Steel Frame Surface Rust
Pulled the fender off my cross check today and found this. Anything I can do about it? Is the frame totally screwed?
Quoted: 1438 Post(s)
Liked 1,092 Times
I would apply a rust converter, a Web search will yield many suggestions, which will turn the rust into a stable substance which will act a a primer, then paint over the area to inhibit further rust. Get the converter into the mounting holes and frame tubes as well as you can. I doubt the frame is seriously compromised but frame experts on the forum may chime in.
Likes For dsbrantjr:
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I am not a frame or metal expert, but, I agree with dsbrantjr's assessment. I use a spray made by Lock-tite, Extend Rust Neutralizer. In my experience, it works well.
Quoted: 4195 Post(s)
Liked 3,837 Times
Frame is toast, what size is it???
Really it's just aging. Best- Scrape/sand off all rust you can, and prime/paint with model/touch up paint. Pull off all components and apply rust converter (I use https://www.evaporust.com/ ) internally and then rust inhibitor (Frame Saver). Andy
AndrewRStewart
AndrewRStewart
Bikes: 70's frame, newer parts
Quoted: 92 Post(s)
Liked 38 Times
Then after removing what you can, rinse well, let it dry a good long time then use the converter, primer then paint. Paint is best applied with a brush because spray paint gets into everything
Quoted: 321 Post(s)
Liked 263 Times
The frame is fine. That little bridge has very little structural value anyway, its main purpose is just as a fender mount. But as others have said you want to get some kind of schmoo down in there to try to stop it rusting any more.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Keep in mind, rust converters, like the Lock-tite product, state that rust must be present for them to work.
Ospho works. Is Phosphoric acid that chemically turns the rust to iron Phosphate. You can either paint over it or leave it.
https://www.worldpaintsupply.com/osp...tal-treatment/
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Keep in mind that the naval jelly can form phosphate crystals, which are grayish-white and powdery, on the treated steel. Ospho recommends wiping with mineral spirits to remove them before painting.
The dropped
Liked 1,014 Times
(spanish native lang here)
I see in the pic that its over the metal, isnt corroding the metal, you can also repaint your frame, use premier paint and then the desired color, you can use a drill with a cable ball thing adapter (i dont know how is named in english) and you can strip all out paint and specially oxide parts and you will see that the oxide is over the metal layer, the issue i dont like to use much this method is that let some micro scratches on the metal, no big deal but i dont like it
Likes For depechegore:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Totally screwed? Nope. You're just getting started!
As others have said, that rust is absolutely minimal, that part is not structural, and even if it were, you can see from your picture that it still have loads of wall thickness left.
It may be a bit jarring when you have a newish bike to see a patch of rust, but rust moves very slowly and it would take years and years of very abusive conditions to get to the point where the frame is compromised. If youa re using it as a winter bike in a place where the roads are salted then this might be 5 years of solid Winter use with no maintenance. Probably more than 5 years, but at least 5 years. If you live in a place where the roads are not salted, expect decades of use before rust becomes an issue. It is far more likely that every part of the bike wears out, or the bike is totalled by 'misadventure', before there is a problem with the frame due to rust.
If I were you I would sand the surface rust off as much as is easy to get at, then use nail polish to cover the bare patch, then remount your fenders to cover the nail polish.
The dropped
Liked 1,014 Times
Likes For Unca_Sam:
