Times in 122 Posts
I've taken the bottom bracket apart and put it back together 3 times. I've adjusted
the adjustable cup 3 times and locked it tight. I ride 2 blocks and the axle wobbles.
Any suggestions?
robertj298 is offline
Old 07-28-21, 07:21 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1010 Post(s)
Liked 943 Times in 499 Posts
well, I guess the question is "what part is coming loose?".
The candidates are:
1. adjustable cup
2. fixed cup
3. crank arm is coming loose on the axle, which gives the impression that the bearings aren't adjusted properly.
I'm guessing that you have to adjust the left cup to tighten things up, which wouldn't point to the crank arm coming loose.
Is the lock ring loose, or do you have to loosen it first before adjusting the left cup? If it is still tight, that suggests that the right cup might be backing out.
Photos would help, as always.
A video of you checking on the looseness and tightening things up might not hurt either.
Steve in Peoria
(I'm betting on the right cup coming loose, just in case it wasn't obvious )
steelbikeguy is offline
Old 07-28-21, 07:31 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
[QUOTE=steelbikeguy;22162006]well, I guess the question is "what part is coming loose?".
The candidates are:
1. adjustable cup
2. fixed cup
Steve in Peoria
(I'm betting on the right cup coming loose, just in case it wasn't obvious )[/QUOTE
I donít think itís the right side cup because I couldnít get it off the first time so I serviced the bearings through the left side. I did notice that the caged bearings fit pretty tight against the cone
Old 07-28-21, 07:32 PM
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 412 Post(s)
Liked 339 Times in 241 Posts
Is this the '86 Panasonic you've been messing with?
Bigbus is offline
Old 07-28-21, 07:49 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
Nope itís the 85 Univega Gran Comp
Old 07-28-21, 08:16 PM
steelbikeguy
Originally Posted by robertj298 View Post
I don’t think it’s the right side cup because I couldn’t get it off the first time so I serviced the bearings through the left side. I did notice that the caged bearings fit pretty tight against the cone
can I change my guess to "the caged bearings are installed the wrong way around"? i.e. might try flipping them over.
Of course, that should mean that the axle doesn't turn freely, I think (I don't recall ever doing this myself)
Photos would be helpful, of course.
I wonder if Park Tool or RJ the Bike Guy have videos explaining about caged bearings?
edit: so you're saying that nothing came loose after each adjustment? i.e. the lock ring wasn't loose and the fixed cup wasn't loose? And the axle turned freely each time you adjusted the bearings?
Steve in Peoria
Likes For steelbikeguy:
Old 07-28-21, 08:20 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
Steve in Peoria
Unless they are the opposite of every other caged bottom bracket bearing I've done they are
the right way. O(pen end of cage towards cup closed end towards cone.
Old 07-28-21, 08:27 PM
SurferRosa
SeŮor Member
SurferRosa's Avatar
Quoted: 1911 Post(s)
Liked 2,162 Times in 1,205 Posts
Unless it's a Campy retainer that accepts 11 balls, I will guess the great majority of c&vers here prefer to toss 9-ball retainers in the trash.
SurferRosa is offline
Old 07-28-21, 08:36 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
I'll have to double check but I believe I replaced 11 balls. I think my next step will be to remove the cage
and putt the bearings in loose.
Old 07-28-21, 11:48 PM
Dfrost
Dfrost's Avatar
Bikes: Ď87 Marinoni SLX Sports Tourer, Ď79 Miyata 912 by Gugificazione
Quoted: 417 Post(s)
Liked 196 Times in 129 Posts
As @SurferRosa implies, there are BB that need caged bearing sets the other way around, like this Campy that needed the closed end toward the cup.
Dfrost is offline
Old 07-29-21, 01:35 AM
randyjawa
randyjawa's Avatar
Quoted: 1131 Post(s)
Liked 969 Times in 587 Posts
Let's assume that the cages and balls are installed properly. Let's assume that everything is adjusted properly. Let's assume that the non-drive side lock nut is locking the non-drive side cup properly. That would leave only one thing, in my mind...
Are the bottom bracket threads or the cup threads in good shape? If not, under use, it is possible that the entire cup is slipping on or jumping over the threads. A cracked bottom bracket shell would also contribute to the problem. Other than that, what else is there to consider?
Again, this thought assumes that installation and adjustment is done properly.
randyjawa is offline
Likes For randyjawa:
Old 07-29-21, 01:52 AM
sd5782
Bikes: 1964 Frejus Tour de France, 1964 Huffy Sportsman 3 speed, 1972 Schwinn Supersport, 1983 Trek 700, 1985 Centurion Ironman, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk
Quoted: 226 Post(s)
Liked 164 Times in 90 Posts
Bearing cage in backwards if they have 11 in the cage.
sd5782 is offline
Old 07-29-21, 03:43 AM
Trakhak
Quoted: 962 Post(s)
Liked 760 Times in 444 Posts
Open side of caged bearings faces spindle bearing race.
Trakhak is offline
Likes For Trakhak:
Old 07-29-21, 03:58 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 88 Post(s)
Liked 42 Times in 29 Posts
There is one possibility that hasn't been mentioned.
If the faces of the bb shell are not parallel, the lock ring has a pretty good chance of loosening up.
"Facing" or milling the faces of the shell removes the paint and excess metal. It allows the lock ring a
smooth surface to rest against.
Tools are expensive for this, but it is truly the best way to get top performance out of
any bb or headset- especially precision versions.
rusty
100bikes is offline
Likes For 100bikes:
Old 07-29-21, 04:55 AM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
This could be it. I was under the impression from the RJ video that all bottom bracket bearings fit with the open end of the cage towards the cup. I will check it today
Old 07-29-21, 05:27 AM
SJX426
SJX426's Avatar
Quoted: 1098 Post(s)
Liked 805 Times in 495 Posts
@robertj298 - Assemble the bearings on the spindle before installing to test the ease of rotation of the caged bearings. The cage should not touch the spindle at all. Then check by adding the NDS cup and apply pressure to the bearing while you turn it. Flip the cage and do it again. One configuration will be much smoother than the other.
SJX426 is offline
Likes For SJX426:
Old 07-29-21, 05:34 AM
shelbyfv
shelbyfv's Avatar
Quoted: 2587 Post(s)
Liked 2,881 Times in 1,530 Posts
More ideas here https://www.bikeforums.net/bicycle-m...sening-up.html and https://www.bikeforums.net/bicycle-m...direction.html
shelbyfv is offline
Old 07-29-21, 05:40 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022, '21 Tsunami SNM-100
Quoted: 1363 Post(s)
Liked 1,318 Times in 709 Posts
This could be it. I was under the impression from the RJ video that ...
And remember, RJ is a hack. He's mostly effective, but a hack nonetheless...
Phil_gretz is offline
Likes For Phil_gretz:
Old 07-29-21, 06:41 AM
bikemig
bikemig's Avatar
Quoted: 5231 Post(s)
Liked 1,857 Times in 1,215 Posts
With cup and cone BBs, you want the adjustment to be a bit on the tight side.
The other suggestions here are good and you'll have to work your way through them.
bikemig is offline
Old 07-29-21, 07:04 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2688 Post(s)
Liked 1,397 Times in 868 Posts
True for 9-ball retainers, but not 11-ball retainers, as @Dfrost notes above.
JohnDThompson is offline
Old 07-29-21, 10:30 AM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
Hats off to SurferRosa From videos and all my other bikes I have done I
just assumed the bearing cage went in with the open side facing the
cup not the other way around. Guess I'll know the next time
Old 07-29-21, 12:07 PM
Phil_gretz
Phil_gretz's Avatar
^ we have all made that mistake once.
Old 07-29-21, 12:35 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 3461 Post(s)
Liked 3,687 Times in 1,861 Posts
Maybe make a mark on the BB aligned with one of the holes in the adjustable cup once you've got it tightened down, and see whether the hole moves?
genejockey is offline
Old 07-29-21, 03:41 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 3407 Post(s)
Liked 1,902 Times in 935 Posts
Not me, no sir, uh-uh.
More than once...
gugie is offline
Likes For gugie:
Old 07-30-21, 04:36 PM
SJX426
SJX426's Avatar
Only once then came up with the process in my previous post. Works every time, but I usually replace with loose balls.
SJX426 is offline
